root/radiance/ray/src/common/standard.h
Revision: 2.27
Committed: Fri Jun 20 00:25:49 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.26: +7 -17 lines
1 /* RCSid $Id: standard.h,v 2.26 2003/06/08 12:03:09 schorsch Exp $ */
2 /*
3 * Miscellaneous definitions required by many routines.
4 */
5 #ifndef _RAD_STANDARD_H_
6 #define _RAD_STANDARD_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #include "copyright.h"
12
13 #include <stdio.h>
14 #include <sys/types.h>
15 #include <fcntl.h>
16 #include <math.h>
17 #include <errno.h>
18 #include <stdlib.h>
19 #include <string.h>
20
21 #include "tifftypes.h"
22
23 #include "mat4.h"
24
25 /* regular transformation */
26 typedef struct {
27 MAT4 xfm; /* transform matrix */
28 FLOAT sca; /* scalefactor */
29 } XF;
30 /* complemetary tranformation */
31 typedef struct {
32 XF f; /* forward */
33 XF b; /* backward */
34 } FULLXF;
35
36 #ifndef PI
37 #ifdef M_PI
38 #define PI ((double)M_PI)
39 #else
40 #define PI 3.14159265358979323846
41 #endif
42 #endif
43
44 /* XXX include paths.h instead */
45 #ifndef F_OK /* mode bits for access(2) call */
46 #define R_OK 4 /* readable */
47 #define W_OK 2 /* writable */
48 #define X_OK 1 /* executable */
49 #define F_OK 0 /* exists */
50 #endif
51
52 /* error codes */
53 #define WARNING 0 /* non-fatal error */
54 #define USER 1 /* fatal user-caused error */
55 #define SYSTEM 2 /* fatal system-related error */
56 #define INTERNAL 3 /* fatal program-related error */
57 #define CONSISTENCY 4 /* bad consistency check, abort */
58 #define COMMAND 5 /* interactive error */
59 #define NERRS 6
60 /* error struct */
61 extern struct erract {
62 char pre[16]; /* prefix message */
63 void (*pf)(); /* put function (resettable) */
64 int ec; /* exit code (0 means non-fatal) */
65 } erract[NERRS]; /* list of error actions */
66
67 #define ERRACT_INIT { {"warning - ", wputs, 0}, \
68 {"fatal - ", eputs, 1}, \
69 {"system - ", eputs, 2}, \
70 {"internal - ", eputs, 3}, \
71 {"consistency - ", eputs, -1}, \
72 {"", NULL, 0} }
73
74 extern char errmsg[]; /* global buffer for error messages */
75
76 #ifdef FASTMATH
77 #define tcos cos
78 #define tsin sin
79 #define ttan tan
80 #else
81 extern double tcos(); /* table-based cosine approximation */
82 #define tsin(x) tcos((x)-(PI/2.))
