root/radiance/ray/src/common/standard.h
Revision: 2.22
Committed: Tue May 13 17:58:32 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.21: +3 -3 lines
1 /* RCSid $Id$ */
2 /*
3 * Miscellaneous definitions required by many routines.
4 */
5
6 #include "copyright.h"
7
8 #include <stdio.h>
9
10 #include <sys/types.h>
11
12 #include <fcntl.h>
13
14 #include <math.h>
15
16 #include <errno.h>
17
18 #include <stdlib.h>
19
20 #include <string.h>
21
22 #include "mat4.h"
23 /* regular transformation */
24 typedef struct {
25 MAT4 xfm; /* transform matrix */
26 FLOAT sca; /* scalefactor */
27 } XF;
28 /* complemetary tranformation */
29 typedef struct {
30 XF f; /* forward */
31 XF b; /* backward */
32 } FULLXF;
33
34 #ifndef PI
35 #ifdef M_PI
36 #define PI ((double)M_PI)
37 #else
38 #define PI 3.14159265358979323846
39 #endif
40 #endif
41
42 #ifndef F_OK /* mode bits for access(2) call */
43 #define R_OK 4 /* readable */
44 #define W_OK 2 /* writable */
45 #define X_OK 1 /* executable */
46 #define F_OK 0 /* exists */
47 #endif
48
49 #ifndef int2
50 #define int2 short /* two-byte integer */
51 #endif
52 #ifndef int4
53 #define int4 int /* four-byte integer */
54 #endif
55
56 /* error codes */
57 #define WARNING 0 /* non-fatal error */
58 #define USER 1 /* fatal user-caused error */
59 #define SYSTEM 2 /* fatal system-related error */
60 #define INTERNAL 3 /* fatal program-related error */
61 #define CONSISTENCY 4 /* bad consistency check, abort */
62 #define COMMAND 5 /* interactive error */
63 #define NERRS 6
64 /* error struct */
65 extern struct erract {
66 char pre[16]; /* prefix message */
67 void (*pf)(); /* put function (resettable) */
68 int ec; /* exit code (0 means non-fatal) */
69 } erract[NERRS]; /* list of error actions */
70
71 #define ERRACT_INIT { {"warning - ", wputs, 0}, \
72 {"fatal - ", eputs, 1}, \
73 {"system - ", eputs, 2}, \
74 {"internal - ", eputs, 3}, \
75 {"consistency - ", eputs, -1}, \
76 {"", NULL, 0} }
77
78 extern char errmsg[]; /* global buffer for error messages */
79
80 #ifdef FASTMATH
81 #define tcos cos
82 #define tsin sin
83 #define ttan tan
84 #else
85 extern double tcos(); /* table-based cosine approximation */
86 #define tsin(x) tcos((x)-(PI/2.))
87 #define ttan(x) (tsin(x)/tcos(x))
88 #endif
89 /* custom version of assert(3) */
90 #define CHECK(be,et,em) if (be) error(et,em); else
91 #ifdef DEBUG
92 #define DCHECK CHECK
93 #else
94 #define DCHECK(be,et,em) (void)0
95 #endif
96 /* memory operations */
97 #ifdef NOSTRUCTASS
98 #define copystruct(d,s) bcopy((void *)(s),(void *)(d),sizeof(*(d)))
99 #else
100 #define copystruct(d,s) (*(d) = *(s))
101 #endif
102
103 #ifndef BSD
104 #define bcopy(s,d,n) (void)memcpy(d,s,n)
105 #define bzero(d,n) (void)memset(d,0,n)
106 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
107 #define index strchr
108 #define rindex strrchr
109 #endif
110 extern off_t lseek();
111
112 #ifdef MSDOS
113 #define NIX 1
114 #endif
115 #ifdef AMIGA
116 #define NIX 1
117 #endif
118
119 #ifdef NOPROTO
120
121 extern int badarg();
122 extern char *bmalloc();
123 extern void bfree();
124 extern void error();
125 extern int expandarg();
126 extern time_t fdate();
127 extern int setfdate();
128 extern char *fgetline();
129 extern int fgetval();
130 extern char *fgetword();
131 extern void fputword();
132 extern char *fixargv0();
133 extern FILE *frlibopen();
134 extern char *getrlibpath();
135 extern char *getpath();
136 extern void putstr();
137 extern void putint();
138 extern void putflt();
139 extern char *getstr();
140 extern long getint();
141 extern double getflt();
142 extern int open_process();
143 extern int process();
144 extern int close_process();
145 extern int readbuf();
146 extern int writebuf();
147 extern int ecompile();
148 extern char *expsave();
149 extern void expset();
150 extern char *eindex();
151 extern char *savestr();
152 extern void freestr();
153 extern int shash();
154 extern char *savqstr();
155 extern void freeqstr();
156 extern double tcos();
