--- ray/src/common/spec_rgb.c 1990/12/08 09:29:10 1.2 +++ ray/src/common/spec_rgb.c 1997/01/31 12:58:39 2.8 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1997 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -10,6 +10,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include "color.h" + +RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */ + +COLOR cblack = BLKCOLOR; /* global black color */ +COLOR cwhite = WHTCOLOR; /* global white color */ + /* * The following table contains the CIE tristimulus integrals * for X, Y, and Z. The table is cumulative, so that @@ -39,19 +45,25 @@ static BYTE chroma[3][NINC] = { } }; -#ifdef NTSC -static float xyz2rgbmat[3][3] = { /* XYZ to RGB (NTSC */ - 1.73, -.48, -.26, - -.81, 1.65, -.02, - .08, -.17, 1.28, +COLORMAT xyz2rgbmat = { /* XYZ to RGB */ + {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD, + (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD, + (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD}, + {(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD, + (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD, + (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD}, + {(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD, + (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD, + (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD} }; -#else -static float xyz2rgbmat[3][3] = { /* XYZ to RGB (color monitor) */ - 2.739, -1.145, -.424, - -1.119, 2.029, .033, - .138, -.333, 1.105, + +COLORMAT rgb2xyzmat = { /* RGB to XYZ */ + {CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D}, + {CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D}, + {(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D, + (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D, + (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D} }; -#endif @@ -78,7 +90,7 @@ int s, e; /* starting and ending wavelengths */ e -= STARTWL; if (e <= s) { - col[RED] = col[GRN] = col[BLU] = 0.0; + col[CIEX] = col[CIEY] = col[CIEZ] = 0.0; return; } if (e >= INCWL*(NINC - 1)) @@ -94,22 +106,192 @@ int s, e; /* starting and ending wavelengths */ for (i = 0; i < 3; i++) col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r; - col[RED] = (col[RED] + 0.5) / (256*INCWL); - col[GRN] = (col[GRN] + 0.5) / (256*INCWL); - col[BLU] = (col[BLU] + 0.5) / (256*INCWL); + col[CIEX] = (col[CIEX] + 0.5) * (1./(256*INCWL)); + col[CIEY] = (col[CIEY] + 0.5) * (1./(256*INCWL)); + col[CIEZ] = (col[CIEZ] + 0.5) * (1./(256*INCWL)); } -cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB (NTSC) */ -register COLOR rgbcolor, ciecolor; +cie_rgb(rgb, xyz) /* convert CIE color to standard RGB */ +COLOR rgb, xyz; { + colortrans(rgb, xyz2rgbmat, xyz); + clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite); +} + + +int +clipgamut(col, brt, gamut, lower, upper) /* clip to gamut cube */ +COLOR col; +double brt; +int gamut; +COLOR lower, upper; +{ + int rflags = 0; + double brtmin, brtmax, v, vv; + COLOR cgry; register int i; + /* check for no check */ + if (gamut == 0) return(0); + /* check brightness limits */ + brtmin = 1./3.*(lower[0]+lower[1]+lower[2]); + if (gamut & CGAMUT_LOWER && brt < brtmin) { + copycolor(col, lower); + return(CGAMUT_LOWER); + } + brtmax = 1./3.*(upper[0]+upper[1]+upper[2]); + if (gamut & CGAMUT_UPPER && brt > brtmax) { + copycolor(col, upper); + return(CGAMUT_UPPER); + } + /* compute equivalent grey */ + v = (brt - brtmin)/(brtmax - brtmin); + for (i = 0; i < 3; i++) + cgry[i] = v*upper[i] + (1.-v)*lower[i]; + vv = 1.; /* check each limit */ + for (i = 0; i < 3; i++) + if (gamut & CGAMUT_LOWER && col[i] < lower[i]) { + v = (lower[i] - cgry[i])/(col[i] - cgry[i]); + if (v < vv) vv = v; + rflags |= CGAMUT_LOWER; + } else if (gamut & CGAMUT_UPPER && col[i] > upper[i]) { + v = (upper[i] - cgry[i])/(col[i] - cgry[i]); + if (v < vv) vv = v; + rflags |= CGAMUT_UPPER; + } + if (rflags) /* desaturate to cube face */ + for (i = 0; i < 3; i++) + col[i] = vv*col[i] + (1.