--- ray/src/common/standard.h 1995/11/10 17:04:14 2.6
+++ ray/src/common/standard.h 2003/02/22 02:07:22 2.16
@@ -1,19 +1,79 @@
-/* Copyright (c) 1992 Regents of the University of California */
-/* SCCSid "$SunId$ LBL" */
+/* RCSid: $Id: standard.h,v 2.16 2003/02/22 02:07:22 greg Exp $ */
* Miscellaneous definitions required by many routines.
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include
+#include
#include
#include
#include
+#include
+#include
#include "mat4.h"
/* regular transformation */
typedef struct {
@@ -26,11 +86,13 @@ typedef struct {
XF b; /* backward */
} FULLXF;
+#ifndef PI
#ifdef M_PI
-#define PI M_PI
+#define PI ((double)M_PI)
#else
#define PI 3.14159265358979323846
#endif
+#endif
#ifndef F_OK /* mode bits for access(2) call */
#define R_OK 4 /* readable */
@@ -38,16 +100,54 @@ typedef struct {
#define X_OK 1 /* executable */
#define F_OK 0 /* exists */
#endif
+#ifndef int2
+#define int2 short /* two-byte integer */
+#endif
+#ifndef int4
+#define int4 int /* four-byte integer */
+#endif
/* error codes */
-#define WARNING 1 /* non-fatal error */
-#define USER 2 /* fatal user-caused error */
-#define SYSTEM 3 /* fatal system-related error */
-#define INTERNAL 4 /* fatal program-related error */
-#define CONSISTENCY 5 /* bad consistency check, abort */
-#define COMMAND 6 /* interactive error */
+#define WARNING 0 /* non-fatal error */
+#define USER 1 /* fatal user-caused error */
+#define SYSTEM 2 /* fatal system-related error */
+#define INTERNAL 3 /* fatal program-related error */
+#define CONSISTENCY 4 /* bad consistency check, abort */
+#define COMMAND 5 /* interactive error */
+#define NERRS 6
+ /* error struct */
+extern struct erract {
+ char pre[16]; /* prefix message */
+ void (*pf)(); /* put function (resettable) */
+ int ec; /* exit code (0 means non-fatal) */
+} erract[NERRS]; /* list of error actions */
+#define ERRACT_INIT { {"warning - ", wputs, 0}, \
+ {"fatal - ", eputs, 1}, \
+ {"system - ", eputs, 2}, \
+ {"internal - ", eputs, 3}, \
+ {"consistency - ", eputs, -1}, \
+ {"", NULL, 0} }
extern char errmsg[]; /* global buffer for error messages */
+#ifdef FASTMATH
+#define tcos cos
+#define tsin sin
+#define ttan tan
+#else
+extern double tcos(); /* table-based cosine approximation */
+#define tsin(x) tcos((x)-(PI/2.))
+#define ttan(x) (tsin(x)/tcos(x))
+#endif
+ /* custom version of assert(3) */
+#define CHECK(be,et,em) ((be) ? error(et,em) : 0)
+#ifdef DEBUG
+#define DCHECK CHECK
+#else
+#define DCHECK(be,et,em) 0
+#endif
/* memory operations */
#ifdef NOSTRUCTASS
#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
@@ -55,25 +155,15 @@ extern char errmsg[]; /* global buffer for error me
#define copystruct(d,s) (*(d) = *(s))
#endif
-#ifndef BSD
+#ifndef BSD
#define bcopy(s,d,n) (void)memcpy(d,s,n)
#define bzero(d,n) (void)memset(d,0,n)
#define bcmp(b1,b2,n) memcmp(b1,b2,n)
#define index strchr
#define rindex strrchr
#endif
+extern off_t lseek();
-extern char *sskip();
-extern char *getpath(), *getenv();
-#ifndef malloc
-extern char *malloc(), *calloc(), *realloc();
-#endif
-extern char *bmalloc(), *savestr(), *savqstr();
-#ifdef DCL_ATOF
-extern double atof();
-#endif
#ifdef MSDOS
#define NIX 1
#endif
@@ -81,3 +171,144 @@ extern double atof();
#define NIX 1
#endif
+#ifdef NOPROTO
+extern int badarg();
+extern char *bmalloc();
+extern void bfree();
+extern void error();
+extern int expandarg();
+extern time_t fdate();
+extern int setfdate();
+extern char *fgetline();
+extern int fgetval();
+extern char *fgetword();
+extern void fputword();
+extern char *fixargv0();
+extern FILE *frlibopen();
+extern char *getlibpath();
+extern char *getpath();
+extern void putstr();
+extern void putint();
+extern void putflt();
+extern char *getstr();
