--- ray/src/common/spec_rgb.c 2003/02/25 02:47:22 2.12 +++ ray/src/common/spec_rgb.c 2024/08/14 20:05:23 2.34 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: spec_rgb.c,v 2.12 2003/02/25 02:47:22 greg Exp $"; +static const char RCSid[] = "$Id: spec_rgb.c,v 2.34 2024/08/14 20:05:23 greg Exp $"; #endif /* * Convert colors and spectral ranges. @@ -10,17 +10,20 @@ static const char RCSid[] = "$Id: spec_rgb.c,v 2.12 20 #include "copyright.h" -#include "color.h" +#include #include +#include +#include "color.h" #define CEPS 1e-4 /* color epsilon */ -#define CEQ(v1,v2) ((v1) <= (v2)+CEPS && (v2) <= (v1)+CEPS) +#define CEQ(v1,v2) (((v1) <= (v2)+CEPS) & ((v2) <= (v1)+CEPS)) -#define XYEQ(c1,c2) (CEQ((c1)[CIEX],(c2)[CIEX]) && CEQ((c1)[CIEY],(c2)[CIEY])) +#define XYEQ(c1,c2) (CEQ((c1)[CIEX],(c2)[CIEX]) & CEQ((c1)[CIEY],(c2)[CIEY])) RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */ +RGBPRIMS xyzprims = {1,0, 0,1, 0,0, 1.f/3.f,1.f/3.f}; COLOR cblack = BLKCOLOR; /* global black color */ COLOR cwhite = WHTCOLOR; /* global white color */ @@ -28,34 +31,174 @@ COLOR cwhite = WHTCOLOR; /* global white color */ float xyneu[2] = {1./3., 1./3.}; /* neutral xy chromaticities */ /* - * The following table contains the CIE tristimulus integrals - * for X, Y, and Z. The table is cumulative, so that - * each color coordinate integrates to 1. + * The tables below encode the CIE 1931 2° standard observer + * functions for X, Y, and Z. These tables are cumulative, as are + * ones that follow. */ -#define STARTWL 380 /* starting wavelength (nanometers) */ -#define INCWL 10 /* wavelength increment */ -#define NINC 40 /* # of values */ +#define CIE_X_WLMIN 362 +#define CIE_X_WLMAX 774 -static BYTE chroma[3][NINC] = { - { /* X */ - 0, 0, 0, 2, 6, 13, 22, 30, 36, 41, - 42, 43, 43, 44, 46, 52, 60, 71, 87, 106, - 128, 153, 178, 200, 219, 233, 243, 249, 252, 254, - 255, 255, 255, 255, 255, 255, 255, 255, 255, 255 - }, { /* Y */ - 0, 0, 0, 0, 0, 1, 2, 4, 7, 11, - 17, 24, 34, 48, 64, 84, 105, 127, 148, 169, - 188, 205, 220, 232, 240, 246, 250, 253, 254, 255, - 255, 255, 255, 255, 255, 255, 255, 255, 255, 255 - }, { /* Z */ - 0, 0, 2, 10, 32, 66, 118, 153, 191, 220, - 237, 246, 251, 253, 254, 255, 255, 255, 255, 255, - 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, - 255, 255, 255, 255, 255, 255, 255, 255, 255, 255 - } +static const unsigned short cie_x_cumul[CIE_X_WLMAX-CIE_X_WLMIN+1] = { +0,1,1,1,1,1,1,2,2,2,3,3,3,4,5,5,6,7,8,9,10,11,12,14,16,18,20,23,26,29, +33,37,41,47,53,60,68,77,86,97,108,121,135,151,170,190,214,241,271,304, +342,385,432,486,545,612,686,768,860,961,1073,1195,1326,1467,1618, +1776,1943,2117,2298,2485,2677,2875,3076,3281,3489,3700,3912,4125,4340,4555, +4769,4983,5197,5409,5620,5830,6038,6244,6448,6651,6851,7049,7245,7437, +7627,7813,7995,8173,8347,8517,8682,8842,8996,9143,9284,9418,9545,9665, +9778,9884,9984,10077,10164,10245,10321,10390,10454,10513,10566,10615, +10659,10698,10734,10766,10794,10819,10842,10861,10879,10893,10906,10917, +10926,10933,10939,10944,10948,10951,10953,10955,10957,10958,10960,10961, +10964,10967,10971,10977,10984,10994,11006,11020,11038,11060,11085,11114, +11148,11187,11231,11280,11335,11396,11464,11537,11618,11705,11799,11901, +12010,12126,12249,12380,12518,12664,12818,12980,13150,13328,13515,13709, +13913,14124,14345,14574,14813,15060,15317,15582,15858,16142,16437,16741, +17055,17379,17713,18057,18412,18776,19151,19536,19931,20337,20753,21180, +21616,22063,22520,22988,23465,23953,24450,24957,25474,26000,26535,27080, +27633,28195,28765