root/radiance/ray/src/common/spec_rgb.c
Revision: 1.1
Committed: Sat Sep 22 10:44:56 1990 UTC (34 years, 10 months ago) by greg
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Convert colors and spectral ranges.
7 */
8
9 #include "color.h"
10
11 /*
12 * The following table contains the CIE tristimulus integrals
13 * for X, Y, and Z. The table is cumulative, so that
14 * each color coordinate integrates to 1.
15 */
16
17 #define STARTWL 380 /* starting wavelength (nanometers) */
18 #define INCWL 10 /* wavelength increment */
19 #define NINC 40 /* # of values */
20
21 static BYTE chroma[3][NINC] = {
22 { /* X */
23 0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
24 42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
25 128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
26 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
27 }, { /* Y */
28 0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
29 17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
30 188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
31 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
32 }, { /* Z */
33 0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
34 237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
35 255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
36 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
37 }
38 };
39
40
41 spec_rgb(col, s, e) /* compute RGB color from spectral range */
42 COLOR col;
43 int s, e;
44 {
45 COLOR ciecolor;
46
47 spec_cie(ciecolor, s, e);
48 cie_rgb(col, ciecolor);
49 }
50
51
52 spec_cie(col, s, e) /* compute a color from a spectral range */
53 COLOR col; /* returned color */
54 int s, e; /* starting and ending wavelengths */
55 {
56 register int i, d, r;
57
58 s -= STARTWL;
59 if (s < 0)
60 s = 0;
61
62 e -= STARTWL;
63 if (e >= INCWL*(NINC - 1))
64 e = INCWL*(NINC - 1) - 1;
65
66 d = e / INCWL; /* interpolate values */
67 r = e % INCWL;
68 for (i = 0; i < 3; i++)
69 col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
70
71 d = s / INCWL;
72 r = s % INCWL;
73 for (i = 0; i < 3; i++)
74 col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
75
76 col[RED] = (col[RED] + 0.5) / (256*INCWL);
77 col[GRN] = (col[GRN] + 0.5) / (256*INCWL);
78 col[BLU] = (col[BLU] + 0.5) / (256*INCWL);
79 }
80
81
82 cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB (NTSC) */
83 register COLOR rgbcolor, ciecolor;
84 {
85 static float cmat[3][3] = {
86 1.73, -.48, -.26,
87 -.81, 1.65, -.02,
88 .08, -.17, 1.28,
89 };
90 register int i;
91
92 for (i = 0; i < 3; i++) {
93 rgbcolor[i] = cmat[i][0]*ciecolor[0] +
94 cmat[i][1]*ciecolor[1] +
95 cmat[i][2]*ciecolor[2] ;
96 if (rgbcolor[i] < 0.0)
97 rgbcolor[i] = 0.0;
98 }
99 }
