--- ray/src/common/standard.h 1998/06/17 13:28:16 2.12 +++ ray/src/common/standard.h 2003/06/27 06:53:22 2.31 @@ -1,108 +1,16 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid $Id: standard.h,v 2.31 2003/06/27 06:53:22 greg Exp $ */ /* - * Miscellaneous definitions required by many routines. + * Collected includes required by many Radiance callers */ +#ifndef _RAD_STANDARD_H_ +#define _RAD_STANDARD_H_ -#include +#include "copyright.h" -#include +#include "rtio.h" +#include "rtmisc.h" +#include "rtmath.h" +#include "rterror.h" -#include - -#include - -#include - -#include "mat4.h" - /* regular transformation */ -typedef struct { - MAT4 xfm; /* transform matrix */ - FLOAT sca; /* scalefactor */ -} XF; - /* complemetary tranformation */ -typedef struct { - XF f; /* forward */ - XF b; /* backward */ -} FULLXF; - -#ifndef PI -#ifdef M_PI -#define PI ((double)M_PI) -#else -#define PI 3.14159265358979323846 -#endif -#endif - -#ifndef F_OK /* mode bits for access(2) call */ -#define R_OK 4 /* readable */ -#define W_OK 2 /* writable */ -#define X_OK 1 /* executable */ -#define F_OK 0 /* exists */ -#endif - -extern int eputs(), wputs(); /* standard error output functions */ - - /* error codes */ -#define WARNING 0 /* non-fatal error */ -#define USER 1 /* fatal user-caused error */ -#define SYSTEM 2 /* fatal system-related error */ -#define INTERNAL 3 /* fatal program-related error */ -#define CONSISTENCY 4 /* bad consistency check, abort */ -#define COMMAND 5 /* interactive error */ -#define NERRS 6 - /* error struct */ -extern struct erract { - char pre[16]; /* prefix message */ - int (*pf)(); /* put function (resettable) */ - int ec; /* exit code (0 means non-fatal) */ -} erract[NERRS]; /* list of error actions */ - -#define ERRACT_INIT { {"warning - ", wputs, 0}, \ - {"fatal - ", eputs, 1}, \ - {"system - ", eputs, 2}, \ - {"internal - ", eputs, 1}, \ - {"consistency - ", eputs, -1}, \ - {"", NULL, 0} } - -extern char errmsg[]; /* global buffer for error messages */ - - /* memory operations */ -#ifdef NOSTRUCTASS -#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) -#else -#define copystruct(d,s) (*(d) = *(s)) -#endif - -#ifdef BSD -extern long lseek(); -#else -#define bcopy(s,d,n) (void)memcpy(d,s,n) -#define bzero(d,n) (void)memset(d,0,n) -#define bcmp(b1,b2,n) memcmp(b1,b2,n) -#define index strchr -#define rindex strrchr -extern off_t lseek(); -#endif -extern long ftell(); - -extern char *sskip(), *sskip2(); -extern char *getpath(), *getenv(); -#ifndef malloc -extern char *malloc(), *calloc(), *realloc(); -#endif -extern char *bmalloc(), *savestr(), *savqstr(); - -#ifdef DCL_ATOF -extern double atof(); -#endif - -#ifdef MSDOS -#define NIX 1 -#endif -#ifdef AMIGA -#define NIX 1 -#endif +#endif /* _RAD_STANDARD_H_ */
