--- ray/src/common/spec_rgb.c 2006/03/23 22:01:43 2.14 +++ ray/src/common/spec_rgb.c 2006/09/05 21:54:32 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: spec_rgb.c,v 2.14 2006/03/23 22:01:43 greg Exp $"; +static const char RCSid[] = "$Id: spec_rgb.c,v 2.15 2006/09/05 21:54:32 greg Exp $"; #endif /* * Convert colors and spectral ranges. @@ -91,9 +91,11 @@ COLORMAT ivkmat = { /* inverse Sharp primary matrix void -spec_rgb(col, s, e) /* compute RGB color from spectral range */ -COLOR col; -int s, e; +spec_rgb( /* compute RGB color from spectral range */ +COLOR col, +int s, +int e +) { COLOR ciecolor; @@ -103,9 +105,11 @@ int s, e; void -spec_cie(col, s, e) /* compute a color from a spectral range */ -COLOR col; /* returned color */ -int s, e; /* starting and ending wavelengths */ +spec_cie( /* compute a color from a spectral range */ +COLOR col, /* returned color */ +int s, /* starting and ending wavelengths */ +int e +) { register int i, d, r; @@ -138,9 +142,10 @@ int s, e; /* starting and ending wavelengths */ void -cie_rgb(rgb, xyz) /* convert CIE color to standard RGB */ -COLOR rgb; -COLOR xyz; +cie_rgb( /* convert CIE color to standard RGB */ +COLOR rgb, +COLOR xyz +) { colortrans(rgb, xyz2rgbmat, xyz); clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite); @@ -148,11 +153,13 @@ COLOR xyz; int -clipgamut(col, brt, gamut, lower, upper) /* clip to gamut cube */ -COLOR col; -double brt; -int gamut; -COLOR lower, upper; +clipgamut( /* clip to gamut cube */ +COLOR col, +double brt, +int gamut, +COLOR lower, +COLOR upper +) { int rflags = 0; double brtmin, brtmax, v, vv; @@ -194,10 +201,11 @@ COLOR lower, upper; void -colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */ -register COLOR c2; -register COLORMAT mat; -register COLOR c1; +colortrans( /* convert c1 by mat and put into c2 */ +register COLOR c2, +register COLORMAT mat, +register COLOR c1 +) { COLOR cout; @@ -210,9 +218,11 @@ register COLOR c1; void -multcolormat(m3, m2, m1) /* multiply m1 by m2 and put into m3 */ -COLORMAT m3; /* m3 can be either m1 or m2 w/o harm */ -COLORMAT m2, m1; +multcolormat( /* multiply m1 by m2 and put into m3 */ +COLORMAT m3, /* m3 can be either m1 or m2 w/o harm */ +COLORMAT m2, +COLORMAT m1 +) { COLORMAT mt; register int i, j; @@ -226,30 +236,56 @@ COLORMAT m2, m1; } -void -compxyz2rgbmat(mat, pr) /* compute conversion from CIE to RGB space */ -COLORMAT mat; -register RGBPRIMS pr; +int +colorprimsOK( /* are color primaries reasonable? */ +RGBPRIMS pr +) { + int i; + + for (i = 0; i < 4; i++) { + if ((pr[i][CIEX] <= CEPS) | (pr[i][CIEY] <= CEPS)) + return(0); + if ((pr[i][CIEX] >= 1.-CEPS) | (pr[i][CIEY] >= 1.-CEPS)) + return(0); + } + return(1); +} + + + +int +compxyz2rgbmat( /* compute conversion from CIE to RGB space */ +COLORMAT mat, +register RGBPRIMS pr +) +{ double C_rD, C_gD, C_bD; if (pr == stdprims) { /* can use xyz2rgbmat */ cpcolormat(mat, xyz2rgbmat); return; } + if (CEQ(pr[WHT][CIEX],0.) | CEQ(pr[WHT][CIEY],0.)) + return(0); C_rD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ; + if (CEQ(C_rD,0.)) + return(0); C_gD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) - pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) - pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ; + if (CEQ(C_gD,0.)) + return(0); C_bD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) - pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) + pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ; - + if (CEQ(C_bD,0.)) + return(0); mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] + pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ; @@ -274,13 +310,15 @@ register RGBPRIMS pr; pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ; mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ; + return(1); } -void -comprgb2xyzmat(mat, pr) /* compute conversion from RGB to CIE space */ -COLORMAT mat; -register RGBPRIMS pr; +int +comprgb2xyzmat( /* compute conversion from RGB to CIE space */ +COLORMAT mat, +register RGBPRIMS pr +) { double C_rD, C_gD, C_bD, D; @@ -288,6 +326,8 @@ register RGBPRIMS pr; cpcolormat(mat, rgb2xyzmat); return; } + if (CEQ(pr[WHT][CIEX],0.) | CEQ(pr[WHT][CIEY],0.)) + return(0); C_rD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + @@ -303,6 +343,8 @@ register RGBPRIMS pr; D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) + pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) + pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ; + if (CEQ(D,0.)) + return(0); mat[0][0] = pr[RED][CIEX]*C_rD/D; mat[0][1] = pr[GRN][CIEX]*C_gD/D; mat[0][2] = pr[BLU][CIEX]*C_bD/D; @@ -312,13 +354,16 @@ register RGBPRIMS pr; mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D; mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D; mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D; + return(1); } -void -comprgb2rgbmat(mat, pr1, pr2) /* compute conversion from RGB1 to RGB2 */ -COLORMAT mat; -RGBPRIMS pr1, pr2; +int +comprgb2rgbmat( /* compute conversion from RGB1 to RGB2 */ +COLORMAT mat, +RGBPRIMS pr1, +RGBPRIMS pr2 +) { COLORMAT pr1toxyz, xyztopr2; @@ -328,33 +373,44 @@ RGBPRIMS pr1, pr2; mat[1][2] = mat[2][0] = mat[2][1] = 0.0; return; } - comprgb2xyzmat(pr1toxyz, pr1); - compxyz2rgbmat(xyztopr2, pr2); + if (!comprgb2xyzmat(pr1toxyz, pr1)) + return(0); + if (!compxyz2rgbmat(xyztopr2, pr2)) + return(0); /* combine transforms */ multcolormat(mat, pr1toxyz, xyztopr2); + return(1); } -void -compxyzWBmat(mat, wht1, wht2) /* CIE von Kries transform from wht1 to wht2 */ -COLORMAT mat; -float wht1[2], wht2[2]; +int +compxyzWBmat( /* CIE von Kries transform from wht1 to wht2 */ +COLORMAT mat, +float wht1[2], +float wht2[2] +) { COLOR cw1, cw2; if (XYEQ(wht1,wht2)) { mat[0][0] = mat[1][1] = mat[2][2] = 1.0; mat[0][1] = mat[0][2] = mat[1][0] = mat[1][2] = mat[2][0] = mat[2][1] = 0.0; - return; + return(1); } + if (CEQ(wht1[CIEX],0.) | CEQ(wht1[CIEY],0.)) + return(0); cw1[RED] = wht1[CIEX]/wht1[CIEY]; cw1[GRN] = 1.; cw1[BLU] = (1. - wht1[CIEX] - wht1[CIEY])/wht1[CIEY]; colortrans(cw1, vkmat, cw1); + if (CEQ(wht2[CIEX],0.) | CEQ(wht2[CIEY],0.)) + return(0); cw2[RED] = wht2[CIEX]/wht2[CIEY]; cw2[GRN] = 1.; cw2[BLU] = (1. - wht2[CIEX] - wht2[CIEY])/wht2[CIEY]; colortrans(cw2, vkmat, cw2); + if (CEQ(cw1[RED],0.) | CEQ(cw1[GRN],0.) | CEQ(cw1[BLU],0.)) + return(0); mat[0][0] = cw2[RED]/cw1[RED]; mat[1][1] = cw2[GRN]/cw1[GRN]; mat[2][2] = cw2[BLU]/cw1[BLU]; @@ -362,41 +418,52 @@ float wht1[2], wht2[2]; mat[1][2] = mat[2][0] = mat[2][1] = 0.0; multcolormat(mat, vkmat, mat); multcolormat(mat, mat, ivkmat); + return(1); } -void -compxyz2rgbWBmat(mat, pr) /* von Kries conversion from CIE to RGB space */ -COLORMAT mat; -RGBPRIMS pr; +int +compxyz2rgbWBmat( /* von Kries conversion from CIE to RGB space */ +COLORMAT mat, +RGBPRIMS pr +) { COLORMAT wbmat; - compxyz2rgbmat(mat, pr); + if (!compxyz2rgbmat(mat, pr)) + return(0); if (XYEQ(pr[WHT],xyneu)) - return; - compxyzWBmat(wbmat, xyneu, pr[WHT]); + return(1); + if (!compxyzWBmat(wbmat, xyneu, pr[WHT])) + return(0); multcolormat(mat, wbmat, mat); + return(1); } -void -comprgb2xyzWBmat(mat, pr) /* von Kries conversion from RGB to CIE space */ -COLORMAT mat; -RGBPRIMS pr; +int +comprgb2xyzWBmat( /* von Kries conversion from RGB to CIE space */ +COLORMAT mat, +RGBPRIMS pr +) { COLORMAT wbmat; - comprgb2xyzmat(mat, pr); + if (!comprgb2xyzmat(mat, pr)) + return(0); if (XYEQ(pr[WHT],xyneu)) - return; - compxyzWBmat(wbmat, pr[WHT], xyneu); + return(1); + if (!compxyzWBmat(wbmat, pr[WHT], xyneu)) + return(0); multcolormat(mat, mat, wbmat); + return(1); } -void -comprgb2rgbWBmat(mat, pr1, pr2) /* von Kries conversion from RGB1 to RGB2 */ -COLORMAT mat; -RGBPRIMS pr1, pr2; +int +comprgb2rgbWBmat( /* von Kries conversion from RGB1 to RGB2 */ +COLORMAT mat, +RGBPRIMS pr1, +RGBPRIMS pr2 +) { COLORMAT pr1toxyz, xyztopr2, wbmat; @@ -404,12 +471,16 @@ RGBPRIMS pr1, pr2; mat[0][0] = mat[1][1] = mat[2][2] = 1.0; mat[0][1] = mat[0][2] = mat[1][0] = mat[1][2] = mat[2][0] = mat[2][1] = 0.0; - return; + return(1); } - comprgb2xyzmat(pr1toxyz, pr1); - compxyzWBmat(wbmat, pr1[WHT], pr2[WHT]); - compxyz2rgbmat(xyztopr2, pr2); + if (!comprgb2xyzmat(pr1toxyz, pr1)) + return(0); + if (!compxyzWBmat(wbmat, pr1[WHT], pr2[WHT])) + return(0); + if (!compxyz2rgbmat(xyztopr2, pr2)) + return(0); /* combine transforms */ multcolormat(mat, pr1toxyz, wbmat); multcolormat(mat, mat, xyztopr2); + return(1); }
