1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* Miscellaneous definitions required by many routines. |
7 |
8 |
9 |
#include <stdio.h> |
10 |
11 |
#include <fcntl.h> |
12 |
13 |
#include <math.h> |
14 |
15 |
#include <errno.h> |
16 |
17 |
#include "mat4.h" |
18 |
/* regular transformation */ |
19 |
typedef struct { |
20 |
MAT4 xfm; /* transform matrix */ |
21 |
FLOAT sca; /* scalefactor */ |
22 |
} XF; |
23 |
/* complemetary tranformation */ |
24 |
typedef struct { |
25 |
XF f; /* forward */ |
26 |
XF b; /* backward */ |
27 |
} FULLXF; |
28 |
29 |
#ifndef PI |
30 |
#ifdef M_PI |
31 |
#define PI ((double)M_PI) |
32 |
#else |
33 |
#define PI 3.14159265358979323846 |
34 |
#endif |
35 |
#endif |
36 |
37 |
#ifndef F_OK /* mode bits for access(2) call */ |
38 |
#define R_OK 4 /* readable */ |
39 |
#define W_OK 2 /* writable */ |
40 |
#define X_OK 1 /* executable */ |
41 |
#define F_OK 0 /* exists */ |
42 |
#endif |
43 |
44 |
extern int eputs(), wputs(); /* standard error output functions */ |
45 |
46 |
/* error codes */ |
47 |
#define WARNING 0 /* non-fatal error */ |
48 |
#define USER 1 /* fatal user-caused error */ |
49 |
#define SYSTEM 2 /* fatal system-related error */ |
50 |
#define INTERNAL 3 /* fatal program-related error */ |
51 |
#define CONSISTENCY 4 /* bad consistency check, abort */ |
52 |
#define COMMAND 5 /* interactive error */ |
53 |
#define NERRS 6 |
54 |
/* error struct */ |
55 |
extern struct erract { |
56 |
char pre[16]; /* prefix message */ |
57 |
int (*pf)(); /* put function (resettable) */ |
58 |
int ec; /* exit code (0 means non-fatal) */ |
59 |
} erract[NERRS]; /* list of error actions */ |
60 |
61 |
#define ERRACT_INIT { {"warning - ", wputs, 0}, \ |
62 |
{"fatal - ", eputs, 1}, \ |
63 |
{"system - ", eputs, 2}, \ |
64 |
{"internal - ", eputs, 1}, \ |
65 |
{"consistency - ", eputs, -1}, \ |
66 |
{"", NULL, 0} } |
67 |
68 |
extern char errmsg[]; /* global buffer for error messages */ |
69 |
70 |
/* memory operations */ |
71 |
#ifdef NOSTRUCTASS |
72 |
#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) |
73 |
#else |
74 |
#define copystruct(d,s) (*(d) = *(s)) |
75 |
#endif |
76 |
77 |
#ifndef BSD |
78 |
#define bcopy(s,d,n) (void)memcpy(d,s,n) |
79 |
#define bzero(d,n) (void)memset(d,0,n) |
80 |
#define bcmp(b1,b2,n) memcmp(b1,b2,n) |
81 |
#define index strchr |
82 |
#define rindex strrchr |
83 |
#endif |
84 |
85 |
extern char *sskip(), *sskip2(); |
86 |
extern char *getpath(), *getenv(); |
87 |
#ifndef malloc |
88 |
extern char *malloc(), *calloc(), *realloc(); |
89 |
#endif |
90 |
extern char *bmalloc(), *savestr(), *savqstr(); |
91 |
92 |
#ifdef DCL_ATOF |
93 |
extern double atof(); |
94 |
#endif |
95 |
96 |
#ifdef MSDOS |
97 |
#define NIX 1 |
98 |
#endif |
99 |
#ifdef AMIGA |
100 |
#define NIX 1 |
101 |
#endif |
102 |