,29343,29929,30522,31122,31729,32342,32961,33585,34215, +34849,35487,36129,36775,37423,38073,38724,39375,40027,40679,41329,41978, +42625,43270,43911,44548,45181,45808,46429,47044,47652,48253,48845,49430, +50005,50571,51128,51674,52209,52733,53245,53745,54232,54706,55167,55614, +56048,56468,56876,57269,57651,58019,58376,58720,59052,59373,59681,59979, +60265,60539,60803,61056,61298,61529,61750,61962,62163,62355,62538,62712, +62877,63034,63183,63325,63459,63586,63706,63820,63927,64028,64123,64213, +64297,64376,64451,64520,64586,64647,64704,64758,64808,64855,64899,64941, +64980,65016,65051,65083,65114,65143,65169,65194,65218,65240,65260,65278, +65296,65312,65327,65341,65354,65366,65377,65387,65397,65406,65415,65423, +65430,65437,65444,65450,65455,65461,65466,65470,65475,65479,65483,65486, +65489,65493,65495,65498,65501,65503,65505,65507,65509,65511,65513,65514, +65516,65517,65518,65519,65520,65521,65522,65523,65524,65525,65526,65526, +65527,65527,65528,65528,65529,65529,65530,65530,65530,65531,65531,65531, +65532,65532,65532,65532,65532,65533,65533,65533,65533,65533,65533,65533, +65533,65534,65534,65534,65534,65534,65534,65534,65534,65534,65534,65534, +65534,65534,65534,65534,65535 }; +#define CIE_Y_WLMIN 386 +#define CIE_Y_WLMAX 760 + +static const unsigned short cie_y_cumul[CIE_Y_WLMAX-CIE_Y_WLMIN+1] = { +0,1,1,1,1,1,1,1,1,1,2,2,2,2,2,3,3,3,4,4,5,5,6,7,8,8,10,11,12,14, +15,17,19,22,25,28,31,35,40,45,50,56,63,70,78,86,95,105,115,126, +138,150,164,178,193,208,225,242,260,280,300,321,343,367,391, +417,443,472,501,532,564,598,633,670,708,748,790,833,879,926, +975,1027,1080,1136,1194,1255,1318,1384,1453,1525,1601,1679,1761, +1846,1935,2027,2123,2223,2327,2435,2548,2665,2787,2915,3048,3187, +3332,3484,3643,3808,3981,4162,4352,4550,4757,4975,5203,5442,5691, +5952,6225,6509,6805,7114,7435,7769,8116,8476,8849,9235,9634,10045, +10469,10904,11351,11808,12275,12752,13239,13734,14239,14752,15273, +15801,16337,16880,17429,17984,18546,19112,19684,20260,20841,21426, +22015,22608,23203,23802,24403,25007,25612,26220,26828,27439,28050, +28662,29275,29888,30501,31114,31727,32340,32951,33561,34170,34777, +35382,35985,36585,37182,37777,38368,38955,39539,40119,40695,41266, +41832,42393,42950,43501,44046,44586,45119,45646,46167,46682,47189, +47690,48183,48670,49149,49621,50085,50542,50991,51432,51866,52293, +52711,53122,53524,53919,54306,54685,55057,55420,55775,56123,56463, +56795,57119,57435,57743,58044,58337,58623,58901,59172,59435,59691, +59939,60180,60414,60640,60859,61070,61274,61471,61661,61844,62019, +62188,62351,62507,62657,62802,62940,63073,63201,63323,63441,63553, +63660,63763,63861,63954,64043,64128,64208,64285,64358,64427,64493, +64555,64614,64670,64723,64773,64820,64865,64907,64947,64984,65019, +65052,65083,65113,65140,65166,65190,65212,65233,65253,65271,65288, +65304,65319,65334,65347,65360,65371,65383,65393,65403,65412,65420, +65428,65435,65442,65449,65454,65460,65465,65470,65474,65478,65482, +65485,65488,65492,65494,65497,65500,65502,65504,65506,65508,65510, +65512,65513,65515,65516,65517,65519,65520,65521,65522,65523,65523, +65524,65525,65526,65526,65527,65527,65528,65528,65529,65529,65530, +65530,65530,65531,65531,65531,65532,65532,65532,65532,65532,65533, +65533,65533,65533,65533,65533,65533,65534,65534,65534,65534,65534, +65534,65534,65534,65534,65534,65534,65534,65534,65534,65534,65534,65535 +}; + +#define CIE_Z_WLMIN 359 +#define CIE_Z_WLMAX 624 + +static const unsigned short