--- ray/src/common/spec_rgb.c 1995/10/15 14:08:01 2.5 +++ ray/src/common/spec_rgb.c 1997/04/17 15:42:02 2.9 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1997 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -13,6 +13,9 @@ static char SCCSid[] = "$SunId$ LBL"; RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */ +COLOR cblack = BLKCOLOR; /* global black color */ +COLOR cwhite = WHTCOLOR; /* global white color */ + /* * The following table contains the CIE tristimulus integrals * for X, Y, and Z. The table is cumulative, so that @@ -109,18 +112,71 @@ int s, e; /* starting and ending wavelengths */ } +cie_rgb(rgb, xyz) /* convert CIE color to standard RGB */ +COLOR rgb, xyz; +{ + colortrans(rgb, xyz2rgbmat, xyz); + clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite); +} + + +int +clipgamut(col, brt, gamut, lower, upper) /* clip to gamut cube */ +COLOR col; +double brt; +int gamut; +COLOR lower, upper; +{ + int rflags = 0; + double brtmin, brtmax, v, vv; + COLOR cgry; + register int i; + /* check for no check */ + if (gamut == 0) return(0); + /* check brightness limits */ + brtmin = 1./3.*(lower[0]+lower[1]+lower[2]); + if (gamut & CGAMUT_LOWER && brt < brtmin) { + copycolor(col, lower); + return(CGAMUT_LOWER); + } + brtmax = 1./3.*(upper[0]+upper[1]+upper[2]); + if (gamut & CGAMUT_UPPER && brt > brtmax) { + copycolor(col, upper); + return(CGAMUT_UPPER); + } + /* compute equivalent grey */ + v = (brt - brtmin)/(brtmax - brtmin); + for (i = 0; i < 3; i++) + cgry[i] = v*upper[i] + (1.-v)*lower[i]; + vv = 1.; /* check each limit */ + for (i = 0; i < 3; i++) + if (gamut & CGAMUT_LOWER && col[i] < lower[i]) { + v = (lower[i] - cgry[i])/(col[i] - cgry[i]); + if (v < vv) vv = v; + rflags |= CGAMUT_LOWER; + } else if (gamut & CGAMUT_UPPER && col[i] > upper[i]) { + v = (upper[i] - cgry[i])/(col[i] - cgry[i]); + if (v < vv) vv = v; + rflags |= CGAMUT_UPPER; + } + if (rflags) /* desaturate to cube face */ + for (i = 0; i < 3; i++) + col[i] = vv*col[i] + (1.-vv)*cgry[i]; + return(rflags); +} + + colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */ register COLORMAT mat; register COLOR c1, c2; { - static float cout[3]; + COLOR cout; cout[0] = mat[0][0]*c1[0] + mat[0][1]*c1[1] + mat[0][2]*c1[2]; cout[1] = mat[1][0]*c1[0] + mat[1][1]*c1[1] + mat[1][2]*c1[2]; cout[2] = mat[2][0]*c1[0] + mat[2][1]*c1[1] + mat[2][2]*c1[2]; - if((c2[0] = cout[0]) < 0.) c2[0] = 0.; - if((c2[1] = cout[1]) < 0.) c2[1] = 0.; - if((c2[2] = cout[2]) < 0.) c2[2] = 0.; + + copycolor(c2, cout); } @@ -145,6 +201,10 @@ register RGBPRIMS pr; { double C_rD, C_gD, C_bD; + if (pr == stdprims) { /* can use xyz2rgbmat */ + cpcolormat(mat, xyz2rgbmat); + return; + } C_rD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + @@ -191,6 +251,10 @@ register RGBPRIMS pr; { double C_rD, C_gD, C_bD, D; + if (pr == stdprims) { /* can use rgb2xyzmat */ + cpcolormat(mat, rgb2xyzmat); + return; + } C_rD = (1./pr[WHT][CIEY]) * ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) - pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) + @@ -224,14 +288,14 @@ RGBPRIMS pr1, pr2; { COLORMAT pr1toxyz, xyztopr2; - if (pr1 == stdprims) /* can use rgb2xyzmat */ - cpcolormat(pr1toxyz, rgb2xyzmat); - else /* otherwise compute it */ - comprgb2xyzmat(pr1toxyz, pr1); - if (pr2 == stdprims) /* can use xyz2rgbmat */ - cpcolormat(xyztopr2, xyz2rgbmat); - else /* otherwise compute it */ - compxyz2rgbmat(xyztopr2, pr2); + if (pr1 == pr2) { + mat[0][0] = mat[1][1] = mat[2][2] = 1.0; + mat[0][1] = mat[0][2] = mat[1][0] = + mat[1][2] = mat[2][0] = mat[2][1] = 0.0; + return; + } + comprgb2xyzmat(pr1toxyz, pr1); + compxyz2rgbmat(xyztopr2, pr2); /* combine transforms */ multcolormat(mat, pr1toxyz, xyztopr2); }
