root/radiance/ray/src/common/spec_rgb.c
Revision: 2.5
Committed: Sun Oct 15 14:08:01 1995 UTC (29 years, 7 months ago) by greg
Changes since 2.4: +126 -22 lines
made changes for new 32-bit_rle_xyze picture type
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert colors and spectral ranges.
9 */
10
11 #include "color.h"
12
13
14 RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */
15
16 /*
17 * The following table contains the CIE tristimulus integrals
18 * for X, Y, and Z. The table is cumulative, so that
19 * each color coordinate integrates to 1.
20 */
21
22 #define STARTWL 380 /* starting wavelength (nanometers) */
23 #define INCWL 10 /* wavelength increment */
24 #define NINC 40 /* # of values */
25
26 static BYTE chroma[3][NINC] = {
27 { /* X */
28 0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
29 42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
30 128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
31 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
32 }, { /* Y */
33 0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
34 17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
35 188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
36 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
37 }, { /* Z */
38 0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
39 237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
40 255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
41 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
42 }
43 };
44
45 COLORMAT xyz2rgbmat = { /* XYZ to RGB */
46 {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
47 (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
48 (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD},
49 {(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
50 (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
51 (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD},
52 {(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
53 (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
54 (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD}
55 };
56
57 COLORMAT rgb2xyzmat = { /* RGB to XYZ */
58 {CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D},
59 {CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D},
60 {(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
61 (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
62 (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D}
63 };
64
65
66
67 spec_rgb(col, s, e) /* compute RGB color from spectral range */
68 COLOR col;
69 int s, e;
70 {
71 COLOR ciecolor;
72
73 spec_cie(ciecolor, s, e);
74 cie_rgb(col, ciecolor);
75 }
76
77
78 spec_cie(col, s, e) /* compute a color from a spectral range */
79 COLOR col; /* returned color */
80 int s, e; /* starting and ending wavelengths */
81 {
82 register int i, d, r;
83
84 s -= STARTWL;
85 if (s < 0)
86 s = 0;
87
88 e -= STARTWL;
89 if (e <= s) {
90 col[CIEX] = col[CIEY] = col[CIEZ] = 0.0;
91 return;
92 }
93 if (e >= INCWL*(NINC - 1))
94 e = INCWL*(NINC - 1) - 1;
95
96 d = e / INCWL; /* interpolate values */
97 r = e % INCWL;
98 for (i = 0; i < 3; i++)
99 col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
100
101 d = s / INCWL;
102 r = s % INCWL;
103 for (i = 0; i < 3; i++)
104 col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
105
106 col[CIEX] = (col[CIEX] + 0.5) * (1./(256*INCWL));
107 col[CIEY] = (col[CIEY] + 0.5) * (1./(256*INCWL));
108 col[CIEZ] = (col[CIEZ] + 0.5) * (1./(256*INCWL));
109 }
110
111
112 colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */
113 register COLORMAT mat;
114 register COLOR c1, c2;
115 {
116 static float cout[3];
117
118 cout[0] = mat[0][0]*c1[0] + mat[0][1]*c1[1] + mat[0][2]*c1[2];
119 cout[1] = mat[1][0]*c1[0] + mat[1][1]*c1[1] + mat[1][2]*c1[2];
120 cout[2] = mat[2][0]*c1[0] + mat[2][1]*c1[1] + mat[2][2]*c1[2];
121 if((c2[0] = cout[0]) < 0.) c2[0] = 0.;
122 if((c2[1] = cout[1]) < 0.) c2[1] = 0.;
123 if((c2[2] = cout[2]) < 0.) c2[2] = 0.;
124 }
125
126
127 multcolormat(m3, m2, m1) /* multiply m1 by m2 and put into m3 */
128 COLORMAT m1, m2, m3; /* m3 can be either m1 or m2 w/o harm */