cie_z_cumul[CIE_Z_WLMAX-CIE_Z_WLMIN+1] = { +0,1,1,2,2,3,4,5,6,7,8,9,11,12,14,16,19,22,25,28,32,37,41,47,52,59,66,75,84, +95,107,121,136,154,173,196,221,250,283,321,362,408,458,512,573,640,717,804, +903,1015,1142,1285,1446,1627,1830,2058,2313,2598,2917,3272,3668,4108,4597, +5135,5723,6360,7044,7773,8544,9356,10205,11090,12006,12952,13923,14918, +15934,16967,18016,19076,20148,21227,22312,23401,24492,25585,26678,27771, +28861,29950,31037,32121,33202,34281,35355,36424,37487,38542,39588,40624, +41647,42657,43652,44631,45590,46527,47438,48321,49173,49993,50783,51542, +52270,52968,53636,54275,54885,55465,56018,56543,57042,57514,57961,58384, +58784,59162,59519,59856,60175,60477,60762,61032,61287,61529,61757,61974, +62179,62374,62559,62734,62901,63059,63211,63355,63492,63622,63745,63862, +63971,64075,64172,64263,64347,64427,64500,64569,64632,64692,64747,64798, +64846,64891,64933,64973,65010,65045,65078,65109,65139,65166,65192,65216, +65239,65260,65280,65298,65315,65331,65345,65359,65371,65383,65393,65403, +65412,65420,65428,65435,65441,65447,65452,65457,65462,65466,65470,65473, +65476,65479,65482,65485,65487,65489,65491,65493,65495,65497,65498,65500, +65501,65503,65504,65505,65506,65508,65509,65510,65511,65512,65513,65514, +65515,65516,65517,65518,65519,65520,65520,65521,65522,65523,65523,65524, +65525,65525,65526,65527,65527,65528,65528,65529,65529,65530,65530,65531, +65531,65531,65532,65532,65532,65532,65533,65533,65533,65533,65533,65533, +65534,65534,65534,65534,65534,65534,65534,65534,65534,65535 +}; + +#define SCOTOPIC_WLMIN 382 +#define SCOTOPIC_WLMAX 684 + +static const unsigned short scotopic_cumul[SCOTOPIC_WLMAX-SCOTOPIC_WLMIN+1] = { +0, 1, 1, 2, 3, 4, 5, 6, 7, 9, 10, 12, 15, 17, 20, 24, 28, 33, 38, 44, +52, 60, 69, 80, 93, 107, 123, 142, 163, 186, 213, 242, 275, 312, 353, +398, 448, 502, 562, 627, 698, 775, 859, 949, 1046, 1150, 1261, 1380, +1507, 1642, 1785, 1936, 2096, 2265, 2442, 2628, 2823, 3027, 3239, 3461, +3691, 3930, 4178, 4435, 4700, 4974, 5257, 5548, 5847, 6154, 6469, 6793, +7123, 7462, 7809, 8162, 8524, 8892, 9268, 9651, 10041, 10438, 10843, 11254, +11673, 12099, 12532, 12973, 13422, 13878, 14342, 14814, 15293, 15780, 16276, +16779, 17290, 17809, 18336, 18872, 19415, 19967, 20526, 21093, 21667, 22249, +22839, 23436, 24039, 24649, 25266, 25890, 26519, 27154, 27795, 28441, 29092, +29747, 30405, 31068, 31734, 32402, 33074, 33747, 34420, 35095, 35771, 36446, +37119, 37793, 38464, 39132, 39798, 40460, 41118, 41772, 42421, 43064, 43701, +44332, 44957, 45575, 46185, 46787, 47381, 47967, 48543, 49110, 49668, 50215, +50753, 51280, 51797, 52302, 52797, 53281, 53754, 54215, 54665, 55104, 55531, +55947, 56352, 56744, 57125, 57495, 57853, 58200, 58536, 58860, 59174, 59477, +59769, 60051, 60322, 60583, 60834, 61075, 61306, 61528, 61741, 61944, 62139, +62326, 62504, 62674, 62836, 62991, 63138, 63278, 63412, 63538, 63659, 63773, +63881, 63983, 64080, 64172, 64259, 64340, 64418, 64490, 64559, 64623, 64684, +64742, 64795, 64846, 64893, 64937, 64978, 65017, 65053, 65087, 65119, 65149, +65176, 65202, 65226, 65248, 65269, 65289, 65307, 65323, 65339, 65353, 65367, +65379, 65391, 65402, 65412, 65421, 65430, 65438, 65445, 65452, 65458, 65464, +65469, 65474, 65479, 65483, 65487, 65491, 65494, 65497, 65500, 65503, 65505, +65507, 65509, 65511, 65513, 65514, 65516, 65517, 65519, 65520, 65521, 65522, +65523, 65524, 65525, 65525, 65526, 65527, 65527, 65528, 65528, 65529, 65529, +65529, 65530, 65530, 65530, 65531, 65531, 65531, 65531, 65532, 65532, 65532, +65532, 65532, 65533, 65533, 65533, 65533, 65533, 65533, 65533, 65533, 65533, +65533, 65534, 65534, 65534, 65534, 