root/radiance/ray/src/common/standard.h
Revision: 2.16
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.15: +207 -24 lines
1 /* RCSid: $Id$ */
2 /*
3 * Miscellaneous definitions required by many routines.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 #include <stdio.h>
64
65 #include <sys/types.h>
66
67 #include <fcntl.h>
68
69 #include <math.h>
70
71 #include <errno.h>
72
73 #include <stdlib.h>
74
75 #include <string.h>
76
77 #include "mat4.h"
78 /* regular transformation */
79 typedef struct {
80 MAT4 xfm; /* transform matrix */
81 FLOAT sca; /* scalefactor */
82 } XF;
83 /* complemetary tranformation */
84 typedef struct {
85 XF f; /* forward */
86 XF b; /* backward */
87 } FULLXF;
88
89 #ifndef PI
90 #ifdef M_PI
91 #define PI ((double)M_PI)
92 #else
93 #define PI 3.14159265358979323846
94 #endif
95 #endif
96
97 #ifndef F_OK /* mode bits for access(2) call */
98 #define R_OK 4 /* readable */
99 #define W_OK 2 /* writable */
100 #define X_OK 1 /* executable */
101 #define F_OK 0 /* exists */
102 #endif
103
104 #ifndef int2
105 #define int2 short /* two-byte integer */
106 #endif
107 #ifndef int4
108 #define int4 int /* four-byte integer */
109 #endif
110
111 /* error codes */
112 #define WARNING 0 /* non-fatal error */
113 #define USER 1 /* fatal user-caused error */
114 #define SYSTEM 2 /* fatal system-related error */
115 #define INTERNAL 3 /* fatal program-related error */
116 #define CONSISTENCY 4 /* bad consistency check, abort */
117 #define COMMAND 5 /* interactive error */
118 #define NERRS 6
119 /* error struct */
120 extern struct erract {
121 char pre[16]; /* prefix message */
122 void (*pf)(); /* put function (resettable) */
123 int ec; /* exit code (0 means non-fatal) */
124 } erract[NERRS]; /* list of error actions */
125
126 #define ERRACT_INIT { {"warning - ", wputs, 0}, \
127 {"fatal - ", eputs, 1}, \
128 {"system - ", eputs, 2}, \
129 {"internal - ", eputs, 3}, \
130 {"consistency - ", eputs, -1}, \
131 {"", NULL, 0} }
132
133 extern char errmsg[]; /* global buffer for error messages */
134
135 #ifdef FASTMATH
136 #define tcos cos
137 #define tsin sin
138 #define ttan tan
139 #else
140 extern double tcos(); /* table-based cosine approximation */
141 #define tsin(x) tcos((x)-(PI/2.))
142 #define ttan(x) (tsin(x)/tcos(x))
143 #endif
144 /* custom version of assert(3) */
145 #define CHECK(be,et,em) ((be) ? error(et,em) : 0)
146 #ifdef DEBUG
147 #define DCHECK CHECK
148 #else
149 #define DCHECK(be,et,em) 0
150 #endif
151 /* memory operations */
152 #ifdef NOSTRUCTASS
153 #define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
154 #else
155 #define copystruct(d,s) (*(d) = *(s))
156 #endif
157
158 #ifndef BSD
159 #define bcopy(s,d,n) (void)memcpy(d,s,n)
160 #define bzero(d,n) (void)memset(d,0,n)
161 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
162 #define index strchr
163 #define rindex strrchr
164 #endif
165 extern off_t lseek();
166
167 #ifdef MSDOS
168 #define NIX 1
169 #endif
170 #ifdef AMIGA
171 #define NIX 1
172 #endif
173
174 #ifdef NOPROTO
175
176 extern int badarg();
177 extern char *bmalloc();
178 extern void bfree();
179 extern void error();
180 extern int expandarg();
181 extern time_t fdate();
182 extern int setfdate();
183 extern char *fgetline();
184 extern int fgetval();
185 extern char *fgetword();
186 extern void fputword();
187 extern char *fixargv0();
188 extern FILE *frlibopen();
189 extern char *getlibpath();
190 extern char *getpath();
191 extern void putstr();
192 extern void putint();
193 extern void putflt();
194 extern char *getstr();
195 extern long getint();
196 extern double getflt();
197 extern int open_process();
198 extern int process();
199 extern int close_process();
200 extern int readbuf();
201 extern int writebuf();
202 extern int ecompile();
203 extern char *expsave();
204 extern void expset();
