1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: spec_rgb.c,v 2.23 2011/05/20 02:06:38 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Convert colors and spectral ranges. |
6 |
* Added von Kries white-balance calculations 10/01 (GW). |
7 |
8 |
* Externals declared in color.h |
9 |
10 |
11 |
#include "copyright.h" |
12 |
13 |
#include <stdio.h> |
14 |
#include <string.h> |
15 |
#include "color.h" |
16 |
17 |
#define CEPS 1e-4 /* color epsilon */ |
18 |
19 |
#define CEQ(v1,v2) ((v1) <= (v2)+CEPS && (v2) <= (v1)+CEPS) |
20 |
21 |
#define XYEQ(c1,c2) (CEQ((c1)[CIEX],(c2)[CIEX]) && CEQ((c1)[CIEY],(c2)[CIEY])) |
22 |
23 |
24 |
RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */ |
25 |
26 |
COLOR cblack = BLKCOLOR; /* global black color */ |
27 |
COLOR cwhite = WHTCOLOR; /* global white color */ |
28 |
29 |
float xyneu[2] = {1./3., 1./3.}; /* neutral xy chromaticities */ |
30 |
31 |
32 |
* The following table contains the CIE tristimulus integrals |
33 |
* for X, Y, and Z. The table is cumulative, so that |
34 |
* each color coordinate integrates to 1. |
35 |
36 |
37 |
#define STARTWL 380 /* starting wavelength (nanometers) */ |
38 |
#define INCWL 10 /* wavelength increment */ |
39 |
#define NINC 40 /* # of values */ |
40 |
41 |
static uby8 chroma[3][NINC] = { |
42 |
{ /* X */ |
43 |
0, 0, 0, 2, 6, 13, 22, 30, 36, 41, |
44 |
42, 43, 43, 44, 46, 52, 60, 71, 87, 106, |
45 |
128, 153, 178, 200, 219, 233, 243, 249, 252, 254, |
46 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255 |
47 |
}, { /* Y */ |
48 |
0, 0, 0, 0, 0, 1, 2, 4, 7, 11, |
49 |
17, 24, 34, 48, 64, 84, 105, 127, 148, 169, |
50 |
188, 205, 220, 232, 240, 246, 250, 253, 254, 255, |
51 |
52 |
}, { /* Z */ |
53 |
0, 0, 2, 10, 32, 66, 118, 153, 191, 220, |
54 |
237, 246, 251, 253, 254, 255, 255, 255, 255, 255, |
55 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255, |
56 |
57 |
58 |
59 |
60 |
COLORMAT xyz2rgbmat = { /* XYZ to RGB (no white balance) */ |
61 |
{(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD, |
62 |
(CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD, |
63 |
(CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD}, |
64 |
{(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD, |
65 |
(CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD, |
66 |
(CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD}, |
67 |
{(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD, |
68 |
(CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD, |
69 |
(CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD} |
70 |
71 |
72 |
COLORMAT rgb2xyzmat = { /* RGB to XYZ (no white balance) */ |
73 |
{CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D}, |
74 |
{CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D}, |
75 |
{(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D, |
76 |
(1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D, |
