root/radiance/ray/src/common/standard.h
Revision: 2.24
Committed: Fri Jun 6 16:38:47 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.23: +8 -2 lines
*** empty log message ***
1 /* RCSid $Id: standard.h,v 2.23 2003/06/05 19:29:34 schorsch Exp $ */
2 /*
3 * Miscellaneous definitions required by many routines.
4 */
5 #ifndef _RAD_STANDARD_H_
6 #define _RAD_STANDARD_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #include "copyright.h"
12
13 #include <stdio.h>
14 #include <sys/types.h>
15 #include <fcntl.h>
16 #include <math.h>
17 #include <errno.h>
18 #include <stdlib.h>
19 #include <string.h>
20
21 #include "platform.h"
22 #include "mat4.h"
23
24 /* regular transformation */
25 typedef struct {
26 MAT4 xfm; /* transform matrix */
27 FLOAT sca; /* scalefactor */
28 } XF;
29 /* complemetary tranformation */
30 typedef struct {
31 XF f; /* forward */
32 XF b; /* backward */
33 } FULLXF;
34
35 #ifndef PI
36 #ifdef M_PI
37 #define PI ((double)M_PI)
38 #else
39 #define PI 3.14159265358979323846
40 #endif
41 #endif
42
43 #ifndef F_OK /* mode bits for access(2) call */
44 #define R_OK 4 /* readable */
45 #define W_OK 2 /* writable */
46 #define X_OK 1 /* executable */
47 #define F_OK 0 /* exists */
48 #endif
49
50 #ifndef int2
51 #define int2 short /* two-byte integer */
52 #endif
53 #ifndef int4
54 #define int4 int /* four-byte integer */
55 #endif
56
57 /* error codes */
58 #define WARNING 0 /* non-fatal error */
59 #define USER 1 /* fatal user-caused error */
60 #define SYSTEM 2 /* fatal system-related error */
61 #define INTERNAL 3 /* fatal program-related error */
62 #define CONSISTENCY 4 /* bad consistency check, abort */
63 #define COMMAND 5 /* interactive error */
64 #define NERRS 6
65 /* error struct */
66 extern struct erract {
67 char pre[16]; /* prefix message */
68 void (*pf)(); /* put function (resettable) */
69 int ec; /* exit code (0 means non-fatal) */
70 } erract[NERRS]; /* list of error actions */
71
72 #define ERRACT_INIT { {"warning - ", wputs, 0}, \
73 {"fatal - ", eputs, 1}, \
74 {"system - ", eputs, 2}, \
75 {"internal - ", eputs, 3}, \
76 {"consistency - ", eputs, -1}, \
77 {"", NULL, 0} }
78
79 extern char errmsg[]; /* global buffer for error messages */
80
81 #ifdef FASTMATH
82 #define tcos cos
83 #define tsin sin
84 #define ttan tan
85 #else
86 extern double tcos(); /* table-based cosine approximation */
87 #define tsin(x) tcos((x)-(PI/2.))
