Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Handling of zero vectors in dircode.c and long long lseek fixes for holodecks
Removed stray definition of tcos()
*** empty log message ***
Fixed bug introduced in last update and potential bug in random.h
Portability fixes immediately following 3.5 release
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added declaration for nextword()
added new tcos() table-lookup function and tsin() and ttan() macros added DCHECK(test,error_type,error_message) macro for debugging checks
added int2 and int4 definitions for 2-byte and 4-byte integers
added declaration for lseek() and ftell()
changed M_PI definition to ward off long double problems
fixed error numbers
replaced sskip() behavior and added new sskip2() function
added conditional define of PI
removed memcpy() declaration
added conditional atof() declarations
removed conflicting atof() declaration
Changes for 32-bit PC port
Changes for PC port
got tired of STRUCTASSIGN so changed to NOSTRUCTASS
added FLOAT definition
added defines for index() and rindex() on non-BSD systems
added forward declaration for getenv()
Changed getpath() to check access modes
