root/radiance/ray/src/common/standard.h
CVS Tags: HEAD, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.30: +7 -206 lines
Diff to previous 2.30 , to selected 2.19
Changes since 2.29: +5 -3 lines
Diff to previous 2.29 , to selected 2.19
Sat Jun 21 14:48:54 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.28: +4 -2 lines
Diff to previous 2.28 , to selected 2.19
Handling of zero vectors in dircode.c and long long lseek fixes for holodecks
Fri Jun 20 16:12:39 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 2.27 , to selected 2.19
Removed stray definition of tcos()
Changes since 2.26: +7 -17 lines
Diff to previous 2.26 , to selected 2.19
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.25: +7 -3 lines
Diff to previous 2.25 , to selected 2.19
Changes since 2.24: +6 -1 lines
Diff to previous 2.24 , to selected 2.19
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.23: +8 -2 lines
Diff to previous 2.23 , to selected 2.19
*** empty log message ***
Changes since 2.22: +8 -70 lines
Diff to previous 2.22 , to selected 2.19
Tue May 13 17:58:32 2003 UTC (21 years ago) by greg
Changes since 2.21: +3 -3 lines
Diff to previous 2.21 , to selected 2.19
Thu Mar 27 16:33:39 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.20 , to selected 2.19
Fixed bug introduced in last update and potential bug in random.h
Thu Mar 27 04:16:33 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.19
Portability fixes immediately following 3.5 release
Revision 2.19 - (view) (download) (annotate) - [selected]
Mon Mar 10 17:13:29 2003 UTC (21 years, 2 months ago) by greg
Diff to previous 2.18
Tue Mar 4 05:49:21 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.17: +9 -0 lines
Diff to previous 2.17 , to selected 2.19
Changes since 2.16: +2 -57 lines
Diff to previous 2.16 , to selected 2.19
Changes since 2.15: +207 -24 lines
Diff to previous 2.15 , to selected 2.19
Mon Jul 12 10:27:59 1999 UTC (24 years, 10 months ago) by gwlarson
Diff to previous 2.14 , to selected 2.19
added declaration for nextword()
Wed Dec 16 18:16:12 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 2.13: +17 -1 lines
Diff to previous 2.13 , to selected 2.19
added new tcos() table-lookup function and tsin() and ttan() macros
added DCHECK(test,error_type,error_message) macro for debugging checks
Wed Aug 12 17:57:44 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.12: +8 -1 lines
Diff to previous 2.12 , to selected 2.19
added int2 and int4 definitions for 2-byte and 4-byte integers
Wed Jun 17 13:28:16 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.11: +7 -1 lines
Diff to previous 2.11 , to selected 2.19
added declaration for lseek() and ftell()
Fri Jan 16 10:43:54 1998 UTC (26 years, 4 months ago) by gregl
Diff to previous 2.10 , to selected 2.19
changed M_PI definition to ward off long double problems
Fri Nov 14 12:31:06 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.9: +7 -7 lines
Diff to previous 2.9 , to selected 2.19
fixed error numbers
Tue Nov 11 19:53:29 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.8: +19 -2 lines
Diff to previous 2.8 , to selected 2.19
Wed Jan 17 10:54:46 1996 UTC (28 years, 4 months ago) by greg
Diff to previous 2.7 , to selected 2.19
replaced sskip() behavior and added new sskip2() function
Wed Jan 10 09:10:58 1996 UTC (28 years, 4 months ago) by greg
Diff to previous 2.6 , to selected 2.19
added conditional define of PI
Fri Nov 10 17:04:14 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.5: +0 -1 lines
Diff to previous 2.5 , to selected 2.19
removed memcpy() declaration
Mon Aug 2 13:51:42 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.4: +4 -0 lines
Diff to previous 2.4 , to selected 2.19
added conditional atof() declarations
Fri Jun 4 15:02:45 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.3: +0 -3 lines
Diff to previous 2.3 , to selected 2.19
removed conflicting atof() declaration
Tue Oct 6 12:29:56 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.2: +5 -0 lines
Diff to previous 2.2 , to selected 2.19
Changes for 32-bit PC port
Mon Sep 21 12:04:27 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +34 -26 lines
Diff to previous 2.1 , to selected 2.19
Changes for PC port
Tue Nov 12 16:54:58 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.9 , to selected 2.19
Thu Oct 24 08:37:58 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.8 , to selected 2.19
got tired of STRUCTASSIGN so changed to NOSTRUCTASS
Wed Oct 23 15:19:23 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 2.19
added FLOAT definition
Wed Oct 23 13:43:09 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.6: +0 -3 lines
Diff to previous 1.6 , to selected 2.19
Fri Apr 12 13:55:33 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.5: +3 -0 lines
Diff to previous 1.5 , to selected 2.19
added defines for index() and rindex() on non-BSD systems
Sat Dec 15 15:01:35 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.4: +12 -2 lines
Diff to previous 1.4 , to selected 2.19
Thu Oct 18 13:34:09 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.3 , to selected 2.19
added forward declaration for getenv()
Thu Jan 18 23:58:53 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.2: +13 -0 lines
Diff to previous 1.2 , to selected 2.19
Thu Jul 27 22:41:04 1989 UTC (34 years, 9 months ago) by greg
Changes since 1.1: +7 -0 lines
Diff to previous 1.1 , to selected 2.19
Changed getpath() to check access modes
Thu Feb 2 10:34:23 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.19
