--- ray/src/common/standard.h 1989/07/27 22:41:04 1.2 +++ ray/src/common/standard.h 1995/11/10 17:04:14 2.6 @@ -1,4 +1,4 @@ -/* Copyright (c) 1988 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ /* SCCSid "$SunId$ LBL" */ @@ -8,40 +8,76 @@ #include +#include + #include #include -#include "fvect.h" +#include "mat4.h" + /* regular transformation */ +typedef struct { + MAT4 xfm; /* transform matrix */ + FLOAT sca; /* scalefactor */ +} XF; + /* complemetary tranformation */ +typedef struct { + XF f; /* forward */ + XF b; /* backward */ +} FULLXF; -#define FHUGE (1e10) /* large real number */ -#define FTINY (1e-6) /* small real number */ - -#ifdef M_PI -#define PI M_PI +#ifdef M_PI +#define PI M_PI #else -#define PI 3.14159265358979323846 +#define PI 3.14159265358979323846 #endif -#ifndef F_OK /* mode bits for access(2) call */ -#define R_OK 4 /* readable */ -#define W_OK 2 /* writable */ -#define X_OK 1 /* executable */ -#define F_OK 0 /* exists */ +#ifndef F_OK /* mode bits for access(2) call */ +#define R_OK 4 /* readable */ +#define W_OK 2 /* writable */ +#define X_OK 1 /* executable */ +#define F_OK 0 /* exists */ #endif /* error codes */ -#define WARNING 1 /* non-fatal error */ -#define USER 2 /* fatal user-caused error */ -#define SYSTEM 3 /* fatal system-related error */ -#define INTERNAL 4 /* fatal program-related error */ -#define CONSISTENCY 5 /* bad consistency check, abort */ -#define COMMAND 6 /* interactive error */ +#define WARNING 1 /* non-fatal error */ +#define USER 2 /* fatal user-caused error */ +#define SYSTEM 3 /* fatal system-related error */ +#define INTERNAL 4 /* fatal program-related error */ +#define CONSISTENCY 5 /* bad consistency check, abort */ +#define COMMAND 6 /* interactive error */ extern char errmsg[]; /* global buffer for error messages */ -extern int errno; /* system error number */ + /* memory operations */ +#ifdef NOSTRUCTASS +#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) +#else +#define copystruct(d,s) (*(d) = *(s)) +#endif +#ifndef BSD +#define bcopy(s,d,n) (void)memcpy(d,s,n) +#define bzero(d,n) (void)memset(d,0,n) +#define bcmp(b1,b2,n) memcmp(b1,b2,n) +#define index strchr +#define rindex strrchr +#endif + extern char *sskip(); -extern char *getpath(); +extern char *getpath(), *getenv(); +#ifndef malloc extern char *malloc(), *calloc(), *realloc(); +#endif extern char *bmalloc(), *savestr(), *savqstr(); + +#ifdef DCL_ATOF +extern double atof(); +#endif + +#ifdef MSDOS +#define NIX 1 +#endif +#ifdef AMIGA +#define NIX 1 +#endif +