-vv)*cgry[i]; + return(rflags); +} - for (i = 0; i < 3; i++) { - rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] + - xyz2rgbmat[i][1]*ciecolor[1] + - xyz2rgbmat[i][2]*ciecolor[2] ; - if (rgbcolor[i] < 0.0) - rgbcolor[i] = 0.0; + +colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */ +register COLORMAT mat; +register COLOR c1, c2; +{ + c2[0] = mat[0][0]*c1[0] + mat[0][1]*c1[1] + mat[0][2]*c1[2]; + c2[1] = mat[1][0]*c1[0] + mat[1][1]*c1[1] + mat[1][2]*c1[2]; + c2[2] = mat[2][0]*c1[0] + mat[2][1]*c1[1] + mat[2][2]*c1[2]; +} + + +multcolormat(m3, m2, m1) /* multiply m1 by m2 and put into m3 */ +COLORMAT m1, m2, m3; /* m3 can be either m1 or m2 w/o harm */ +{ + COLORMAT mt; + register int i, j; + + for (i = 0; i < 3; i++) + for (j = 0; j < 3; j++) + mt[i][j] = m1[i][0]*m2[0][j] + + m1[i][1]*m2[1][j] + + m1[i][2]*m2[2][j] ; + cpcolormat(m3, mt); +} + + +compxyz2rgbmat(mat, pr) /* compute conversion from CIE to RGB space */ +COLORMAT mat; +register RGBPRIMS pr; +{ + double C_rD, C_gD, C_bD; + + if (pr == stdprims) { /* can use xyz2rgbmat */ + cpcolormat(mat, xyz2rgbmat); + return; } + C_rD = (1./pr[WHT][CIEY]) * + ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - + pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + + pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ; + C_gD = (1./pr[WHT][CIEY]) * + ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) - + pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) - + pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ; + C_bD = (1./pr[WHT][CIEY]) * + ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) - + pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) + + pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ; + + mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] - + pr[BLU][CIEX]*pr[GRN][CIEY] + + pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ; + mat[0][1] = (pr[BLU][CIEX] - pr[GRN][CIEX] - + pr[BLU][CIEX]*pr[GRN][CIEY] + + pr[GRN][CIEX]*pr[BLU][CIEY])/C_rD ; + mat[0][2] = (pr[GRN][CIEX]*pr[BLU][CIEY] - + pr[BLU][CIEX]*pr[GRN][CIEY])/C_rD ; + mat[1][0] = (pr[BLU][CIEY] - pr[RED][CIEY] - + pr[BLU][CIEY]*pr[RED][CIEX] + + pr[RED][CIEY]*pr[BLU][CIEX])/C_gD ; + mat[1][1] = (pr[RED][CIEX] - pr[BLU][CIEX] - + pr[RED][CIEX]*pr[BLU][CIEY] + + pr[BLU][CIEX]*pr[RED][CIEY])/C_gD ; + mat[1][2] = (pr[BLU][CIEX]*pr[RED][CIEY] - + pr[RED][CIEX]*pr[BLU][CIEY])/C_gD ; + mat[2][0] = (pr[RED][CIEY] - pr[GRN][CIEY] - + pr[RED][CIEY]*pr[GRN][CIEX] + + pr[GRN][CIEY]*pr[RED][CIEX])/C_bD ; + mat[2][1] = (pr[GRN][CIEX] - pr[RED][CIEX] - + pr[GRN][CIEX]*pr[RED][CIEY] + + pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ; + mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] - + pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ; +} + + +comprgb2xyzmat(mat, pr) /* compute conversion from RGB to CIE space */ +COLORMAT mat; +register RGBPRIMS pr; +{ + double C_rD, C_gD, C_bD, D; + + if (pr == stdprims) { /* can use rgb2xyzmat */ + cpcolormat(mat, rgb2xyzmat); + return; + } + C_rD = (1./pr[WHT][CIEY]) * + ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - + pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + + pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ; + C_gD = (1./pr[WHT][CIEY]) * + ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) - + pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) - + pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ; + C_bD = (1./pr[WHT][CIEY]) * + ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) - + pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) + + pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ; + D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) + + pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) + + pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ; + mat[0][0] = pr[RED][CIEX]*C_rD/D; + mat[0][1] = pr[GRN][CIEX]*C_gD/D; + mat[0][2] = pr[BLU][CIEX]*C_bD/D; + mat[1][0] = pr[RED][CIEY]*C_rD/D; + mat[1][1] = pr[GRN][CIEY]*C_gD/D; + mat[1][2] = pr[BLU][CIEY]*C_bD/D; + mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D; + mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D; + mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D; +} + + +comprgb2rgbmat(mat, pr1, pr2) /* compute conversion from RGB1 to RGB2 */ +COLORMAT mat; +RGBPRIMS pr1, pr2; +{ + COLORMAT pr1toxyz, xyztopr2; + + if (pr1 == pr2) { + mat[0][0] = mat[1][1] = mat[2][2] = 1.0; + mat[0][1] = mat[0][2] = mat[1][0] = + mat[1][2] = mat[2][0] = mat[2][1] = 0.0; + return; + } + comprgb2xyzmat(pr1toxyz, pr1); + compxyz2rgbmat(xyztopr2, pr2); + /* combine transforms */ + multcolormat(mat, pr1toxyz, xyztopr2); }
