1 |
/* Copyright (c) 1990 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Convert colors and spectral ranges. |
9 |
10 |
11 |
#include "color.h" |
12 |
13 |
14 |
* The following table contains the CIE tristimulus integrals |
15 |
* for X, Y, and Z. The table is cumulative, so that |
16 |
* each color coordinate integrates to 1. |
17 |
18 |
19 |
#define STARTWL 380 /* starting wavelength (nanometers) */ |
20 |
#define INCWL 10 /* wavelength increment */ |
21 |
#define NINC 40 /* # of values */ |
22 |
23 |
static BYTE chroma[3][NINC] = { |
24 |
{ /* X */ |
25 |
0, 0, 0, 2, 6, 13, 22, 30, 36, 41, |
26 |
42, 43, 43, 44, 46, 52, 60, 71, 87, 106, |
27 |
128, 153, 178, 200, 219, 233, 243, 249, 252, 254, |
28 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255 |
29 |
}, { /* Y */ |
30 |
0, 0, 0, 0, 0, 1, 2, 4, 7, 11, |
31 |
17, 24, 34, 48, 64, 84, 105, 127, 148, 169, |
32 |
188, 205, 220, 232, 240, 246, 250, 253, 254, 255, |
33 |
34 |
}, { /* Z */ |
35 |
0, 0, 2, 10, 32, 66, 118, 153, 191, 220, |
36 |
237, 246, 251, 253, 254, 255, 255, 255, 255, 255, |
37 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255, |
38 |
39 |
40 |
41 |
42 |
static float xyz2rgbmat[3][3] = { /* XYZ to RGB */ |
43 |
{(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD, |
44 |
(CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD, |
45 |
(CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD}, |
46 |
{(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD, |
47 |
(CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD, |
48 |
(CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD}, |
49 |
{(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD, |
50 |
(CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD, |
51 |
(CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD} |
52 |
53 |
54 |
static float rgb2xyzmat[3][3] = { /* RGB to XYZ */ |
55 |
{CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D}, |
56 |
{CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D}, |
57 |
{(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D, |
58 |
(1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D, |
59 |
(1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D} |
60 |
61 |
62 |
63 |
64 |
spec_rgb(col, s, e) /* compute RGB color from spectral range */ |
65 |
COLOR col; |
66 |
int s, e; |
67 |
68 |
COLOR ciecolor; |
69 |
70 |
spec_cie(ciecolor, s, e); |
71 |
cie_rgb(col, ciecolor); |
72 |
73 |
74 |
75 |
spec_cie(col, s, e) /* compute a color from a spectral range */ |
76 |
COLOR col; /* returned color */ |
77 |
int s, e; /* starting and ending wavelengths */ |
78 |
79 |
register int i, d, r; |
80 |
81 |
s -= STARTWL; |
82 |
if (s < 0) |
83 |
s = 0; |
84 |
85 |
e -= STARTWL; |
86 |
if (e <= s) { |
87 |
col[RED] = col[GRN] = col[BLU] = 0.0; |
88 |
return; |
89 |
90 |
if (e >= INCWL*(NINC - 1)) |
91 |
e = INCWL*(NINC - 1) - 1; |
92 |
93 |
d = e / INCWL; /* interpolate values */ |
94 |
r = e % INCWL; |
95 |
for (i = 0; i < 3; i++) |
96 |
col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r; |
97 |
98 |
d = s / INCWL; |
99 |
r = s % INCWL; |
100 |
101 |
col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r; |
102 |
103 |
col[RED] = (col[RED] + 0.5) / (256*INCWL); |
104 |
col[GRN] = (col[GRN] + 0.5) / (256*INCWL); |
105 |
col[BLU] = (col[BLU] + 0.5) / (256*INCWL); |
106 |
107 |
108 |
109 |
cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB */ |
110 |
register COLOR rgbcolor, ciecolor; |
111 |
112 |
register int i; |
113 |
114 |
for (i = 0; i < 3; i++) { |
115 |
rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] + |
116 |
xyz2rgbmat[i][1]*ciecolor[1] + |
117 |
xyz2rgbmat[i][2]*ciecolor[2] ; |
118 |
if (rgbcolor[i] < 0.0) |
119 |
rgbcolor[i] = 0.0; |
120 |
121 |
122 |
123 |
124 |
rgb_cie(ciecolor, rgbcolor) /* convert RGB to CIE */ |
125 |
register COLOR ciecolor, rgbcolor; |
126 |
127 |
register int i; |
128 |
129 |
130 |
ciecolor[i] = rgb2xyzmat[i][0]*rgbcolor[0] + |
131 |
rgb2xyzmat[i][1]*rgbcolor[1] + |
132 |
rgb2xyzmat[i][2]*rgbcolor[2] ; |
133 |
