root/radiance/ray/src/common/spec_rgb.c
Revision: 2.4
Committed: Thu Jul 7 15:21:25 1994 UTC (30 years, 11 months ago) by greg
Changes since 2.3: +20 -0 lines
added rgb_cie() routine
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert colors and spectral ranges.
9 */
10
11 #include "color.h"
12
13 /*
14 * The following table contains the CIE tristimulus integrals
15 * for X, Y, and Z. The table is cumulative, so that
16 * each color coordinate integrates to 1.
17 */
18
19 #define STARTWL 380 /* starting wavelength (nanometers) */
20 #define INCWL 10 /* wavelength increment */
21 #define NINC 40 /* # of values */
22
23 static BYTE chroma[3][NINC] = {
24 { /* X */
25 0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
26 42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
27 128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
28 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
29 }, { /* Y */
30 0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
31 17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
32 188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
33 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
34 }, { /* Z */
35 0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
36 237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
37 255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
38 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
39 }
40 };
41
42 static float xyz2rgbmat[3][3] = { /* XYZ to RGB */
43 {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
44 (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
45 (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD},
46 {(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
47 (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
48 (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD},
49 {(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
50 (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
51 (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD}
52 };
53
54 static float rgb2xyzmat[3][3] = { /* RGB to XYZ */
55 {CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D},
56 {CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D},
57 {(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
58 (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
59 (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D}
60 };
61
62
63
64 spec_rgb(col, s, e) /* compute RGB color from spectral range */
65 COLOR col;
66 int s, e;
67 {
68 COLOR ciecolor;
69
70 spec_cie(ciecolor, s, e);
71 cie_rgb(col, ciecolor);
72 }
73
74
75 spec_cie(col, s, e) /* compute a color from a spectral range */
76 COLOR col; /* returned color */
77 int s, e; /* starting and ending wavelengths */
78 {
79 register int i, d, r;
80
81 s -= STARTWL;
82 if (s < 0)
83 s = 0;
84
85 e -= STARTWL;
86 if (e <= s) {
87 col[RED] = col[GRN] = col[BLU] = 0.0;
88 return;
89 }
90 if (e >= INCWL*(NINC - 1))
91 e = INCWL*(NINC - 1) - 1;
92
93 d = e / INCWL; /* interpolate values */
94 r = e % INCWL;
95 for (i = 0; i < 3; i++)
96 col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
97
98 d = s / INCWL;
99 r = s % INCWL;
100 for (i = 0; i < 3; i++)
101 col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
102
103 col[RED] = (col[RED] + 0.5) / (256*INCWL);
104 col[GRN] = (col[GRN] + 0.5) / (256*INCWL);
105 col[BLU] = (col[BLU] + 0.5) / (256*INCWL);
106 }
107
108
109 cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB */
110 register COLOR rgbcolor, ciecolor;
111 {
112 register int i;
113
114 for (i = 0; i < 3; i++) {
115 rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] +
116 xyz2rgbmat[i][1]*ciecolor[1] +
117 xyz2rgbmat[i][2]*ciecolor[2] ;
118 if (rgbcolor[i] < 0.0)
119 rgbcolor[i] = 0.0;
120 }
121 }
122
123
124 rgb_cie(ciecolor, rgbcolor) /* convert RGB to CIE */
125 register COLOR ciecolor, rgbcolor;
126 {
127 register int i;
128
129 for (i = 0; i < 3; i++)
130 ciecolor[i] = rgb2xyzmat[i][0]*rgbcolor[0] +
131 rgb2xyzmat[i][1]*rgbcolor[1] +
132 rgb2xyzmat[i][2]*rgbcolor[2] ;
133 }