65534, 65534, 65534, 65534, 65535 +}; + +#define MELANOPIC_WLMIN 380 +#define MELANOPIC_WLMAX 651 + +static const unsigned short melanopic_cumul[MELANOPIC_WLMAX-MELANOPIC_WLMIN+1] = { +0, 1, 2, 3, 4, 5, 7, 8, 10, 12, 14, 17, 20, 23, 27, 32, 37, 42, 49, 56, +65, 75, 86, 99, 114, 131, 150, 173, 200, 230, 265, 303, 347, 395, 448, +508, 574, 650, 734, 828, 931, 1041, 1158, 1283, 1415, 1554, 1703, 1862, +2031, 2211, 2400, 2600, 2809, 3028, 3257, 3497, 3748, 4012, 4288, 4576, +4876, 5187, 5509, 5842, 6185, 6540, 6905, 7283, 7673, 8075, 8489, 8915, +9351, 9799, 10259, 10729, 11211, 11705, 12211, 12729, 13258, 13799, +14351, 14915, 15491, 16078, 16676, 17286, 17908, 18541, 19184, 19837, +20498, 21168, 21846, 22532, 23226, 23928, 24637, 25353, 26075, 26802, +27532, 28267, 29005, 29746, 30488, 31233, 31979, 32726, 33473, 34220, +34966, 35711, 36455, 37196, 37935, 38671, 39403, 40129, 40851, 41568, +42279, 42983, 43680, 44369, 45050, 45724, 46388, 47043, 47688, 48322, +48945, 49557, 50156, 50743, 51317, 51879, 52428, 52964, 53487, 53997, +54493, 54976, 55445, 55901, 56343, 56771, 57186, 57587, 57976, 58351, +58712, 59061, 59397, 59720, 60031, 60330, 60616, 60891, 61154, 61405, +61646, 61875, 62094, 62303, 62501, 62690, 62870, 63040, 63201, 63354, +63498, 63634, 63763, 63884, 63998, 64105, 64206, 64300, 64389, 64472, +64549, 64622, 64689, 64753, 64811, 64866, 64917, 64964, 65008, 65049, +65086, 65121, 65154, 65184, 65211, 65237, 65260, 65282, 65302, 65321, +65338, 65354, 65368, 65381, 65394, 65405, 65415, 65425, 65434, 65442, +65449, 65456, 65463, 65468, 65474, 65479, 65483, 65487, 65491, 65494, +65498, 65501, 65503, 65506, 65508, 65510, 65512, 65514, 65515, 65517, +65518, 65520, 65521, 65522, 65523, 65524, 65525, 65525, 65526, 65527, +65527, 65528, 65528, 65529, 65529, 65530, 65530, 65530, 65531, 65531, +65531, 65531, 65532, 65532, 65532, 65532, 65532, 65533, 65533, 65533, +65533, 65533, 65533, 65533, 65533, 65533, 65534, 65534, 65534, 65535 +}; + COLORMAT xyz2rgbmat = { /* XYZ to RGB (no white balance) */ {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD, (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD, @@ -90,73 +233,263 @@ COLORMAT ivkmat = { /* inverse Sharp primary matrix void -spec_rgb(col, s, e) /* compute RGB color from spectral range */ -COLOR col; -int s, e; +spec_cie( /* compute XYZ color from a spectral range */ +COLOR col, /* returned color */ +int s, /* starting and ending wavelengths */ +int e +) { + if (s > e) { int i = s; s = e; e = i; } + + if ((s >= CIE_X_WLMAX) | (e <= CIE_X_WLMIN)) + col[CIEX] = 0; + else + col[CIEX] = (cie_x_cumul[e>=CIE_X_WLMAX ? CIE_X_WLMAX-CIE_X_WLMIN : e-CIE_X_WLMIN] - + cie_x_cumul[(s>CIE_X_WLMIN)*(s-CIE_X_WLMIN)])*(1./65535.); + + if ((s >= CIE_Y_WLMAX) | (e <= CIE_Y_WLMIN)) + col[CIEY] = 0; + else + col[CIEY] = (cie_y_cumul[e>=CIE_Y_WLMAX ? CIE_Y_WLMAX-CIE_Y_WLMIN : e-CIE_Y_WLMIN] - + cie_y_cumul[(s>CIE_Y_WLMIN)*(s-CIE_Y_WLMIN)])*(1./65535.); + + if ((s >= CIE_Z_WLMAX) | (e <= CIE_Z_WLMIN)) + col[CIEZ] = 0; + else + col[CIEZ] = (cie_z_cumul[e>=CIE_Z_WLMAX ? CIE_Z_WLMAX-CIE_Z_WLMIN : e-CIE_Z_WLMIN] - + cie_z_cumul[(s>CIE_Z_WLMIN)*(s-CIE_Z_WLMIN)])*(1./65535.); +} + + +void +spec_rgb( /* compute RGB color from spectral range */ +COLOR col, +int s, +int e +) +{ COLOR ciecolor; spec_cie(ciecolor, s, e); - cie_rgb(col, ciecolor); + colortrans(col, xyz2rgbmat, ciecolor); } +static double +spec_dot( /* spectrum dot-product with cumulative observer */ + const SCOLOR scol, + int ncs, + const float wlpt[4], + const unsigned