root/radiance/ray/src/common/spec_rgb.c
Mon Jun 30 19:04:29 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.11: +1 -56 lines
Sat Feb 22 02:07:22 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.10: +177 -11 lines
Wed Oct 7 17:11:40 1998 UTC (25 years, 8 months ago) by gwlarson
added conservative measures to make sure clipgamut() kept in bounds
Thu Apr 17 15:42:02 1997 UTC (27 years, 2 months ago) by greg
Changes since 2.8: +7 -3 lines
fixed bug in colortrans() introduced in last change
Fri Jan 31 12:58:39 1997 UTC (27 years, 4 months ago) by greg
Changes since 2.7: +61 -12 lines
added clipgamut() routine for performing gamut mapping and clipping
Thu Jan 30 19:14:39 1997 UTC (27 years, 4 months ago) by greg
Changes since 2.6: +8 -5 lines
changed colortrans() to optionally allow negative results
Wed Oct 2 11:05:18 1996 UTC (27 years, 8 months ago) by greg
Changes since 2.5: +16 -8 lines
made testing for stdprims more sensible
Sun Oct 15 14:08:01 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.4: +126 -22 lines
made changes for new 32-bit_rle_xyze picture type
Thu Jul 7 15:21:25 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.3: +20 -0 lines
added rgb_cie() routine
Wed Jun 29 18:16:58 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.2: +10 -12 lines
changed RGB primaries and went to true (i.e. equal-energy) white
Fri Mar 5 15:14:04 1993 UTC (31 years, 3 months ago) by greg
portability improvements
Tue Nov 12 16:54:40 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.3 , to selected 2.5
Fri Dec 14 12:48:32 1990 UTC (33 years, 6 months ago) by greg
added correct color transformations
Sat Dec 8 09:29:10 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.1: +24 -8 lines
changed cie_rgb to use mapping for color monitor by default
Sat Sep 22 10:44:56 1990 UTC (33 years, 9 months ago) by greg
Diff to selected 2.5