83 #define ttan(x) (tsin(x)/tcos(x))
84 #endif
85 /* custom version of assert(3) */
86 #define CHECK(be,et,em) if (be) error(et,em); else
87 #ifdef DEBUG
88 #define DCHECK CHECK
89 #else
90 #define DCHECK(be,et,em) (void)0
91 #endif
92 /* memory operations */
93 #ifdef NOSTRUCTASS
94 #define copystruct(d,s) bcopy((void *)(s),(void *)(d),sizeof(*(d)))
95 #else
96 #define copystruct(d,s) (*(d) = *(s))
97 #endif
98
99 #ifndef BSD
100 #define bcopy(s,d,n) (void)memcpy(d,s,n)
101 #define bzero(d,n) (void)memset(d,0,n)
102 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
103 #define index strchr
104 #define rindex strrchr
105 #endif
106 extern off_t lseek();
107
108 #ifdef _WIN32
109 #define NIX 1
110 #endif
111 #ifdef AMIGA
112 #define NIX 1
113 #endif
114
115
116 /* defined in badarg.c */
117 extern int badarg(int ac, char **av, char *fl);
118 /* defined in bmalloc.c */
119 extern char *bmalloc(unsigned int n);
120 extern void bfree(char *p, unsigned int n);
121 /* defined in error.c */
122 extern void error(int etype, char *emsg);
123 /* defined in expandarg.c */
124 extern int expandarg(int *acp, char ***avp, int n);
125 /* defined in fdate.c */
126 extern time_t fdate(char *fname);
127 extern int setfdate(char *fname, long ftim);
128 /* defined in fgetline.c */
129 extern char *fgetline(char *s, int n, FILE *fp);
130 /* defined in fgetval.c */
131 extern int fgetval(FILE *fp, int ty, char *vp);
132 /* defined in fgetword.c */
133 extern char *fgetword(char *s, int n, FILE *fp);
134 /* defined in fputword.c */
135 extern void fputword(char *s, FILE *fp);
136 /* defined in fixargv0.c */
137 extern char *fixargv0(char *av0);
138 /* defined in fropen.c */
139 extern FILE *frlibopen(char *fname);
140 /* defined in getlibpath.c */
141 extern char *getrlibpath(void);
142 /* defined in getpath.c */
143 extern char *getpath(char *fname, char *searchpath, int mode);
144 /* defined in portio.c */
145 extern void putstr(char *s, FILE *fp);
146 extern void putint(long i, int siz, FILE *fp);
147 extern void putflt(double f, FILE *fp);
148 extern char *getstr(char *s, FILE *fp);
149 extern long getint(int siz, FILE *fp);
150 extern double getflt(FILE *fp);
151 /* defined in process.c */
152 extern int open_process(int pd[3], char *av[]);
153 extern int process(int pd[3], char *recvbuf, char *sendbuf,
154 int nbr, int nbs);
155 extern int close_process(int pd[3]);
156 extern int readbuf(int fd, char *bpos, int siz);
157 extern int writebuf(int fd, char *bpos, int siz);
158 /* defined in rexpr.c */
159 extern int ecompile(char *sp, int iflg, int wflag);
160 extern char *expsave(void);
161 extern void expset(char *ep);
162 extern char *eindex(char *sp);
163 /* defined in savestr.c */
164 extern char *savestr(char *str);
165 extern void freestr(char *s);
166 extern int shash(char *s);
167 /* defined in savqstr.c */
168 extern char *savqstr(char *s);
169 extern void freeqstr(char *s);
170 /* defined in tcos.c */
171 extern double tcos(double x);
172 /* defined in wordfile.c */
173 extern int wordfile(char **words, char *fname);
174 extern int wordstring(char **avl, char *str);
175 /* defined in words.c */
176 extern char *atos(char *rs, int nb, char *s);
177 extern char *nextword(char *cp, int nb, char *s);
178 extern char *sskip(char *s);
179 extern char *sskip2(char *s, int n);
180 extern char *iskip(char *s);
181 extern char *fskip(char *s);
182 extern int isint(char *s);
183 extern int isintd(char *s, char *ds);
184 extern int isflt(char *s);
185 extern int isfltd(char *s, char *ds);
186 /* defined in xf.c */
187 extern int xf(XF *ret, int ac, char *av[]);
188 extern int invxf(XF *ret, int ac, char *av[]);
189 extern int fullxf(FULLXF *fx, int ac, char *av[]);
190 /* defined in zeroes.c */
191 extern int quadtratic(double *r, double a, double b, double c);
192 /* defined in dircode.c */
193 extern int32 encodedir(FVECT dv);
194 extern void decodedir(FVECT dv, int32 dc);
195 extern double dir2diff(int32 dc1, int32 dc2);
196 extern double fdir2diff(int32 dc1, FVECT v2);
197 /* defined in lamp.c */
198 extern float * matchlamp(char *s);
199 extern int loadlamps(char *file);
200 extern void freelamps(void);
201 /* miscellaneous */
202 extern void eputs(char *s);
203 extern void wputs(char *s);
204 extern void quit(int code);
205
206
207 #ifdef __cplusplus
208 }
209 #endif
210 #endif /* _RAD_STANDARD_H_ */
211