88 #define ttan(x) (tsin(x)/tcos(x))
89 #endif
90 /* custom version of assert(3) */
91 #define CHECK(be,et,em) if (be) error(et,em); else
92 #ifdef DEBUG
93 #define DCHECK CHECK
94 #else
95 #define DCHECK(be,et,em) (void)0
96 #endif
97 /* memory operations */
98 #ifdef NOSTRUCTASS
99 #define copystruct(d,s) bcopy((void *)(s),(void *)(d),sizeof(*(d)))
100 #else
101 #define copystruct(d,s) (*(d) = *(s))
102 #endif
103
104 #ifndef BSD
105 #define bcopy(s,d,n) (void)memcpy(d,s,n)
106 #define bzero(d,n) (void)memset(d,0,n)
107 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
108 #define index strchr
109 #define rindex strrchr
110 #endif
111 extern off_t lseek();
112
113 #ifdef MSDOS
114 #define NIX 1
115 #endif
116 #ifdef AMIGA
117 #define NIX 1
118 #endif
119
120
121 /* defined in badarg.c */
122 extern int badarg(int ac, char **av, char *fl);
123 /* defined in bmalloc.c */
124 extern char *bmalloc(unsigned int n);
125 extern void bfree(char *p, unsigned int n);
126 /* defined in error.c */
127 extern void error(int etype, char *emsg);
128 /* defined in expandarg.c */
129 extern int expandarg(int *acp, char ***avp, int n);
130 /* defined in fdate.c */
131 extern time_t fdate(char *fname);
132 extern int setfdate(char *fname, long ftim);
133 /* defined in fgetline.c */
134 extern char *fgetline(char *s, int n, FILE *fp);
135 /* defined in fgetval.c */
136 extern int fgetval(FILE *fp, int ty, char *vp);
137 /* defined in fgetword.c */
138 extern char *fgetword(char *s, int n, FILE *fp);
139 /* defined in fputword.c */
140 extern void fputword(char *s, FILE *fp);
141 /* defined in fixargv0.c */
142 extern char *fixargv0(char *av0);
143 /* defined in fropen.c */
144 extern FILE *frlibopen(char *fname);
145 /* defined in getlibpath.c */
146 extern char *getrlibpath(void);
147 /* defined in getpath.c */
148 extern char *getpath(char *fname, char *searchpath, int mode);
149 /* defined in portio.c */
150 extern void putstr(char *s, FILE *fp);
151 extern void putint(long i, int siz, FILE *fp);
152 extern void putflt(double f, FILE *fp);
153 extern char *getstr(char *s, FILE *fp);
154 extern long getint(int siz, FILE *fp);
155 extern double getflt(FILE *fp);
156 /* defined in process.c */
157 extern int open_process(int pd[3], char *av[]);
158 extern int process(int pd[3], char *recvbuf, char *sendbuf,
159 int nbr, int nbs);
160 extern int close_process(int pd[3]);
161 extern int readbuf(int fd, char *bpos, int siz);
162 extern int writebuf(int fd, char *bpos, int siz);
163 /* defined in rexpr.c */
164 extern int ecompile(char *sp, int iflg, int wflag);
165 extern char *expsave(void);
166 extern void expset(char *ep);
167 extern char *eindex(char *sp);
168 /* defined in savestr.c */
169 extern char *savestr(char *str);
170 extern void freestr(char *s);
171 extern int shash(char *s);
172 /* defined in savqstr.c */
173 extern char *savqstr(char *s);
174 extern void freeqstr(char *s);
175 /* defined in tcos.c */
176 extern double tcos(double x);
177 /* defined in wordfile.c */
178 extern int wordfile(char **words, char *fname);
179 extern int wordstring(char **avl, char *str);
180 /* defined in words.c */
181 extern char *atos(char *rs, int nb, char *s);
182 extern char *nextword(char *cp, int nb, char *s);
183 extern char *sskip(char *s);
184 extern char *sskip2(char *s, int n);
185 extern char *iskip(char *s);
186 extern char *fskip(char *s);
187 extern int isint(char *s);
188 extern int isintd(char *s, char *ds);
189 extern int isflt(char *s);
190 extern int isfltd(char *s, char *ds);
191 /* defined in xf.c */
192 extern int xf(XF *ret, int ac, char *av[]);
193 extern int invxf(XF *ret, int ac, char *av[]);
194 extern int fullxf(FULLXF *fx, int ac, char *av[]);
195 /* defined in zeroes.c */
196 extern int quadtratic(double *r, double a, double b, double c);
197 /* defined in dircode.c */
198 extern int4 encodedir(FVECT dv);
199 extern void decodedir(FVECT dv, int4 dc);
200 extern double dir2diff(int4 dc1, int4 dc2);
201 extern double fdir2diff(int4 dc1, FVECT v2);
202 /* miscellaneous */
203 extern void eputs(char *s);
204 extern void wputs(char *s);
205 extern void quit(int code);
206
207
208 #ifdef __cplusplus
209 }
210 #endif
211 #endif /* _RAD_STANDARD_H_ */
212