short cumul[], + int wlmin, + int wlmax +) +{ + const double wlstp = (wlpt[0] - wlpt[3])/(double)ncs; + int wl1 = (int)wlpt[3]; + int n = 0; + double sum = 0; + + if (wl1 < wlmin) { + n += (int)((wlmin - wl1)/wlstp); + wl1 = wlmin; + } else if (wl1 >= wlmax) + return(.0); + + while (n < ncs) { + int wl0 = wl1; + wl1 = (int)(ncs==3 ? wlpt[2-n] : wlpt[3] + (n+1)*wlstp); + if (wl1 >= wlmax) { + sum += (65535 - cumul[wl0-wlmin]) * scol[ncs-1-n]; + break; + } + sum += (cumul[wl1-wlmin] - cumul[wl0-wlmin]) * scol[ncs-1-n++]; + } + return(sum * (1./65535.)); +} + + void -spec_cie(col, s, e) /* compute a color from a spectral range */ -COLOR col; /* returned color */ -int s, e; /* starting and ending wavelengths */ +scolor2cie( /* accurate conversion from spectrum to XYZ */ + COLOR col, + const SCOLOR scol, + int ncs, + const float wlpt[4] +) { - register int i, d, r; - - s -= STARTWL; - if (s < 0) - s = 0; + if (ncs == 3) { /* not a spectrum! */ + rgb_cie(col, scol); + return; + } + col[CIEX] = spec_dot(scol, ncs, wlpt, cie_x_cumul, CIE_X_WLMIN, CIE_X_WLMAX); + col[CIEY] = spec_dot(scol, ncs, wlpt, cie_y_cumul, CIE_Y_WLMIN, CIE_Y_WLMAX); + col[CIEZ] = spec_dot(scol, ncs, wlpt, cie_z_cumul, CIE_Z_WLMIN, CIE_Z_WLMAX); +} - e -= STARTWL; - if (e <= s) { - col[CIEX] = col[CIEY] = col[CIEZ] = 0.0; + +void +scolor2rgb( /* accurate conversion from spectrum to RGB */ + COLOR col, + const SCOLOR scol, + int ncs, + const float wlpt[4] +) +{ + COLOR ciecolor; + + if (ncs == 3) { /* not really a spectrum, so we punt... */ + copycolor(col, scol); return; } - if (e >= INCWL*(NINC - 1)) - e = INCWL*(NINC - 1) - 1; + scolor2cie(ciecolor, scol, ncs, wlpt); + cie_rgb(col, ciecolor); +} - d = e / INCWL; /* interpolate values */ - r = e % INCWL; - for (i = 0; i < 3; i++) - col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r; - d = s / INCWL; - r = s % INCWL; - for (i = 0; i < 3; i++) - col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r; +void +scolor_out( /* prepare (spectral) color for output */ + COLORV *cout, + RGBPRIMS pr, + const SCOLOR cres +) +{ + static COLORMAT xyz2myp; + static RGBPRIMP lastp = NULL; - col[CIEX] = (col[CIEX] + 0.5) * (1./(256*INCWL)); - col[CIEY] = (col[CIEY] + 0.5) * (1./(256*INCWL)); - col[CIEZ] = (col[CIEZ] + 0.5) * (1./(256*INCWL)); + if (!pr) { /* output is spectral */ + copyscolor(cout, cres); + } else if (pr == stdprims) { /* output is standard RGB */ + scolor_rgb(cout, cres); + } else if (pr == xyzprims) { /* output is XYZ */ + scolor_cie(cout, cres); + scalecolor(cout, WHTEFFICACY); + } else if (NCSAMP > 3) { /* spectral -> custom RGB */ + COLOR xyz; + if (lastp != pr) + compxyz2rgbWBmat(xyz2myp, lastp=pr); + scolor_cie(xyz, cres); + colortrans(cout, xyz2myp, xyz); + clipgamut(cout, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite); + } else { /* else copy unknown RGB */ + copycolor(cout, cres); + } } +double +scolor2photopic( /* compute scotopic integral for spectral color */ + const SCOLOR scol, + int ncs, + const float wlpt[4] +) +{ + if (ncs == 3) + return bright(scol); + + return(spec_dot(scol, ncs, wlpt, cie_y_cumul, CIE_Y_WLMIN, CIE_Y_WLMAX)); +} + + +double +scolor2scotopic( /* compute Y channel for spectral color */ + const SCOLOR scol, + int ncs, + const float wlpt[4] +) +{ + return(spec_dot(scol, ncs, wlpt, scotopic_cumul, SCOTOPIC_WLMIN, SCOTOPIC_WLMAX)); +} + + +double +scolor2melanopic( /* compute melanopic integral for spectral color */ + const SCOLOR scol, + int ncs, + const float wlpt[4] +) +{ + return(spec_dot(scol, ncs, wlpt, melanopic_cumul, MELANOPIC_WLMIN, MELANOPIC_WLMAX)); +} + + +double +scolor_photopic( /* compute scotopic integral for spectral color */ + const SCOLOR scol +) +{ + return(scolor2photopic(scol, NCSAMP, WLPART)); +} + + +double +scolor_scotopic( /* compute Y channel for spectral color */ + const SCOLOR scol +) +{ + return(scolor2scotopic(scol, NCSAMP, WLPART)); +} + + +double +scolor_melanopic( /* compute melanopic integral for spectral color */ + const SCOLOR scol +) +{ + return(scolor2melanopic(scol, NCSAMP, WLPART)); +} + + void -cie_rgb(rgb, xyz) /* convert CIE color to standard RGB */ -COLOR rgb; -COLOR xyz; +convertscolorcol( /* any uniform spectrum to working */ + SCOLOR rcol, + const COLORV src[], + int snc, + double swl0, + double swl1 +) { + if (NCSAMP > 3) { /* spectrum -> spectrum */ + convertscolor(rcol, NCSAMP, WLPART[0], WLPART[3], + src, snc, swl0, swl1); + } else if ((snc <= MAXCSAMP) & (swl0 > swl1)) { + float wlpt[4]; /* no intermediate conversion needed */ + wlpt[0] = swl0; wlpt[3] = swl1; + wlpt[1] = WLPART[1]; wlpt[2] = WLPART[2]; + scolor2rgb(rcol, (COLORV *)src, snc, wlpt); + } else { + SCOLOR dcol; /* else convert spectrum first */ + int dnc = snc*(WLPART[0] - WLPART[3])/fabs(swl0 - swl1) + .99; + if (dnc > MAXCSAMP) dnc = MAXCSAMP; + convertscolor(dcol, dnc, WLPART[0], WLPART[3], src, snc, swl0, swl1); + scolor2rgb(rcol, dcol, dnc, WLPART); + } +} + + +void +cie_rgb( /* convert CIE color to standard RGB */ +COLOR rgb, +const COLOR xyz +) +{ colortrans(rgb, xyz2rgbmat, xyz); clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite); } int -clipgamut(col, brt, gamut, lower, upper) /* clip to gamut cube */ -COLOR col; -double brt; -int gamut; -COLOR lower, upper; +clipgamut( /* clip to gamut cube */ +COLOR col, +double brt, +int gamut, +const COLOR lower, +const COLOR upper +) { int rflags = 0; double brtmin, brtmax, v, vv; COLOR cgry; - register int i; + int i; /* check for no check */ if (gamut == 0) return(0); /* check brightness limits */ @@ -177,11 +510,11 @@ COLOR lower, upper; vv = 1.; /* check each limit */ for (i = 0; i < 3; i++) if (gamut & CGAMUT_LOWER && col[i] < lower[i]) { - v = (lower[i]+CEPS - cgry[i])/(col[i] - cgry[i]); + v = (lower[i] - cgry[i])/(col[i] - cgry[i]); if (v < vv) vv = v; rflags |= CGAMUT_LOWER; } else if (gamut & CGAMUT_UPPER && col[i] > upper[i]) { - v = (upper[i]-CEPS - cgry[i])/(col[i] - cgry[i]); + v = (upper[i] - cgry[i])/(col[i] - cgry[i]); if (v < vv) vv = v; rflags |= CGAMUT_UPPER; } @@ -193,10 +526,11 @@ COLOR lower, upper; void -colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */ -register COLOR c2; -register COLORMAT mat; -register COLOR c1; +colortrans( /* convert c1 by mat and put into c2 */ +COLOR c2, +const COLORMAT mat, +const COLOR c1 +) { COLOR cout; @@ -209,12 +543,14 @@ register COLOR c1; void -multcolormat(m3, m2, m1) /* multiply m1 by m2 and put into m3 */ -COLORMAT m3; /* m3 can be either m1 or m2 w/o harm */ -COLORMAT m2, m1; +multcolormat( /* multiply m1 by m2 and put into m3 */ +COLORMAT m3, /* m3 can be either m1 or m2 w/o harm */ +const COLORMAT m2, +const COLORMAT m1 +) { COLORMAT mt; - register int i, j; + int i, j; for (i = 0; i < 3; i++) for (j = 0; j < 3; j++) @@ -225,30 +561,79 @@ COLORMAT m2, m1; } -void -compxyz2rgbmat(mat, pr) /* compute conversion from CIE to RGB space */ -COLORMAT mat; -register RGBPRIMS pr; +int +colorprimsOK( /* are color primaries reasonable? */ +RGBPRIMS pr +) { + int i, j; + /* check white point */ + if ((pr[3][CIEX] <= CEPS) | (pr[3][CIEX] >= 1.