--- ray/src/common/spec_rgb.c 1990/12/08 09:29:10 1.2 +++ ray/src/common/spec_rgb.c 1990/12/14 12:48:32 1.3 @@ -40,7 +40,7 @@ static BYTE chroma[3][NINC] = { }; #ifdef NTSC -static float xyz2rgbmat[3][3] = { /* XYZ to RGB (NTSC */ +static float xyz2rgbmat[3][3] = { /* XYZ to RGB (NTSC) */ 1.73, -.48, -.26, -.81, 1.65, -.02, .08, -.17, 1.28, @@ -100,7 +100,7 @@ int s, e; /* starting and ending wavelengths */ } -cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB (NTSC) */ +cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB */ register COLOR rgbcolor, ciecolor; { register int i;
