root/radiance/ray/src/common/standard.h
Revision: 2.11
Committed: Fri Jan 16 10:43:54 1998 UTC (26 years, 4 months ago) by gregl
changed M_PI definition to ward off long double problems
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Miscellaneous definitions required by many routines.
7 */
8
9 #include <stdio.h>
10
11 #include <fcntl.h>
12
13 #include <math.h>
14
15 #include <errno.h>
16
17 #include "mat4.h"
18 /* regular transformation */
19 typedef struct {
20 MAT4 xfm; /* transform matrix */
21 FLOAT sca; /* scalefactor */
22 } XF;
23 /* complemetary tranformation */
24 typedef struct {
25 XF f; /* forward */
26 XF b; /* backward */
27 } FULLXF;
28
29 #ifndef PI
30 #ifdef M_PI
31 #define PI ((double)M_PI)
32 #else
33 #define PI 3.14159265358979323846
34 #endif
35 #endif
36
37 #ifndef F_OK /* mode bits for access(2) call */
38 #define R_OK 4 /* readable */
39 #define W_OK 2 /* writable */
40 #define X_OK 1 /* executable */
41 #define F_OK 0 /* exists */
42 #endif
43
44 extern int eputs(), wputs(); /* standard error output functions */
45
46 /* error codes */
47 #define WARNING 0 /* non-fatal error */
48 #define USER 1 /* fatal user-caused error */
49 #define SYSTEM 2 /* fatal system-related error */
50 #define INTERNAL 3 /* fatal program-related error */
51 #define CONSISTENCY 4 /* bad consistency check, abort */
52 #define COMMAND 5 /* interactive error */
53 #define NERRS 6
54 /* error struct */
55 extern struct erract {
56 char pre[16]; /* prefix message */
57 int (*pf)(); /* put function (resettable) */
58 int ec; /* exit code (0 means non-fatal) */
59 } erract[NERRS]; /* list of error actions */
60
61 #define ERRACT_INIT { {"warning - ", wputs, 0}, \
62 {"fatal - ", eputs, 1}, \
63 {"system - ", eputs, 2}, \
64 {"internal - ", eputs, 1}, \
65 {"consistency - ", eputs, -1}, \
66 {"", NULL, 0} }
67
68 extern char errmsg[]; /* global buffer for error messages */
69
70 /* memory operations */
71 #ifdef NOSTRUCTASS
72 #define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
73 #else
74 #define copystruct(d,s) (*(d) = *(s))
75 #endif
76
77 #ifndef BSD
78 #define bcopy(s,d,n) (void)memcpy(d,s,n)
79 #define bzero(d,n) (void)memset(d,0,n)
80 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
81 #define index strchr
82 #define rindex strrchr
83 #endif
84
85 extern char *sskip(), *sskip2();
86 extern char *getpath(), *getenv();
87 #ifndef malloc
88 extern char *malloc(), *calloc(), *realloc();
89 #endif
90 extern char *bmalloc(), *savestr(), *savqstr();
91
92 #ifdef DCL_ATOF
93 extern double atof();
94 #endif
95
96 #ifdef MSDOS
97 #define NIX 1
98 #endif
99 #ifdef AMIGA
100 #define NIX 1
101 #endif
102