157 extern int wordfile();
158 extern int wordstring();
159 extern char *atos();
160 extern char *nextword();
161 extern char *sskip();
162 extern char *sskip2();
163 extern char *iskip();
164 extern char *fskip();
165 extern int isint();
166 extern int isintd();
167 extern int isflt();
168 extern int isfltd();
169 extern int xf();
170 extern int invxf();
171 extern int fullxf();
172 extern int quadtratic();
173 extern int4 encodedir();
174 extern void decodedir();
175 extern double dir2diff();
176 extern double fdir2diff();
177 extern void eputs();
178 extern void wputs();
179 extern void quit();
180
181 #else
182 /* defined in badarg.c */
183 extern int badarg(int ac, char **av, char *fl);
184 /* defined in bmalloc.c */
185 extern char *bmalloc(unsigned int n);
186 extern void bfree(char *p, unsigned int n);
187 /* defined in error.c */
188 extern void error(int etype, char *emsg);
189 /* defined in expandarg.c */
190 extern int expandarg(int *acp, char ***avp, int n);
191 /* defined in fdate.c */
192 extern time_t fdate(char *fname);
193 extern int setfdate(char *fname, long ftim);
194 /* defined in fgetline.c */
195 extern char *fgetline(char *s, int n, FILE *fp);
196 /* defined in fgetval.c */
197 extern int fgetval(FILE *fp, int ty, char *vp);
198 /* defined in fgetword.c */
199 extern char *fgetword(char *s, int n, FILE *fp);
200 /* defined in fputword.c */
201 extern void fputword(char *s, FILE *fp);
202 /* defined in fixargv0.c */
203 extern char *fixargv0(char *av0);
204 /* defined in fropen.c */
205 extern FILE *frlibopen(char *fname);
206 /* defined in getlibpath.c */
207 extern char *getrlibpath(void);
208 /* defined in getpath.c */
209 extern char *getpath(char *fname, char *searchpath, int mode);
210 /* defined in portio.c */
211 extern void putstr(char *s, FILE *fp);
212 extern void putint(long i, int siz, FILE *fp);
213 extern void putflt(double f, FILE *fp);
214 extern char *getstr(char *s, FILE *fp);
215 extern long getint(int siz, FILE *fp);
216 extern double getflt(FILE *fp);
217 /* defined in process.c */
218 extern int open_process(int pd[3], char *av[]);
219 extern int process(int pd[3], char *recvbuf, char *sendbuf,
220 int nbr, int nbs);
221 extern int close_process(int pd[3]);
222 extern int readbuf(int fd, char *bpos, int siz);
223 extern int writebuf(int fd, char *bpos, int siz);
224 /* defined in rexpr.c */
225 extern int ecompile(char *sp, int iflg, int wflag);
226 extern char *expsave(void);
227 extern void expset(char *ep);
228 extern char *eindex(char *sp);
229 /* defined in savestr.c */
230 extern char *savestr(char *str);
231 extern void freestr(char *s);
232 extern int shash(char *s);
233 /* defined in savqstr.c */
234 extern char *savqstr(char *s);
235 extern void freeqstr(char *s);
236 /* defined in tcos.c */
237 extern double tcos(double x);
238 /* defined in wordfile.c */
239 extern int wordfile(char **words, char *fname);
240 extern int wordstring(char **avl, char *str);
241 /* defined in words.c */
242 extern char *atos(char *rs, int nb, char *s);
243 extern char *nextword(char *cp, int nb, char *s);
244 extern char *sskip(char *s);
245 extern char *sskip2(char *s, int n);
246 extern char *iskip(char *s);
247 extern char *fskip(char *s);
248 extern int isint(char *s);
249 extern int isintd(char *s, char *ds);
250 extern int isflt(char *s);
251 extern int isfltd(char *s, char *ds);
252 /* defined in xf.c */
253 extern int xf(XF *ret, int ac, char *av[]);
254 extern int invxf(XF *ret, int ac, char *av[]);
255 extern int fullxf(FULLXF *fx, int ac, char *av[]);
256 /* defined in zeroes.c */
257 extern int quadtratic(double *r, double a, double b, double c);
258 /* defined in dircode.c */
259 extern int4 encodedir(FVECT dv);
260 extern void decodedir(FVECT dv, int4 dc);
261 extern double dir2diff(int4 dc1, int4 dc2);
262 extern double fdir2diff(int4 dc1, FVECT v2);
263 /* miscellaneous */
264 extern void eputs(char *s);
265 extern void wputs(char *s);
266 extern void quit(int code);
267
268 #endif
