--- ray/src/common/standard.h 1992/09/21 12:04:27 2.2 +++ ray/src/common/standard.h 2003/02/22 02:07:22 2.16 @@ -1,19 +1,79 @@ -/* Copyright (c) 1992 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: standard.h,v 2.16 2003/02/22 02:07:22 greg Exp $ */ /* * Miscellaneous definitions required by many routines. */ +/* ==================================================================== + * The Radiance Software License, Version 1.0 + * + * Copyright (c) 1990 - 2002 The Regents of the University of California, + * through Lawrence Berkeley National Laboratory. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * 3. The end-user documentation included with the redistribution, + * if any, must include the following acknowledgment: + * "This product includes Radiance software + * (http://radsite.lbl.gov/) + * developed by the Lawrence Berkeley National Laboratory + * (http://www.lbl.gov/)." + * Alternately, this acknowledgment may appear in the software itself, + * if and wherever such third-party acknowledgments normally appear. + * + * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" + * and "The Regents of the University of California" must + * not be used to endorse or promote products derived from this + * software without prior written permission. For written + * permission, please contact radiance@radsite.lbl.gov. + * + * 5. Products derived from this software may not be called "Radiance", + * nor may "Radiance" appear in their name, without prior written + * permission of Lawrence Berkeley National Laboratory. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR + * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * ==================================================================== + * + * This software consists of voluntary contributions made by many + * individuals on behalf of Lawrence Berkeley National Laboratory. For more + * information on Lawrence Berkeley National Laboratory, please see + * . + */ + #include +#include + #include #include #include +#include + +#include + #include "mat4.h" /* regular transformation */ typedef struct { @@ -26,11 +86,13 @@ typedef struct { XF b; /* backward */ } FULLXF; +#ifndef PI #ifdef M_PI -#define PI M_PI +#define PI ((double)M_PI) #else #define PI 3.14159265358979323846 #endif +#endif #ifndef F_OK /* mode bits for access(2) call */ #define R_OK 4 /* readable */ @@ -38,16 +100,54 @@ typedef struct { #define X_OK 1 /* executable */ #define F_OK 0 /* exists */ #endif + +#ifndef int2 +#define int2 short /* two-byte integer */ +#endif +#ifndef int4 +#define int4 int /* four-byte integer */ +#endif + /* error codes */ -#define WARNING 1 /* non-fatal error */ -#define USER 2 /* fatal user-caused error */ -#define SYSTEM 3 /* fatal system-related error */ -#define INTERNAL 4 /* fatal program-related error */ -#define CONSISTENCY 5 /* bad consistency check, abort */ -#define COMMAND 6 /* interactive error */ +#define WARNING 0 /* non-fatal error */ +#define USER 1 /* fatal user-caused error */ +#define SYSTEM 2 /* fatal system-related error */ +#define INTERNAL 3 /* fatal program-related error */ +#define CONSISTENCY 4 /* bad consistency check, abort */ +#define COMMAND 5 /* interactive error */ +#define NERRS 6 + /* error struct */ +extern struct erract { + char pre[16]; /* prefix message */ + void (*pf)(); /* put function (resettable) */ + int ec; /* exit code (0 means non-fatal) */ +} erract[NERRS]; /* list of error actions */ +#define ERRACT_INIT { {"warning - ", wputs, 0}, \ + {"fatal - ", eputs, 1}, \ + {"system - ", eputs, 2}, \ + {"internal - ", eputs, 3}, \ + {"consistency - ", eputs, -1}, \ + {"", NULL, 0} } + extern char errmsg[]; /* global buffer for error messages */ +#ifdef FASTMATH +#define tcos cos +#define tsin sin +#define ttan tan +#else +extern double tcos(); /* table-based cosine approximation */ +#define tsin(x) tcos((x)-(PI/2.)) +#define ttan(x) (tsin(x)/tcos(x)) +#endif + /* custom version of assert(3) */ +#define CHECK(be,et,em) ((be) ? error(et,em) : 0) +#ifdef DEBUG +#define DCHECK CHECK +#else +#define DCHECK(be,et,em) 0 +#endif /* memory operations */ #ifdef NOSTRUCTASS #define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) @@ -55,20 +155,15 @@ extern char errmsg[]; /* global buffer for error me #define copystruct(d,s) (*(d) = *(s)) #endif -#ifndef BSD +#ifndef BSD #define bcopy(s,d,n) (void)memcpy(d,s,n) #define bzero(d,n) (void)memset(d,0,n) #define bcmp(b1,b2,n) memcmp(b1,b2,n) -extern char *memcpy(), *memset(); #define index strchr #define rindex strrchr #endif +extern off_t lseek(); -extern