root/radiance/ray/src/common/standard.h
Revision: 2.13
Committed: Wed Aug 12 17:57:44 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 2.12: +8 -1 lines
added int2 and int4 definitions for 2-byte and 4-byte integers
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Miscellaneous definitions required by many routines.
7 */
8
9 #include <stdio.h>
10
11 #include <sys/types.h>
12
13 #include <fcntl.h>
14
15 #include <math.h>
16
17 #include <errno.h>
18
19 #include "mat4.h"
20 /* regular transformation */
21 typedef struct {
22 MAT4 xfm; /* transform matrix */
23 FLOAT sca; /* scalefactor */
24 } XF;
25 /* complemetary tranformation */
26 typedef struct {
27 XF f; /* forward */
28 XF b; /* backward */
29 } FULLXF;
30
31 #ifndef PI
32 #ifdef M_PI
33 #define PI ((double)M_PI)
34 #else
35 #define PI 3.14159265358979323846
36 #endif
37 #endif
38
39 #ifndef F_OK /* mode bits for access(2) call */
40 #define R_OK 4 /* readable */
41 #define W_OK 2 /* writable */
42 #define X_OK 1 /* executable */
43 #define F_OK 0 /* exists */
44 #endif
45
46 #ifndef int2
47 #define int2 short /* two-byte integer */
48 #endif
49 #ifndef int4
50 #define int4 int /* four-byte integer */
51 #endif
52
53 extern int eputs(), wputs(); /* standard error output functions */
54
55 /* error codes */
56 #define WARNING 0 /* non-fatal error */
57 #define USER 1 /* fatal user-caused error */
58 #define SYSTEM 2 /* fatal system-related error */
59 #define INTERNAL 3 /* fatal program-related error */
60 #define CONSISTENCY 4 /* bad consistency check, abort */
61 #define COMMAND 5 /* interactive error */
62 #define NERRS 6
63 /* error struct */
64 extern struct erract {
65 char pre[16]; /* prefix message */
66 int (*pf)(); /* put function (resettable) */
67 int ec; /* exit code (0 means non-fatal) */
68 } erract[NERRS]; /* list of error actions */
69
70 #define ERRACT_INIT { {"warning - ", wputs, 0}, \
71 {"fatal - ", eputs, 1}, \
72 {"system - ", eputs, 2}, \
73 {"internal - ", eputs, 1}, \
74 {"consistency - ", eputs, -1}, \
75 {"", NULL, 0} }
76
77 extern char errmsg[]; /* global buffer for error messages */
78
79 /* memory operations */
80 #ifdef NOSTRUCTASS
81 #define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
82 #else
83 #define copystruct(d,s) (*(d) = *(s))
84 #endif
85
86 #ifdef BSD
87 extern long lseek();
88 #else
89 #define bcopy(s,d,n) (void)memcpy(d,s,n)
90 #define bzero(d,n) (void)memset(d,0,n)
91 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
92 #define index strchr
93 #define rindex strrchr
94 extern off_t lseek();
95 #endif
96 extern long ftell();
97
98 extern char *sskip(), *sskip2();
99 extern char *getpath(), *getenv();
100 #ifndef malloc
101 extern char *malloc(), *calloc(), *realloc();
102 #endif
103 extern char *bmalloc(), *savestr(), *savqstr();
104
105 #ifdef DCL_ATOF
106 extern double atof();
107 #endif
108
109 #ifdef MSDOS
110 #define NIX 1
111 #endif
112 #ifdef AMIGA
113 #define NIX 1
114 #endif
115
