--- ray/src/common/standard.h 1998/12/16 18:16:12 2.14 +++ ray/src/common/standard.h 2003/03/04 05:49:21 2.18 @@ -1,11 +1,10 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid $Id: standard.h,v 2.18 2003/03/04 05:49:21 greg Exp $ */ /* * Miscellaneous definitions required by many routines. */ +#include "copyright.h" + #include #include @@ -16,6 +15,10 @@ #include +#include + +#include + #include "mat4.h" /* regular transformation */ typedef struct { @@ -50,8 +53,6 @@ typedef struct { #define int4 int /* four-byte integer */ #endif -extern int eputs(), wputs(); /* standard error output functions */ - /* error codes */ #define WARNING 0 /* non-fatal error */ #define USER 1 /* fatal user-caused error */ @@ -63,14 +64,14 @@ extern int eputs(), wputs(); /* standard error output /* error struct */ extern struct erract { char pre[16]; /* prefix message */ - int (*pf)(); /* put function (resettable) */ + void (*pf)(); /* put function (resettable) */ int ec; /* exit code (0 means non-fatal) */ } erract[NERRS]; /* list of error actions */ #define ERRACT_INIT { {"warning - ", wputs, 0}, \ {"fatal - ", eputs, 1}, \ {"system - ", eputs, 2}, \ - {"internal - ", eputs, 1}, \ + {"internal - ", eputs, 3}, \ {"consistency - ", eputs, -1}, \ {"", NULL, 0} } @@ -99,29 +100,15 @@ extern double tcos(); /* table-based cosine approxim #define copystruct(d,s) (*(d) = *(s)) #endif -#ifdef BSD -extern long lseek(); -#else +#ifndef BSD #define bcopy(s,d,n) (void)memcpy(d,s,n) #define bzero(d,n) (void)memset(d,0,n) #define bcmp(b1,b2,n) memcmp(b1,b2,n) #define index strchr #define rindex strrchr -extern off_t lseek(); #endif -extern long ftell(); +extern off_t lseek(); -extern char *sskip(), *sskip2(); -extern char *getpath(), *getenv(); -#ifndef malloc -extern char *malloc(), *calloc(), *realloc(); -#endif -extern char *bmalloc(), *savestr(), *savqstr(); - -#ifdef DCL_ATOF -extern double atof(); -#endif - #ifdef MSDOS #define NIX 1 #endif @@ -129,3 +116,153 @@ extern double atof(); #define NIX 1 #endif +#ifdef NOPROTO + +extern int badarg(); +extern char *bmalloc(); +extern void bfree(); +extern void error(); +extern int expandarg(); +extern time_t fdate(); +extern int setfdate(); +extern char *fgetline(); +extern int fgetval(); +extern char *fgetword(); +extern void fputword(); +extern char *fixargv0(); +extern FILE *frlibopen(); +extern char *getlibpath(); +extern char *getpath(); +extern void putstr(); +extern void putint(); +extern void putflt(); +extern char *getstr(); +extern long getint(); +extern double getflt(); +extern int open_process(); +extern int process(); +extern int close_process(); +extern int readbuf(); +extern int writebuf(); +extern int ecompile(); +extern char *expsave(); +extern void expset(); +extern char *eindex(); +extern char *savestr(); +extern void freestr(); +extern int shash(); +extern char *savqstr(); +extern void freeqstr(); +extern double tcos(); +extern int wordfile(); +extern int wordstring(); +extern char *atos(); +extern char *nextword(); +extern char *sskip(); +extern char *sskip2(); +extern char *iskip(); +extern char *fskip(); +extern int isint(); +extern int isintd(); +extern int isflt(); +extern int isfltd(); +extern int xf(); +extern int invxf(); +extern int fullxf(); +extern int quadtratic(); +extern int4 encodedir(); +extern void decodedir(); +extern double dir2diff(); +extern double fdir2diff(); +extern void eputs(); +extern void wputs(); +extern void quit(); + +#else + /* defined in badarg.c */ +extern int badarg(int ac, char **av, char *fl); + /* defined in bmalloc.c */ +extern char *bmalloc(unsigned int n); +extern void bfree(char *p, unsigned int n); + /* defined in error.c */ +extern void error(int etype, char *emsg); + /* defined in expandarg.c */ +extern int expandarg(int *acp, char ***avp, int n); + /* defined in fdate.c */ +extern time_t fdate(char *fname); +extern int setfdate(char *fname, long ftim); + /* defined in fgetline.c */ +extern char *fgetline(char *s, int n, FILE *fp); + /* defined in fgetval.c */ +extern int fgetval(FILE *fp, int ty, char *vp); + /* defined in fgetword.c */ +extern char *fgetword(char *s, int n, FILE *fp); + /* defined in fputword.c */ +extern void fputword(char *s, FILE *fp); + /* defined in fixargv0.c */ +extern char *fixargv0(char *av0); + /* defined in fropen.c */ +extern FILE *frlibopen(char *fname); + /* defined in getlibpath.c */ +extern char *getlibpath(void); + /* defined in getpath.c */ +extern char *getpath(char *fname, char *searchpath, int mode); + /* defined in portio.c */ +extern void putstr(char *s, FILE *fp); +extern void putint(long i, int siz, FILE *fp); +extern void putflt(double f, FILE *fp); +extern char *getstr(char *s, FILE *fp); +extern long getint(int siz, FILE *fp); +extern double getflt(FILE *fp); + /* defined in process.c */ +extern int open_process(int pd[3], char *av[]); +extern int process(int pd[3], char *recvbuf, char *sendbuf, + int nbr, int nbs); +extern int close_process(int pd[3]); +extern int readbuf(int fd, char *bpos, int siz); +extern int writebuf(int fd, char *bpos, int siz); + /* defined in rexpr.c */ +extern int ecompile(char *sp, int iflg, int wflag); +extern char *expsave(); +extern void expset(char *ep); +extern char *eindex(char *sp); + /* defined in savestr.c */ +extern char *savestr(char *str); +extern void freestr(char *s); +extern int shash(char *s); + /* defined in savqstr.c */ +extern char *savqstr(char *s); +extern void freeqstr(char *s); + /* defined in tcos.c */ +extern double tcos(double x); + /* defined in wordfile.c */ +extern int wordfile(char **words, char *fname); +extern int wordstring(char **avl, char *str); + /* defined in words.c */ +extern char *atos(char *rs, int nb, char *s); +extern char *nextword(char *cp, int nb, char *s); +extern char *sskip(char *s); +extern char *sskip2(char *s, int n); +extern char *iskip(char *s); +extern char *fskip(char *s); +extern int isint(char *s); +extern int isintd(char *s, char *ds); +extern int isflt(char *s); +extern int isfltd(char *s, char *ds); + /* defined in xf.c */ +extern int xf(XF *ret, int ac, char *av[]); +extern int invxf(XF *ret, int ac, char *av[]); +extern int fullxf(FULLXF *fx, int ac, char *av[]); + /* defined in zeroes.c */ +extern int quadtratic(double *r, double a, double b, double c); + /* defined in dircode.c */ +extern int4 encodedir(FVECT dv); +extern void decodedir(FVECT dv, int4 dc); +extern double dir2diff(int4 dc1, int4 dc2); +extern double fdir2diff(int4 dc1, FVECT v2); + /* miscellaneous */ +extern void eputs(char *s); +extern void wputs(char *s); +extern void quit(int code); + +#endif
