root/radiance/ray/src/common/spec_rgb.c
Revision: 2.9
Committed: Thu Apr 17 15:42:02 1997 UTC (27 years ago) by greg
Changes since 2.8: +7 -3 lines
fixed bug in colortrans() introduced in last change
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert colors and spectral ranges.
9 */
10
11 #include "color.h"
12
13
14 RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */
15
16 COLOR cblack = BLKCOLOR; /* global black color */
17 COLOR cwhite = WHTCOLOR; /* global white color */
18
19 /*
20 * The following table contains the CIE tristimulus integrals
21 * for X, Y, and Z. The table is cumulative, so that
22 * each color coordinate integrates to 1.
23 */
24
25 #define STARTWL 380 /* starting wavelength (nanometers) */
26 #define INCWL 10 /* wavelength increment */
27 #define NINC 40 /* # of values */
28
29 static BYTE chroma[3][NINC] = {
30 { /* X */
31 0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
32 42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
33 128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
34 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
35 }, { /* Y */
36 0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
37 17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
38 188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
39 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
40 }, { /* Z */
41 0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
42 237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
43 255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
44 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
45 }
46 };
47
48 COLORMAT xyz2rgbmat = { /* XYZ to RGB */
49 {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
50 (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
51 (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD},
52 {(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
53 (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
54 (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD},
55 {(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
56 (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
57 (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD}
58 };
59
60 COLORMAT rgb2xyzmat = { /* RGB to XYZ */
61 {CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D},
62 {CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D},
63 {(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
64 (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
65 (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D}
66 };
67
68
69
70 spec_rgb(col, s, e) /* compute RGB color from spectral range */
71 COLOR col;
72 int s, e;
73 {
74 COLOR ciecolor;
75
76 spec_cie(ciecolor, s, e);
77 cie_rgb(col, ciecolor);
78 }
79
80
81 spec_cie(col, s, e) /* compute a color from a spectral range */
82 COLOR col; /* returned color */
83 int s, e; /* starting and ending wavelengths */
84 {
85 register int i, d, r;
86
87 s -= STARTWL;
88 if (s < 0)
89 s = 0;
90
91 e -= STARTWL;
92 if (e <= s) {
93 col[CIEX] = col[CIEY] = col[CIEZ] = 0.0;
94 return;
95 }
96 if (e >= INCWL*(NINC - 1))
97 e = INCWL*(NINC - 1) - 1;
98
99 d = e / INCWL; /* interpolate values */
100 r = e % INCWL;
101 for (i = 0; i < 3; i++)
102 col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
103
104 d = s / INCWL;
105 r = s % INCWL;
106 for (i = 0; i < 3; i++)
107 col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
108
109 col[CIEX] = (col[CIEX] + 0.5) * (1./(256*INCWL));
110 col[CIEY] = (col[CIEY] + 0.5) * (1./(256*INCWL));
111 col[CIEZ] = (col[CIEZ] + 0.5) * (1./(256*INCWL));
112 }
113
114
115 cie_rgb(rgb, xyz) /* convert CIE color to standard RGB */
116 COLOR rgb, xyz;
117 {
118 colortrans(rgb, xyz2rgbmat, xyz);
119 clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite);
120 }
121
122
123 int
124 clipgamut(col, brt, gamut, lower, upper) /* clip to gamut cube */
125 COLOR col;
126 double brt;
127 int gamut;
128 COLOR lower, upper;
129 {
130 int rflags = 0;
131 double brtmin, brtmax, v, vv;
132 COLOR cgry;
133 register int i;
134 /* check for no check */
135 if (gamut == 0) return(0);
136 /* check brightness limits */
137 brtmin = 1./3.*(lower[0]+lower[1]+lower[2]);
138 if (gamut & CGAMUT_LOWER && brt < brtmin) {
139 copycolor(col, lower);
140 return(CGAMUT_LOWER);
141 }
142 brtmax = 1./3.*(upper[0]+upper[1]+upper[2]);
143 if (gamut & CGAMUT_UPPER && brt > brtmax) {
144 copycolor(col, upper);
145 return(CGAMUT_UPPER);
146 }
147 /* compute equivalent grey */
148 v = (brt - brtmin)/(brtmax - brtmin);
149 for (i = 0; i < 3; i++)
150 cgry[i] = v*upper[i] + (1.-v)*lower[i];
151 vv = 1.; /* check each limit */
152 for (i = 0; i < 3; i++)
153 if (gamut & CGAMUT_LOWER && col[i] < lower[i]) {
154 v = (lower[i] - cgry[i])/(col[i] - cgry[i]);
155 if (v < vv) vv = v;
156 rflags |= CGAMUT_LOWER;
157 } else if (gamut & CGAMUT_UPPER && col[i] > upper[i]) {
158 v = (upper[i] - cgry[i])/(col[i] - cgry[i]);
