root/radiance/ray/src/common/standard.h
Revision: 2.5
Committed: Mon Aug 2 13:51:42 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.4: +4 -0 lines
added conditional atof() declarations
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Miscellaneous definitions required by many routines.
7 */
8
9 #include <stdio.h>
10
11 #include <fcntl.h>
12
13 #include <math.h>
14
15 #include <errno.h>
16
17 #include "mat4.h"
18 /* regular transformation */
19 typedef struct {
20 MAT4 xfm; /* transform matrix */
21 FLOAT sca; /* scalefactor */
22 } XF;
23 /* complemetary tranformation */
24 typedef struct {
25 XF f; /* forward */
26 XF b; /* backward */
27 } FULLXF;
28
29 #ifdef M_PI
30 #define PI M_PI
31 #else
32 #define PI 3.14159265358979323846
33 #endif
34
35 #ifndef F_OK /* mode bits for access(2) call */
36 #define R_OK 4 /* readable */
37 #define W_OK 2 /* writable */
38 #define X_OK 1 /* executable */
39 #define F_OK 0 /* exists */
40 #endif
41 /* error codes */
42 #define WARNING 1 /* non-fatal error */
43 #define USER 2 /* fatal user-caused error */
44 #define SYSTEM 3 /* fatal system-related error */
45 #define INTERNAL 4 /* fatal program-related error */
46 #define CONSISTENCY 5 /* bad consistency check, abort */
47 #define COMMAND 6 /* interactive error */
48
49 extern char errmsg[]; /* global buffer for error messages */
50
51 /* memory operations */
52 #ifdef NOSTRUCTASS
53 #define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
54 #else
55 #define copystruct(d,s) (*(d) = *(s))
56 #endif
57
58 #ifndef BSD
59 #define bcopy(s,d,n) (void)memcpy(d,s,n)
60 #define bzero(d,n) (void)memset(d,0,n)
61 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
62 extern char *memcpy(), *memset();
63 #define index strchr
64 #define rindex strrchr
65 #endif
66
67 extern char *sskip();
68 extern char *getpath(), *getenv();
69 #ifndef malloc
70 extern char *malloc(), *calloc(), *realloc();
71 #endif
72 extern char *bmalloc(), *savestr(), *savqstr();
73
74 #ifdef DCL_ATOF
75 extern double atof();
76 #endif
77
78 #ifdef MSDOS
79 #define NIX 1
80 #endif
81 #ifdef AMIGA
82 #define NIX 1
83 #endif
84