77 |
(1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D} |
78 |
79 |
80 |
COLORMAT vkmat = { /* Sharp primary matrix */ |
81 |
{ 1.2694, -0.0988, -0.1706}, |
82 |
{-0.8364, 1.8006, 0.0357}, |
83 |
{ 0.0297, -0.0315, 1.0018} |
84 |
85 |
86 |
COLORMAT ivkmat = { /* inverse Sharp primary matrix */ |
87 |
{ 0.8156, 0.0472, 0.1372}, |
88 |
{ 0.3791, 0.5769, 0.0440}, |
89 |
{-0.0123, 0.0167, 0.9955} |
90 |
91 |
92 |
93 |
void |
94 |
spec_rgb( /* compute RGB color from spectral range */ |
95 |
COLOR col, |
96 |
int s, |
97 |
int e |
98 |
99 |
100 |
COLOR ciecolor; |
101 |
102 |
spec_cie(ciecolor, s, e); |
103 |
cie_rgb(col, ciecolor); |
104 |
105 |
106 |
107 |
void |
108 |
spec_cie( /* compute a color from a spectral range */ |
109 |
COLOR col, /* returned color */ |
110 |
int s, /* starting and ending wavelengths */ |
111 |
int e |
112 |
113 |
114 |
register int i, d, r; |
115 |
116 |
s -= STARTWL; |
117 |
if (s < 0) |
118 |
s = 0; |
119 |
120 |
e -= STARTWL; |
121 |
if (e <= s) { |
122 |
col[CIEX] = col[CIEY] = col[CIEZ] = 0.0; |
123 |
return; |
124 |
125 |
if (e >= INCWL*(NINC - 1)) |
126 |
e = INCWL*(NINC - 1) - 1; |
127 |
128 |
d = e / INCWL; /* interpolate values */ |
129 |
r = e % INCWL; |
130 |
for (i = 0; i < 3; i++) |
131 |
col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r; |
132 |
133 |
d = s / INCWL; |
134 |
r = s % INCWL; |
135 |
136 |
col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r; |
137 |
138 |
col[CIEX] = (col[CIEX] + 0.5) * (1./(256*INCWL)); |
139 |
col[CIEY] = (col[CIEY] + 0.5) * (1./(256*INCWL)); |
140 |
col[CIEZ] = (col[CIEZ] + 0.5) * (1./(256*INCWL)); |
141 |
142 |
143 |
144 |
void |
145 |
cie_rgb( /* convert CIE color to standard RGB */ |
146 |
COLOR rgb, |
147 |
COLOR xyz |
148 |
149 |
150 |
colortrans(rgb, xyz2rgbmat, xyz); |
151 |
clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite); |
152 |
153 |
154 |
155 |
int |
156 |
clipgamut( /* clip to gamut cube */ |
157 |
COLOR col, |
158 |
double brt, |
159 |
int gamut, |
160 |
COLOR lower, |
161 |
COLOR upper |
162 |
163 |
164 |
int rflags = 0; |
165 |
double brtmin, brtmax, v, vv; |
166 |
COLOR cgry; |
167 |
register int i; |
168 |
/* check for no check */ |
169 |
if (gamut == 0) return(0); |
170 |
/* check brightness limits */ |
171 |
brtmin = 1./3.*(lower[0]+lower[1]+lower[2]); |
172 |
if (gamut & CGAMUT_LOWER && brt < brtmin) { |
173 |
copycolor(col, lower); |
174 |
return(CGAMUT_LOWER); |
175 |
176 |
brtmax = 1./3.*(upper[0]+upper[1]+upper[2]); |
177 |
if (gamut & CGAMUT_UPPER && brt > brtmax) { |
178 |
copycolor(col, upper); |
179 |
return(CGAMUT_UPPER); |
180 |
181 |
/* compute equivalent grey */ |
182 |
v = (brt - brtmin)/(brtmax - brtmin); |
183 |
184 |
cgry[i] = v*upper[i] + (1.-v)*lower[i]; |
185 |
vv = 1.; /* check each limit */ |
186 |
187 |
if (gamut & CGAMUT_LOWER && col[i] < lower[i]) { |