char *sskip(); -extern char *getpath(), *getenv(); -extern char *malloc(), *calloc(), *realloc(); -extern char *bmalloc(), *savestr(), *savqstr(); - #ifdef MSDOS #define NIX 1 #endif @@ -76,3 +171,144 @@ extern char *bmalloc(), *savestr(), *savqstr(); #define NIX 1 #endif +#ifdef NOPROTO + +extern int badarg(); +extern char *bmalloc(); +extern void bfree(); +extern void error(); +extern int expandarg(); +extern time_t fdate(); +extern int setfdate(); +extern char *fgetline(); +extern int fgetval(); +extern char *fgetword(); +extern void fputword(); +extern char *fixargv0(); +extern FILE *frlibopen(); +extern char *getlibpath(); +extern char *getpath(); +extern void putstr(); +extern void putint(); +extern void putflt(); +extern char *getstr(); +extern long getint(); +extern double getflt(); +extern int open_process(); +extern int process(); +extern int close_process(); +extern int readbuf(); +extern int writebuf(); +extern int ecompile(); +extern char *expsave(); +extern void expset(); +extern char *eindex(); +extern char *savestr(); +extern void freestr(); +extern int shash(); +extern char *savqstr(); +extern void freeqstr(); +extern double tcos(); +extern int wordfile(); +extern int wordstring(); +extern char *atos(); +extern char *nextword(); +extern char *sskip(); +extern char *sskip2(); +extern char *iskip(); +extern char *fskip(); +extern int isint(); +extern int isintd(); +extern int isflt(); +extern int isfltd(); +extern int xf(); +extern int invxf(); +extern int fullxf(); +extern int quadtratic(); +extern void eputs(); +extern void wputs(); +extern void quit(); + +#else + /* defined in badarg.c */ +extern int badarg(int ac, char **av, char *fl); + /* defined in bmalloc.c */ +extern char *bmalloc(unsigned int n); +extern void bfree(char *p, unsigned int n); + /* defined in error.c */ +extern void error(int etype, char *emsg); + /* defined in expandarg.c */ +extern int expandarg(int *acp, char ***avp, int n); + /* defined in fdate.c */ +extern time_t fdate(char *fname); +extern int setfdate(char *fname, long ftim); + /* defined in fgetline.c */ +extern char *fgetline(char *s, int n, FILE *fp); + /* defined in fgetval.c */ +extern int fgetval(FILE *fp, int ty, char *vp); + /* defined in fgetword.c */ +extern char *fgetword(char *s, int n, FILE *fp); + /* defined in fputword.c */ +extern void fputword(char *s, FILE *fp); + /* defined in fixargv0.c */ +extern char *fixargv0(char *av0); + /* defined in fropen.c */ +extern FILE *frlibopen(char *fname); + /* defined in getlibpath.c */ +extern char *getlibpath(void); + /* defined in getpath.c */ +extern char *getpath(char *fname, char *searchpath, int mode); + /* defined in portio.c */ +extern void putstr(char *s, FILE *fp); +extern void putint(long i, int siz, FILE *fp); +extern void putflt(double f, FILE *fp); +extern char *getstr(char *s, FILE *fp); +extern long getint(int siz, FILE *fp); +extern double getflt(FILE *fp); + /* defined in process.c */ +extern int open_process(int pd[3], char *av[]); +extern int process(int pd[3], char *recvbuf, char *sendbuf, + int nbr, int nbs); +extern int close_process(int pd[3]); +extern int readbuf(int fd, char *bpos, int siz); +extern int writebuf(int fd, char *bpos, int siz); + /* defined in rexpr.c */ +extern int ecompile(char *sp, int iflg, int wflag); +extern char *expsave(); +extern void expset(char *ep); +extern char *eindex(char *sp); + /* defined in savestr.c */ +extern char *savestr(char *str); +extern void freestr(char *s); +extern int shash(char *s); + /* defined in savqstr.c */ +extern char *savqstr(char *s); +extern void freeqstr(char *s); + /* defined in tcos.c */ +extern double tcos(double x); + /* defined in wordfile.c */ +extern int wordfile(char **words, char *fname); +extern int wordstring(char **avl, char *str); + /* defined in words.c */ +extern char *atos(char *rs, int nb, char *s); +extern char *nextword(char *cp, int nb, char *s); +extern char *sskip(char *s); +extern char *sskip2(char *s, int n); +extern char *iskip(char *s); +extern char *fskip(char *s); +extern int isint(char *s); +extern int isintd(char *s, char *ds); +extern int isflt(char *s); +extern int isfltd(char *s, char *ds); + /* defined in xf.c */ +extern int xf(XF *ret, int ac, char *av[]); +extern int invxf(XF *ret, int ac, char *av[]); +extern int fullxf(FULLXF *fx, int ac, char *av[]); + /* defined in zeroes.c */ +extern int quadtratic(double *r, double a, double b, double c); + /* miscellaneous */ +extern void eputs(char *s); +extern void wputs(char *s); +extern void quit(int code); + +#endif