+extern long getint();
+extern double getflt();
+extern int open_process();
+extern int process();
+extern int close_process();
+extern int readbuf();
+extern int writebuf();
+extern int ecompile();
+extern char *expsave();
+extern void expset();
+extern char *eindex();
+extern char *savestr();
+extern void freestr();
+extern int shash();
+extern char *savqstr();
+extern void freeqstr();
+extern int wordfile();
+extern int wordstring();
+extern char *atos();
+extern char *nextword();
+extern char *sskip();
+extern char *sskip2();
+extern char *iskip();
+extern char *fskip();
+extern int isint();
+extern int isintd();
+extern int isflt();
+extern int isfltd();
+extern int xf();
+extern int invxf();
+extern int fullxf();
+extern int quadtratic();
+extern void eputs();
+extern void wputs();
+extern void quit();
+#else
+ /* defined in badarg.c */
+extern int badarg(int ac, char **av, char *fl);
+ /* defined in bmalloc.c */
+extern char *bmalloc(unsigned int n);
+extern void bfree(char *p, unsigned int n);
+ /* defined in error.c */
+extern void error(int etype, char *emsg);
+ /* defined in expandarg.c */
+extern int expandarg(int *acp, char ***avp, int n);
+ /* defined in fdate.c */
+extern time_t fdate(char *fname);
+extern int setfdate(char *fname, long ftim);
+ /* defined in fgetline.c */
+extern char *fgetline(char *s, int n, FILE *fp);
+ /* defined in fgetval.c */
+extern int fgetval(FILE *fp, int ty, char *vp);
+ /* defined in fgetword.c */
+extern char *fgetword(char *s, int n, FILE *fp);
+ /* defined in fputword.c */
+extern void fputword(char *s, FILE *fp);
+ /* defined in fixargv0.c */
+extern char *fixargv0(char *av0);
+ /* defined in fropen.c */
+extern FILE *frlibopen(char *fname);
+ /* defined in getlibpath.c */
+extern char *getlibpath(void);
+ /* defined in getpath.c */
+extern char *getpath(char *fname, char *searchpath, int mode);
+ /* defined in portio.c */
+extern void putstr(char *s, FILE *fp);
+extern void putint(long i, int siz, FILE *fp);
+extern void putflt(double f, FILE *fp);
+extern char *getstr(char *s, FILE *fp);
+extern long getint(int siz, FILE *fp);
+extern double getflt(FILE *fp);
+ /* defined in process.c */
+extern int open_process(int pd[3], char *av[]);
+extern int process(int pd[3], char *recvbuf, char *sendbuf,
+ int nbr, int nbs);
+extern int close_process(int pd[3]);
+extern int readbuf(int fd, char *bpos, int siz);
+extern int writebuf(int fd, char *bpos, int siz);
+ /* defined in rexpr.c */
+extern int ecompile(char *sp, int iflg, int wflag);
+extern void expset(char *ep);
+extern char *eindex(char *sp);
+ /* defined in savestr.c */
+extern char *savestr(char *str);
+extern void freestr(char *s);
+extern int shash(char *s);
+ /* defined in savqstr.c */
+extern char *savqstr(char *s);
+extern void freeqstr(char *s);
+ /* defined in tcos.c */
+extern double tcos(double x);
+ /* defined in wordfile.c */
+extern int wordfile(char **words, char *fname);
+extern int wordstring(char **avl, char *str);
+ /* defined in words.c */
+extern char *atos(char *rs, int nb, char *s);
+extern char *nextword(char *cp, int nb, char *s);
+extern char *sskip(char *s);
+extern char *sskip2(char *s, int n);
+extern char *iskip(char *s);
+extern char *fskip(char *s);
+extern int isint(char *s);
+extern int isintd(char *s, char *ds);
+extern int isflt(char *s);
+extern int isfltd(char *s, char *ds);
+ /* defined in xf.c */
+extern int xf(XF *ret, int ac, char *av[]);
+extern int invxf(XF *ret, int ac, char *av[]);
+extern int fullxf(FULLXF *fx, int ac, char *av[]);
+ /* defined in zeroes.c */
+extern int quadtratic(double *r, double a, double b, double c);
+ /* miscellaneous */
+extern void eputs(char *s);
+extern void wputs(char *s);
+extern void quit(int code);
+#endif