188 |
v = (lower[i] - cgry[i])/(col[i] - cgry[i]); |
189 |
if (v < vv) vv = v; |
190 |
rflags |= CGAMUT_LOWER; |
191 |
} else if (gamut & CGAMUT_UPPER && col[i] > upper[i]) { |
192 |
v = (upper[i] - cgry[i])/(col[i] - cgry[i]); |
193 |
194 |
rflags |= CGAMUT_UPPER; |
195 |
196 |
if (rflags) /* desaturate to cube face */ |
197 |
198 |
col[i] = vv*col[i] + (1.-vv)*cgry[i]; |
199 |
return(rflags); |
200 |
201 |
202 |
203 |
void |
204 |
colortrans( /* convert c1 by mat and put into c2 */ |
205 |
register COLOR c2, |
206 |
register COLORMAT mat, |
207 |
register COLOR c1 |
208 |
209 |
210 |
COLOR cout; |
211 |
212 |
cout[0] = mat[0][0]*c1[0] + mat[0][1]*c1[1] + mat[0][2]*c1[2]; |
213 |
cout[1] = mat[1][0]*c1[0] + mat[1][1]*c1[1] + mat[1][2]*c1[2]; |
214 |
cout[2] = mat[2][0]*c1[0] + mat[2][1]*c1[1] + mat[2][2]*c1[2]; |
215 |
216 |
copycolor(c2, cout); |
217 |
218 |
219 |
220 |
void |
221 |
multcolormat( /* multiply m1 by m2 and put into m3 */ |
222 |
COLORMAT m3, /* m3 can be either m1 or m2 w/o harm */ |
223 |
COLORMAT m2, |
224 |
COLORMAT m1 |
225 |
226 |
227 |
COLORMAT mt; |
228 |
register int i, j; |
229 |
230 |
231 |
for (j = 0; j < 3; j++) |
232 |
mt[i][j] = m1[i][0]*m2[0][j] + |
233 |
m1[i][1]*m2[1][j] + |
234 |
m1[i][2]*m2[2][j] ; |
235 |
cpcolormat(m3, mt); |
236 |
237 |
238 |
239 |
int |
240 |
colorprimsOK( /* are color primaries reasonable? */ |
241 |
RGBPRIMS pr |
242 |
243 |
244 |
int i, j; |
245 |
246 |
for (i = 0; i < 3; i++) { |
247 |
if ((pr[i][CIEX] <= -2.) | (pr[i][CIEY] <= -2.)) |
248 |
return(0); |
249 |
if ((pr[i][CIEX] >= 3.) | (pr[i][CIEY] >= 3.)) |
250 |
return(0); |
251 |
if (pr[i][CIEX] + pr[i][CIEY] <= -2.) |
252 |
return(0); |
253 |
if (pr[i][CIEX] + pr[i][CIEY] >= 3.) |
254 |
return(0); |
255 |
256 |
if ((pr[3][CIEX] <= 0.) | (pr[3][CIEX] >= 1.) | |
257 |
(pr[3][CIEY] <= 0.) | (pr[3][CIEY] >= 1.)) |
258 |
return(0); |
259 |
for (i = 0; i < 4; i++) |
260 |
for (j = i+1; j < 4; j++) |
261 |
if (CEQ(pr[i][CIEX],pr[j][CIEX]) && |
262 |
CEQ(pr[i][CIEY],pr[j][CIEY])) |
263 |
return(0); |
264 |
return(1); |
265 |
266 |
267 |
268 |
269 |
int |
270 |
compxyz2rgbmat( /* compute conversion from CIE to RGB space */ |
271 |
COLORMAT mat, |
272 |
register RGBPRIMS pr |
273 |
274 |
275 |
double C_rD, C_gD, C_bD; |
276 |
277 |
if (pr == stdprims) { /* can use xyz2rgbmat */ |
278 |
cpcolormat(mat, xyz2rgbmat); |
279 |
return(1); |
280 |
281 |
if (CEQ(pr[WHT][CIEX],0.) | CEQ(pr[WHT][CIEY],0.)) |
282 |
return(0); |
283 |
C_rD = (1./pr[WHT][CIEY]) * |
284 |
( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - |
285 |
pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + |
286 |
pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ; |
287 |
if (CEQ(C_rD,0.)) |
288 |
return(0); |
289 |
C_gD = (1./pr[WHT][CIEY]) * |
290 |
( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) - |
291 |
pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) - |
292 |
pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ; |
293 |
if (CEQ(C_gD,0.)) |
294 |
return(0); |
295 |
C_bD = (1./pr[WHT][CIEY]) * |
296 |
( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) - |
297 |
pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) + |
298 |
pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ; |
299 |
if (CEQ(C_bD,0.)) |
300 |
return(0); |
301 |
mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] - |
302 |
pr[BLU][CIEX]*pr[GRN][CIEY] + |
303 |
pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ; |
304 |
mat[0][1] = (pr[BLU][CIEX] - pr[GRN][CIEX] - |
305 |
306 |
pr[GRN][CIEX]*pr[BLU][CIEY])/C_rD ; |
307 |
mat[0][2] = (pr[GRN][CIEX]*pr[BLU][CIEY] - |
308 |
pr[BLU][CIEX]*pr[GRN][CIEY])/C_rD ; |
309 |
mat[1][0] = (pr[BLU][CIEY] - pr[RED][CIEY] - |
310 |
pr[BLU][CIEY]*pr[RED][CIEX] + |
311 |
pr[RED][CIEY]*pr[BLU][CIEX])/C_gD ; |
312 |
mat[1][1] = (pr[RED][CIEX] - pr[BLU][CIEX] - |
313 |
pr[RED][CIEX]*pr[BLU][CIEY] + |
314 |
pr[BLU][CIEX]*pr[RED][CIEY])/C_gD ; |
315 |
mat[1][2] = (pr[BLU][CIEX]*pr[RED][CIEY] - |
316 |
pr[RED][CIEX]*pr[BLU][CIEY])/C_gD ; |
317 |
mat[2][0] = (pr[RED][CIEY] - pr[GRN][CIEY] - |
318 |
pr[RED][CIEY]*pr[GRN][CIEX] + |
319 |
pr[GRN][CIEY]*pr[RED][CIEX])/C_bD ; |
320 |
mat[2][1] = (pr[GRN][CIEX] - pr[RED][CIEX] - |
321 |
pr[GRN][CIEX]*pr[RED][CIEY] + |
322 |
pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ; |
323 |
mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] - |
324 |
pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ; |
325 |
return(1); |
326 |
327 |
328 |
329 |
int |
330 |
comprgb2xyzmat( /* compute conversion from RGB to CIE space */ |
331 |
COLORMAT mat, |
332 |
333 |
334 |
335 |
double C_rD, C_gD, C_bD, D; |
336 |
337 |
if (pr == stdprims) { /* can use rgb2xyzmat */ |
338 |
cpcolormat(mat, rgb2xyzmat); |
339 |
return(1); |
340 |
341 |
342 |
return(0); |
343 |
344 |
345 |
346 |
347 |
348 |
349 |
350 |
351 |
352 |
353 |
354 |
355 |
D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) + |
356 |
pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) + |
357 |
pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ; |
358 |
if (CEQ(D,0.)) |
359 |
return(0); |
360 |
mat[0][0] = pr[RED][CIEX]*C_rD/D; |
361 |
mat[0][1] = pr[GRN][CIEX]*C_gD/D; |
362 |
mat[0][2] = pr[BLU][CIEX]*C_bD/D; |
363 |
mat[1][0] = pr[RED][CIEY]*C_rD/D; |
364 |
mat[1][1] = pr[GRN][CIEY]*C_gD/D; |
365 |
mat[1][2] = pr[BLU][CIEY]*C_bD/D; |
366 |
mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D; |
367 |
mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D; |
368 |
mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D; |
369 |
return(1); |
370 |
371 |
372 |
373 |
int |
374 |
comprgb2rgbmat( /* compute conversion from RGB1 to RGB2 */ |
375 |
COLORMAT mat, |
376 |
RGBPRIMS pr1, |
377 |
RGBPRIMS pr2 |
378 |
379 |
