--- ray/src/common/standard.h 1997/11/11 19:53:29 2.9 +++ ray/src/common/standard.h 1998/12/16 18:16:12 2.14 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ /* SCCSid "$SunId$ SGI" */ @@ -8,6 +8,8 @@ #include +#include + #include #include @@ -28,7 +30,7 @@ typedef struct { #ifndef PI #ifdef M_PI -#define PI M_PI +#define PI ((double)M_PI) #else #define PI 3.14159265358979323846 #endif @@ -41,16 +43,23 @@ typedef struct { #define F_OK 0 /* exists */ #endif +#ifndef int2 +#define int2 short /* two-byte integer */ +#endif +#ifndef int4 +#define int4 int /* four-byte integer */ +#endif + extern int eputs(), wputs(); /* standard error output functions */ /* error codes */ -#define WARNING 1 /* non-fatal error */ -#define USER 2 /* fatal user-caused error */ -#define SYSTEM 3 /* fatal system-related error */ -#define INTERNAL 4 /* fatal program-related error */ -#define CONSISTENCY 5 /* bad consistency check, abort */ -#define COMMAND 6 /* interactive error */ -#define NERRS 7 +#define WARNING 0 /* non-fatal error */ +#define USER 1 /* fatal user-caused error */ +#define SYSTEM 2 /* fatal system-related error */ +#define INTERNAL 3 /* fatal program-related error */ +#define CONSISTENCY 4 /* bad consistency check, abort */ +#define COMMAND 5 /* interactive error */ +#define NERRS 6 /* error struct */ extern struct erract { char pre[16]; /* prefix message */ @@ -67,6 +76,22 @@ extern struct erract { extern char errmsg[]; /* global buffer for error messages */ +#ifdef FASTMATH +#define tcos cos +#define tsin sin +#define ttan tan +#else +extern double tcos(); /* table-based cosine approximation */ +#define tsin(x) tcos((x)-(PI/2.)) +#define ttan(x) (tsin(x)/tcos(x)) +#endif + /* custom version of assert(3) */ +#define CHECK(be,et,em) ((be) ? error(et,em) : 0) +#ifdef DEBUG +#define DCHECK CHECK +#else +#define DCHECK(be,et,em) 0 +#endif /* memory operations */ #ifdef NOSTRUCTASS #define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) @@ -74,13 +99,17 @@ extern char errmsg[]; /* global buffer for error me #define copystruct(d,s) (*(d) = *(s)) #endif -#ifndef BSD +#ifdef BSD +extern long lseek(); +#else #define bcopy(s,d,n) (void)memcpy(d,s,n) #define bzero(d,n) (void)memset(d,0,n) #define bcmp(b1,b2,n) memcmp(b1,b2,n) #define index strchr #define rindex strrchr +extern off_t lseek(); #endif +extern long ftell(); extern char *sskip(), *sskip2(); extern char *getpath(), *getenv();
