root/radiance/ray/src/common/spec_rgb.c
Revision: 2.1
Committed: Tue Nov 12 16:54:40 1991 UTC (32 years, 7 months ago) by greg
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert colors and spectral ranges.
9 */
10
11 #include "color.h"
12
13 /*
14 * The following table contains the CIE tristimulus integrals
15 * for X, Y, and Z. The table is cumulative, so that
16 * each color coordinate integrates to 1.
17 */
18
19 #define STARTWL 380 /* starting wavelength (nanometers) */
20 #define INCWL 10 /* wavelength increment */
21 #define NINC 40 /* # of values */
22
23 static BYTE chroma[3][NINC] = {
24 { /* X */
25 0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
26 42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
27 128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
28 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
29 }, { /* Y */
30 0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
31 17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
32 188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
33 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
34 }, { /* Z */
35 0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
36 237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
37 255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
38 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
39 }
40 };
41
42 #ifdef NTSC
43 static float xyz2rgbmat[3][3] = { /* XYZ to RGB (NTSC) */
44 1.73, -.48, -.26,
45 -.81, 1.65, -.02,
46 .08, -.17, 1.28,
47 };
48 #else
49 static float xyz2rgbmat[3][3] = { /* XYZ to RGB (color monitor) */
50 2.739, -1.145, -.424,
51 -1.119, 2.029, .033,
52 .138, -.333, 1.105,
53 };
54 #endif
55
56
57
58 spec_rgb(col, s, e) /* compute RGB color from spectral range */
59 COLOR col;
60 int s, e;
61 {
62 COLOR ciecolor;
63
64 spec_cie(ciecolor, s, e);
65 cie_rgb(col, ciecolor);
66 }
67
68
69 spec_cie(col, s, e) /* compute a color from a spectral range */
70 COLOR col; /* returned color */
71 int s, e; /* starting and ending wavelengths */
72 {
73 register int i, d, r;
74
75 s -= STARTWL;
76 if (s < 0)
77 s = 0;
78
79 e -= STARTWL;
80 if (e <= s) {
81 col[RED] = col[GRN] = col[BLU] = 0.0;
82 return;
83 }
84 if (e >= INCWL*(NINC - 1))
85 e = INCWL*(NINC - 1) - 1;
86
87 d = e / INCWL; /* interpolate values */
88 r = e % INCWL;
89 for (i = 0; i < 3; i++)
90 col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
91
92 d = s / INCWL;
93 r = s % INCWL;
94 for (i = 0; i < 3; i++)
95 col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
96
97 col[RED] = (col[RED] + 0.5) / (256*INCWL);
98 col[GRN] = (col[GRN] + 0.5) / (256*INCWL);
99 col[BLU] = (col[BLU] + 0.5) / (256*INCWL);
100 }
101
102
103 cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB */
104 register COLOR rgbcolor, ciecolor;
105 {
106 register int i;
107
108 for (i = 0; i < 3; i++) {
109 rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] +
110 xyz2rgbmat[i][1]*ciecolor[1] +
111 xyz2rgbmat[i][2]*ciecolor[2] ;
112 if (rgbcolor[i] < 0.0)
113 rgbcolor[i] = 0.0;
114 }
115 }