129 {
130 COLORMAT mt;
131 register int i, j;
132
133 for (i = 0; i < 3; i++)
134 for (j = 0; j < 3; j++)
135 mt[i][j] = m1[i][0]*m2[0][j] +
136 m1[i][1]*m2[1][j] +
137 m1[i][2]*m2[2][j] ;
138 cpcolormat(m3, mt);
139 }
140
141
142 compxyz2rgbmat(mat, pr) /* compute conversion from CIE to RGB space */
143 COLORMAT mat;
144 register RGBPRIMS pr;
145 {
146 double C_rD, C_gD, C_bD;
147
148 C_rD = (1./pr[WHT][CIEY]) *
149 ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
150 pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
151 pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
152 C_gD = (1./pr[WHT][CIEY]) *
153 ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
154 pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
155 pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
156 C_bD = (1./pr[WHT][CIEY]) *
157 ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
158 pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
159 pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
160
161 mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] -
162 pr[BLU][CIEX]*pr[GRN][CIEY] +
163 pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ;
164 mat[0][1] = (pr[BLU][CIEX] - pr[GRN][CIEX] -
165 pr[BLU][CIEX]*pr[GRN][CIEY] +
166 pr[GRN][CIEX]*pr[BLU][CIEY])/C_rD ;
167 mat[0][2] = (pr[GRN][CIEX]*pr[BLU][CIEY] -
168 pr[BLU][CIEX]*pr[GRN][CIEY])/C_rD ;
169 mat[1][0] = (pr[BLU][CIEY] - pr[RED][CIEY] -
170 pr[BLU][CIEY]*pr[RED][CIEX] +
171 pr[RED][CIEY]*pr[BLU][CIEX])/C_gD ;
172 mat[1][1] = (pr[RED][CIEX] - pr[BLU][CIEX] -
173 pr[RED][CIEX]*pr[BLU][CIEY] +
174 pr[BLU][CIEX]*pr[RED][CIEY])/C_gD ;
175 mat[1][2] = (pr[BLU][CIEX]*pr[RED][CIEY] -
176 pr[RED][CIEX]*pr[BLU][CIEY])/C_gD ;
177 mat[2][0] = (pr[RED][CIEY] - pr[GRN][CIEY] -
178 pr[RED][CIEY]*pr[GRN][CIEX] +
179 pr[GRN][CIEY]*pr[RED][CIEX])/C_bD ;
180 mat[2][1] = (pr[GRN][CIEX] - pr[RED][CIEX] -
181 pr[GRN][CIEX]*pr[RED][CIEY] +
182 pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ;
183 mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] -
184 pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ;
185 }
186
187
188 comprgb2xyzmat(mat, pr) /* compute conversion from RGB to CIE space */
189 COLORMAT mat;
190 register RGBPRIMS pr;
191 {
192 double C_rD, C_gD, C_bD, D;
193
194 C_rD = (1./pr[WHT][CIEY]) *
195 ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
196 pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
197 pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
198 C_gD = (1./pr[WHT][CIEY]) *
199 ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
200 pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
201 pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
202 C_bD = (1./pr[WHT][CIEY]) *
203 ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
204 pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
205 pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
206 D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) +
207 pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) +
208 pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ;
209 mat[0][0] = pr[RED][CIEX]*C_rD/D;
210 mat[0][1] = pr[GRN][CIEX]*C_gD/D;
211 mat[0][2] = pr[BLU][CIEX]*C_bD/D;
212 mat[1][0] = pr[RED][CIEY]*C_rD/D;
213 mat[1][1] = pr[GRN][CIEY]*C_gD/D;
214 mat[1][2] = pr[BLU][CIEY]*C_bD/D;
215 mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D;
216 mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D;
217 mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D;
218 }
219
220
221 comprgb2rgbmat(mat, pr1, pr2) /* compute conversion from RGB1 to RGB2 */
222 COLORMAT mat;
223 RGBPRIMS pr1, pr2;
224 {
225 COLORMAT pr1toxyz, xyztopr2;
226
227 if (pr1 == stdprims) /* can use rgb2xyzmat */
228 cpcolormat(pr1toxyz, rgb2xyzmat);
229 else /* otherwise compute it */
230 comprgb2xyzmat(pr1toxyz, pr1);
231 if (pr2 == stdprims) /* can use xyz2rgbmat */
232 cpcolormat(xyztopr2, xyz2rgbmat);
233 else /* otherwise compute it */
234 compxyz2rgbmat(xyztopr2, pr2);
235 /* combine transforms */
236 multcolormat(mat, pr1toxyz, xyztopr2);
237 }
