root/radiance/ray/src/common/spec_rgb.c
Fri May 18 22:48:39 2012 UTC (12 years ago) by greg
Diff to previous 2.23 , to selected 2.21
Even wider acceptance of whacky color primaries
Fri May 20 02:06:38 2011 UTC (13 years ago) by greg
Diff to previous 2.22 , to selected 2.21
Tue Apr 13 01:48:52 2010 UTC (14 years, 1 month ago) by greg
Changes since 2.21: +5 -2 lines
Diff to previous 2.21
Stricter check on white point
Revision 2.21 - (view) (download) (annotate) - [selected]
Mon Apr 12 21:24:07 2010 UTC (14 years, 1 month ago) by greg
Changes since 2.20: +6 -4 lines
Diff to previous 2.20
Allow for even larger primary chromaticity range
Mon Jan 4 19:40:14 2010 UTC (14 years, 4 months ago) by greg
Changes since 2.19: +7 -2 lines
Diff to previous 2.19 , to selected 2.21
Improved chromaticity check
Fri Nov 20 17:51:47 2009 UTC (14 years, 6 months ago) by greg
Diff to previous 2.18 , to selected 2.21
Syntax error
Fri Nov 20 17:50:50 2009 UTC (14 years, 6 months ago) by greg
Diff to previous 2.17 , to selected 2.21
Made color primitive checker even more forgiving
Mon Nov 2 23:45:11 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.16: +5 -3 lines
Diff to previous 2.16 , to selected 2.21
Made color primitives check a little more forgiving
Mon Oct 8 18:07:55 2007 UTC (16 years, 7 months ago) by greg
Diff to previous 2.15 , to selected 2.21
Tue Sep 5 21:54:32 2006 UTC (17 years, 8 months ago) by greg
Changes since 2.14: +135 -64 lines
Diff to previous 2.14 , to selected 2.21
Added return values and colorprimsOK() function to check primary ranges
Thu Mar 23 22:01:43 2006 UTC (18 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 2.21
Fixed problems with NaN and Inf floating point color values
Mon Jun 30 19:04:29 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 2.12 , to selected 2.21
Changes since 2.11: +1 -56 lines
Diff to previous 2.11 , to selected 2.21
Changes since 2.10: +177 -11 lines
Diff to previous 2.10 , to selected 2.21
Wed Oct 7 17:11:40 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 2.9 , to selected 2.21
added conservative measures to make sure clipgamut() kept in bounds
Thu Apr 17 15:42:02 1997 UTC (27 years, 1 month ago) by greg
Changes since 2.8: +7 -3 lines
Diff to previous 2.8 , to selected 2.21
fixed bug in colortrans() introduced in last change
Fri Jan 31 12:58:39 1997 UTC (27 years, 3 months ago) by greg
Changes since 2.7: +61 -12 lines
Diff to previous 2.7 , to selected 2.21
added clipgamut() routine for performing gamut mapping and clipping
Thu Jan 30 19:14:39 1997 UTC (27 years, 3 months ago) by greg
Changes since 2.6: +8 -5 lines
Diff to previous 2.6 , to selected 2.21
changed colortrans() to optionally allow negative results
Wed Oct 2 11:05:18 1996 UTC (27 years, 7 months ago) by greg
Changes since 2.5: +16 -8 lines
Diff to previous 2.5 , to selected 2.21
made testing for stdprims more sensible
Sun Oct 15 14:08:01 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.4: +126 -22 lines
Diff to previous 2.4 , to selected 2.21
made changes for new 32-bit_rle_xyze picture type
Thu Jul 7 15:21:25 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.3: +20 -0 lines
Diff to previous 2.3 , to selected 2.21
added rgb_cie() routine
Wed Jun 29 18:16:58 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.2: +10 -12 lines
Diff to previous 2.2 , to selected 2.21
changed RGB primaries and went to true (i.e. equal-energy) white
Fri Mar 5 15:14:04 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.1 , to selected 2.21
portability improvements
Tue Nov 12 16:54:40 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 2.21
Fri Dec 14 12:48:32 1990 UTC (33 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 2.21
added correct color transformations
Sat Dec 8 09:29:10 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.1: +24 -8 lines
Diff to previous 1.1 , to selected 2.21
changed cie_rgb to use mapping for color monitor by default
Sat Sep 22 10:44:56 1990 UTC (33 years, 8 months ago) by greg
Diff to selected 2.21