159 if (v < vv) vv = v;
160 rflags |= CGAMUT_UPPER;
161 }
162 if (rflags) /* desaturate to cube face */
163 for (i = 0; i < 3; i++)
164 col[i] = vv*col[i] + (1.-vv)*cgry[i];
165 return(rflags);
166 }
167
168
169 colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */
170 register COLORMAT mat;
171 register COLOR c1, c2;
172 {
173 COLOR cout;
174
175 cout[0] = mat[0][0]*c1[0] + mat[0][1]*c1[1] + mat[0][2]*c1[2];
176 cout[1] = mat[1][0]*c1[0] + mat[1][1]*c1[1] + mat[1][2]*c1[2];
177 cout[2] = mat[2][0]*c1[0] + mat[2][1]*c1[1] + mat[2][2]*c1[2];
178
179 copycolor(c2, cout);
180 }
181
182
183 multcolormat(m3, m2, m1) /* multiply m1 by m2 and put into m3 */
184 COLORMAT m1, m2, m3; /* m3 can be either m1 or m2 w/o harm */
185 {
186 COLORMAT mt;
187 register int i, j;
188
189 for (i = 0; i < 3; i++)
190 for (j = 0; j < 3; j++)
191 mt[i][j] = m1[i][0]*m2[0][j] +
192 m1[i][1]*m2[1][j] +
193 m1[i][2]*m2[2][j] ;
194 cpcolormat(m3, mt);
195 }
196
197
198 compxyz2rgbmat(mat, pr) /* compute conversion from CIE to RGB space */
199 COLORMAT mat;
200 register RGBPRIMS pr;
201 {
202 double C_rD, C_gD, C_bD;
203
204 if (pr == stdprims) { /* can use xyz2rgbmat */
205 cpcolormat(mat, xyz2rgbmat);
206 return;
207 }
208 C_rD = (1./pr[WHT][CIEY]) *
209 ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
210 pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
211 pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
212 C_gD = (1./pr[WHT][CIEY]) *
213 ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
214 pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
215 pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
216 C_bD = (1./pr[WHT][CIEY]) *
217 ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
218 pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
219 pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
220
221 mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] -
222 pr[BLU][CIEX]*pr[GRN][CIEY] +
223 pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ;
224 mat[0][1] = (pr[BLU][CIEX] - pr[GRN][CIEX] -
225 pr[BLU][CIEX]*pr[GRN][CIEY] +
226 pr[GRN][CIEX]*pr[BLU][CIEY])/C_rD ;
227 mat[0][2] = (pr[GRN][CIEX]*pr[BLU][CIEY] -
228 pr[BLU][CIEX]*pr[GRN][CIEY])/C_rD ;
229 mat[1][0] = (pr[BLU][CIEY] - pr[RED][CIEY] -
230 pr[BLU][CIEY]*pr[RED][CIEX] +
231 pr[RED][CIEY]*pr[BLU][CIEX])/C_gD ;
232 mat[1][1] = (pr[RED][CIEX] - pr[BLU][CIEX] -
233 pr[RED][CIEX]*pr[BLU][CIEY] +
234 pr[BLU][CIEX]*pr[RED][CIEY])/C_gD ;
235 mat[1][2] = (pr[BLU][CIEX]*pr[RED][CIEY] -
236 pr[RED][CIEX]*pr[BLU][CIEY])/C_gD ;
237 mat[2][0] = (pr[RED][CIEY] - pr[GRN][CIEY] -
238 pr[RED][CIEY]*pr[GRN][CIEX] +
239 pr[GRN][CIEY]*pr[RED][CIEX])/C_bD ;
240 mat[2][1] = (pr[GRN][CIEX] - pr[RED][CIEX] -
241 pr[GRN][CIEX]*pr[RED][CIEY] +
242 pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ;
243 mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] -
244 pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ;
245 }
246
247
248 comprgb2xyzmat(mat, pr) /* compute conversion from RGB to CIE space */
249 COLORMAT mat;
250 register RGBPRIMS pr;
251 {
252 double C_rD, C_gD, C_bD, D;
253
254 if (pr == stdprims) { /* can use rgb2xyzmat */
255 cpcolormat(mat, rgb2xyzmat);
256 return;
257 }
258 C_rD = (1./pr[WHT][CIEY]) *
259 ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
260 pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
261 pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
262 C_gD = (1./pr[WHT][CIEY]) *
263 ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
264 pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
265 pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
266 C_bD = (1./pr[WHT][CIEY]) *
267 ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
268 pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
269 pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
270 D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) +
271 pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) +
272 pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ;
273 mat[0][0] = pr[RED][CIEX]*C_rD/D;
274 mat[0][1] = pr[GRN][CIEX]*C_gD/D;
275 mat[0][2] = pr[BLU][CIEX]*C_bD/D;
276 mat[1][0] = pr[RED][CIEY]*C_rD/D;
277 mat[1][1] = pr[GRN][CIEY]*C_gD/D;
278 mat[1][2] = pr[BLU][CIEY]*C_bD/D;
279 mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D;
280 mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D;
281 mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D;
282 }
283
284
285 comprgb2rgbmat(mat, pr1, pr2) /* compute conversion from RGB1 to RGB2 */
286 COLORMAT mat;
287 RGBPRIMS pr1, pr2;
288 {
289 COLORMAT pr1toxyz, xyztopr2;
290
291 if (pr1 == pr2) {
292 mat[0][0] = mat[1][1] = mat[2][2] = 1.0;
293 mat[0][1] = mat[0][2] = mat[1][0] =
294 mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
295 return;
296 }
297 comprgb2xyzmat(pr1toxyz, pr1);
298 compxyz2rgbmat(xyztopr2, pr2);
299 /* combine transforms */
300 multcolormat(mat, pr1toxyz, xyztopr2);
301 }