-CEPS) | + (pr[3][CIEY] <= CEPS) | (pr[3][CIEY] >= 1.-CEPS)) + return(0); + for (i = 3; i--; ) /* check for XYZ color primaries */ + if (!CEQ(pr[i][CIEX],(i==0)) | !CEQ(pr[i][CIEY],(i==1))) + break; + if (i < 0) + return(-1); /* flag as XYZ color space */ + /* check color primaries */ + for (i = 0; i < 3; i++) { + if ((pr[i][CIEX] <= -2.) | (pr[i][CIEY] <= -2.)) + return(0); + if ((pr[i][CIEX] >= 3.) | (pr[i][CIEY] >= 3.)) + return(0); + if (pr[i][CIEX] + pr[i][CIEY] <= -2.) + return(0); + if (pr[i][CIEX] + pr[i][CIEY] >= 3.) + return(0); + } + for (i = 0; i < 4; i++) /* make sure space is 3-dimensional */ + for (j = i+1; j < 4; j++) + if (CEQ(pr[i][CIEX],pr[j][CIEX]) & + CEQ(pr[i][CIEY],pr[j][CIEY])) + return(0); + return(1); +} + + + +int +compxyz2rgbmat( /* compute conversion from CIE to RGB space */ +COLORMAT mat, +RGBPRIMS pr +) +{ double C_rD, C_gD, C_bD; if (pr == stdprims) { /* can use xyz2rgbmat */ cpcolormat(mat, xyz2rgbmat); - return; + return(1); } + if (pr == xyzprims) { /* identity */ + memset(mat, 0, sizeof(COLORMAT)); + mat[0][0] = mat[1][1] = mat[2][2] = 1.f; + return(1); + } + if (CEQ(pr[WHT][CIEX],0.) | CEQ(pr[WHT][CIEY],0.)) + return(0); C_rD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ; + if (CEQ(C_rD,0.)) + return(0); C_gD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) - pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) - pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ; + if (CEQ(C_gD,0.)) + return(0); C_bD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) - pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) + pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ; - + if (CEQ(C_bD,0.)) + return(0); mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] + pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ; @@ -273,20 +658,29 @@ register RGBPRIMS pr; pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ; mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ; + return(1); } -void -comprgb2xyzmat(mat, pr) /* compute conversion from RGB to CIE space */ -COLORMAT mat; -register RGBPRIMS pr; +int +comprgb2xyzmat( /* compute conversion from RGB to CIE space */ +COLORMAT mat, +RGBPRIMS pr +) { double C_rD, C_gD, C_bD, D; if (pr == stdprims) { /* can use rgb2xyzmat */ cpcolormat(mat, rgb2xyzmat); - return; + return(1); } + if (pr == xyzprims) { /* identity */ + memset(mat, 0, sizeof(COLORMAT)); + mat[0][0] = mat[1][1] = mat[2][2] = 1.f; + return(1); + } + if (CEQ(pr[WHT][CIEX],0.) | CEQ(pr[WHT][CIEY],0.)) + return(0); C_rD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + @@ -302,6 +696,8 @@ register RGBPRIMS pr; D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) + pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) + pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ; + if (CEQ(D,0.)) + return(0); mat[0][0] = pr[RED][CIEX]*C_rD/D; mat[0][1] = pr[GRN][CIEX]*C_gD/D; mat[0][2] = pr[BLU][CIEX]*C_bD/D; @@ -311,49 +707,61 @@ register RGBPRIMS pr; mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D; mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D; mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D; + return(1); } -void -comprgb2rgbmat(mat, pr1, pr2) /* compute conversion from RGB1 to RGB2 */ -COLORMAT mat; -RGBPRIMS pr1, pr2; +int +comprgb2rgbmat( /* compute conversion from RGB1 to RGB2 */ +COLORMAT mat, +RGBPRIMS pr1, +RGBPRIMS pr2 +) { COLORMAT pr1toxyz, xyztopr2; if (pr1 == pr2) { - mat[0][0] = mat[1][1] = mat[2][2] = 1.0; - mat[0][1] = mat[0][2] = mat[1][0] = - mat[1][2] = mat[2][0] = mat[2][1] = 