205 extern char *eindex();
206 extern char *savestr();
207 extern void freestr();
208 extern int shash();
209 extern char *savqstr();
210 extern void freeqstr();
211 extern double tcos();
212 extern int wordfile();
213 extern int wordstring();
214 extern char *atos();
215 extern char *nextword();
216 extern char *sskip();
217 extern char *sskip2();
218 extern char *iskip();
219 extern char *fskip();
220 extern int isint();
221 extern int isintd();
222 extern int isflt();
223 extern int isfltd();
224 extern int xf();
225 extern int invxf();
226 extern int fullxf();
227 extern int quadtratic();
228 extern void eputs();
229 extern void wputs();
230 extern void quit();
231
232 #else
233 /* defined in badarg.c */
234 extern int badarg(int ac, char **av, char *fl);
235 /* defined in bmalloc.c */
236 extern char *bmalloc(unsigned int n);
237 extern void bfree(char *p, unsigned int n);
238 /* defined in error.c */
239 extern void error(int etype, char *emsg);
240 /* defined in expandarg.c */
241 extern int expandarg(int *acp, char ***avp, int n);
242 /* defined in fdate.c */
243 extern time_t fdate(char *fname);
244 extern int setfdate(char *fname, long ftim);
245 /* defined in fgetline.c */
246 extern char *fgetline(char *s, int n, FILE *fp);
247 /* defined in fgetval.c */
248 extern int fgetval(FILE *fp, int ty, char *vp);
249 /* defined in fgetword.c */
250 extern char *fgetword(char *s, int n, FILE *fp);
251 /* defined in fputword.c */
252 extern void fputword(char *s, FILE *fp);
253 /* defined in fixargv0.c */
254 extern char *fixargv0(char *av0);
255 /* defined in fropen.c */
256 extern FILE *frlibopen(char *fname);
257 /* defined in getlibpath.c */
258 extern char *getlibpath(void);
259 /* defined in getpath.c */
260 extern char *getpath(char *fname, char *searchpath, int mode);
261 /* defined in portio.c */
262 extern void putstr(char *s, FILE *fp);
263 extern void putint(long i, int siz, FILE *fp);
264 extern void putflt(double f, FILE *fp);
265 extern char *getstr(char *s, FILE *fp);
266 extern long getint(int siz, FILE *fp);
267 extern double getflt(FILE *fp);
268 /* defined in process.c */
269 extern int open_process(int pd[3], char *av[]);
270 extern int process(int pd[3], char *recvbuf, char *sendbuf,
271 int nbr, int nbs);
272 extern int close_process(int pd[3]);
273 extern int readbuf(int fd, char *bpos, int siz);
274 extern int writebuf(int fd, char *bpos, int siz);
275 /* defined in rexpr.c */
276 extern int ecompile(char *sp, int iflg, int wflag);
277 extern char *expsave();
278 extern void expset(char *ep);
279 extern char *eindex(char *sp);
280 /* defined in savestr.c */
281 extern char *savestr(char *str);
282 extern void freestr(char *s);
283 extern int shash(char *s);
284 /* defined in savqstr.c */
285 extern char *savqstr(char *s);
286 extern void freeqstr(char *s);
287 /* defined in tcos.c */
288 extern double tcos(double x);
289 /* defined in wordfile.c */
290 extern int wordfile(char **words, char *fname);
291 extern int wordstring(char **avl, char *str);
292 /* defined in words.c */
293 extern char *atos(char *rs, int nb, char *s);
294 extern char *nextword(char *cp, int nb, char *s);
295 extern char *sskip(char *s);
296 extern char *sskip2(char *s, int n);
297 extern char *iskip(char *s);
298 extern char *fskip(char *s);
299 extern int isint(char *s);
300 extern int isintd(char *s, char *ds);
301 extern int isflt(char *s);
302 extern int isfltd(char *s, char *ds);
303 /* defined in xf.c */
304 extern int xf(XF *ret, int ac, char *av[]);
305 extern int invxf(XF *ret, int ac, char *av[]);
306 extern int fullxf(FULLXF *fx, int ac, char *av[]);
307 /* defined in zeroes.c */
308 extern int quadtratic(double *r, double a, double b, double c);
309 /* miscellaneous */
310 extern void eputs(char *s);
311 extern void wputs(char *s);
312 extern void quit(int code);
313
314 #endif