380 |
COLORMAT pr1toxyz, xyztopr2; |
381 |
382 |
if (pr1 == pr2) { |
383 |
mat[0][0] = mat[1][1] = mat[2][2] = 1.0; |
384 |
mat[0][1] = mat[0][2] = mat[1][0] = |
385 |
mat[1][2] = mat[2][0] = mat[2][1] = 0.0; |
386 |
return(1); |
387 |
388 |
if (!comprgb2xyzmat(pr1toxyz, pr1)) |
389 |
return(0); |
390 |
if (!compxyz2rgbmat(xyztopr2, pr2)) |
391 |
return(0); |
392 |
/* combine transforms */ |
393 |
multcolormat(mat, pr1toxyz, xyztopr2); |
394 |
return(1); |
395 |
396 |
397 |
398 |
int |
399 |
compxyzWBmat( /* CIE von Kries transform from wht1 to wht2 */ |
400 |
COLORMAT mat, |
401 |
float wht1[2], |
402 |
float wht2[2] |
403 |
404 |
405 |
COLOR cw1, cw2; |
406 |
if (XYEQ(wht1,wht2)) { |
407 |
408 |
409 |
410 |
return(1); |
411 |
412 |
if (CEQ(wht1[CIEX],0.) | CEQ(wht1[CIEY],0.)) |
413 |
return(0); |
414 |
cw1[RED] = wht1[CIEX]/wht1[CIEY]; |
415 |
cw1[GRN] = 1.; |
416 |
cw1[BLU] = (1. - wht1[CIEX] - wht1[CIEY])/wht1[CIEY]; |
417 |
colortrans(cw1, vkmat, cw1); |
418 |
if (CEQ(wht2[CIEX],0.) | CEQ(wht2[CIEY],0.)) |
419 |
return(0); |
420 |
cw2[RED] = wht2[CIEX]/wht2[CIEY]; |
421 |
cw2[GRN] = 1.; |
422 |
cw2[BLU] = (1. - wht2[CIEX] - wht2[CIEY])/wht2[CIEY]; |
423 |
colortrans(cw2, vkmat, cw2); |
424 |
if (CEQ(cw1[RED],0.) | CEQ(cw1[GRN],0.) | CEQ(cw1[BLU],0.)) |
425 |
return(0); |
426 |
mat[0][0] = cw2[RED]/cw1[RED]; |
427 |
mat[1][1] = cw2[GRN]/cw1[GRN]; |
428 |
mat[2][2] = cw2[BLU]/cw1[BLU]; |
429 |
430 |
431 |
multcolormat(mat, vkmat, mat); |
432 |
multcolormat(mat, mat, ivkmat); |
433 |
return(1); |
434 |
435 |
436 |
437 |
int |
438 |
compxyz2rgbWBmat( /* von Kries conversion from CIE to RGB space */ |
439 |
COLORMAT mat, |
440 |
RGBPRIMS pr |
441 |
442 |
443 |
COLORMAT wbmat; |
444 |
445 |
if (!compxyz2rgbmat(mat, pr)) |
446 |
return(0); |
447 |
if (XYEQ(pr[WHT],xyneu)) |
448 |
return(1); |
449 |
if (!compxyzWBmat(wbmat, xyneu, pr[WHT])) |
450 |
return(0); |
451 |
multcolormat(mat, wbmat, mat); |
452 |
return(1); |
453 |
454 |
455 |
int |
456 |
comprgb2xyzWBmat( /* von Kries conversion from RGB to CIE space */ |
457 |
COLORMAT mat, |
458 |
RGBPRIMS pr |
459 |
460 |
461 |
COLORMAT wbmat; |
462 |
463 |
if (!comprgb2xyzmat(mat, pr)) |
464 |
return(0); |
465 |
466 |
return(1); |
467 |
if (!compxyzWBmat(wbmat, pr[WHT], xyneu)) |
468 |
return(0); |
469 |
multcolormat(mat, mat, wbmat); |
470 |
return(1); |
471 |
472 |
473 |
int |
474 |
comprgb2rgbWBmat( /* von Kries conversion from RGB1 to RGB2 */ |
475 |
COLORMAT mat, |
476 |
RGBPRIMS pr1, |
477 |
RGBPRIMS pr2 |
478 |
479 |
480 |
COLORMAT pr1toxyz, xyztopr2, wbmat; |
481 |
482 |
if (pr1 == pr2) { |
483 |
484 |
485 |
486 |
return(1); |
487 |
488 |
489 |
return(0); |
490 |
if (!compxyzWBmat(wbmat, pr1[WHT], pr2[WHT])) |
491 |
return(0); |
492 |
493 |
return(0); |
494 |
495 |
multcolormat(mat, pr1toxyz, wbmat); |
496 |
multcolormat(mat, mat, xyztopr2); |
497 |
return(1); |
498 |