0.0; - return; + memset(mat, 0, sizeof(COLORMAT)); + mat[0][0] = mat[1][1] = mat[2][2] = 1.f; + return(1); } - comprgb2xyzmat(pr1toxyz, pr1); - compxyz2rgbmat(xyztopr2, pr2); + if (!comprgb2xyzmat(pr1toxyz, pr1)) + return(0); + if (!compxyz2rgbmat(xyztopr2, pr2)) + return(0); /* combine transforms */ multcolormat(mat, pr1toxyz, xyztopr2); + return(1); } -void -compxyzWBmat(mat, wht1, wht2) /* CIE von Kries transform from wht1 to wht2 */ -COLORMAT mat; -float wht1[2], wht2[2]; +int +compxyzWBmat( /* CIE von Kries transform from wht1 to wht2 */ +COLORMAT mat, +const float wht1[2], +const float wht2[2] +) { COLOR cw1, cw2; if (XYEQ(wht1,wht2)) { - mat[0][0] = mat[1][1] = mat[2][2] = 1.0; - mat[0][1] = mat[0][2] = mat[1][0] = - mat[1][2] = mat[2][0] = mat[2][1] = 0.0; - return; + memset(mat, 0, sizeof(COLORMAT)); + mat[0][0] = mat[1][1] = mat[2][2] = 1.f; + return(1); } + if (CEQ(wht1[CIEX],0.) | CEQ(wht1[CIEY],0.)) + return(0); cw1[RED] = wht1[CIEX]/wht1[CIEY]; cw1[GRN] = 1.; cw1[BLU] = (1. - wht1[CIEX] - wht1[CIEY])/wht1[CIEY]; colortrans(cw1, vkmat, cw1); + if (CEQ(wht2[CIEX],0.) | CEQ(wht2[CIEY],0.)) + return(0); cw2[RED] = wht2[CIEX]/wht2[CIEY]; cw2[GRN] = 1.; cw2[BLU] = (1. - wht2[CIEX] - wht2[CIEY])/wht2[CIEY]; colortrans(cw2, vkmat, cw2); + if (CEQ(cw1[RED],0.) | CEQ(cw1[GRN],0.) | CEQ(cw1[BLU],0.)) + return(0); mat[0][0] = cw2[RED]/cw1[RED]; mat[1][1] = cw2[GRN]/cw1[GRN]; mat[2][2] = cw2[BLU]/cw1[BLU]; @@ -361,54 +769,68 @@ float wht1[2], wht2[2]; mat[1][2] = mat[2][0] = mat[2][1] = 0.0; multcolormat(mat, vkmat, mat); multcolormat(mat, mat, ivkmat); + return(1); } -void -compxyz2rgbWBmat(mat, pr) /* von Kries conversion from CIE to RGB space */ -COLORMAT mat; -RGBPRIMS pr; +int +compxyz2rgbWBmat( /* von Kries conversion from CIE to RGB space */ +COLORMAT mat, +RGBPRIMS pr +) { COLORMAT wbmat; - compxyz2rgbmat(mat, pr); + if (!compxyz2rgbmat(mat, pr)) + return(0); if (XYEQ(pr[WHT],xyneu)) - return; - compxyzWBmat(wbmat, xyneu, pr[WHT]); + return(1); + if (!compxyzWBmat(wbmat, xyneu, pr[WHT])) + return(0); multcolormat(mat, wbmat, mat); + return(1); } -void -comprgb2xyzWBmat(mat, pr) /* von Kries conversion from RGB to CIE space */ -COLORMAT mat; -RGBPRIMS pr; +int +comprgb2xyzWBmat( /* von Kries conversion from RGB to CIE space */ +COLORMAT mat, +RGBPRIMS pr +) { COLORMAT wbmat; - comprgb2xyzmat(mat, pr); + if (!comprgb2xyzmat(mat, pr)) + return(0); if (XYEQ(pr[WHT],xyneu)) - return; - compxyzWBmat(wbmat, pr[WHT], xyneu); + return(1); + if (!compxyzWBmat(wbmat, pr[WHT], xyneu)) + return(0); multcolormat(mat, mat, wbmat); + return(1); } -void -comprgb2rgbWBmat(mat, pr1, pr2) /* von Kries conversion from RGB1 to RGB2 */ -COLORMAT mat; -RGBPRIMS pr1, pr2; +int +comprgb2rgbWBmat( /* von Kries conversion from RGB1 to RGB2 */ +COLORMAT mat, +RGBPRIMS pr1, +RGBPRIMS pr2 +) { COLORMAT pr1toxyz, xyztopr2, wbmat; if (pr1 == pr2) { - mat[0][0] = mat[1][1] = mat[2][2] = 1.0; - mat[0][1] = mat[0][2] = mat[1][0] = - mat[1][2] = mat[2][0] = mat[2][1] = 0.0; - return; + memset(mat, 0, sizeof(COLORMAT)); + mat[0][0] = mat[1][1] = mat[2][2] = 1.f; + return(1); } - comprgb2xyzmat(pr1toxyz, pr1); - compxyzWBmat(wbmat, pr1[WHT], pr2[WHT]); - compxyz2rgbmat(xyztopr2, pr2); + if (!comprgb2xyzmat(pr1toxyz, pr1)) + return(0); + if (!compxyzWBmat(wbmat, pr1[WHT], pr2[WHT])) + return(0); + if (!compxyz2rgbmat(xyztopr2, pr2)) + return(0); /* combine transforms */ multcolormat(mat, pr1toxyz, wbmat); multcolormat(mat, mat, xyztopr2); + return(1); }
