| 1 |
/* Copyright (c) 1990 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Convert colors and spectral ranges.
| 9 |
| 10 |
| 11 |
#include "color.h"
| 12 |
| 13 |
| 14 |
* The following table contains the CIE tristimulus integrals
| 15 |
* for X, Y, and Z. The table is cumulative, so that
| 16 |
* each color coordinate integrates to 1.
| 17 |
| 18 |
| 19 |
#define STARTWL 380 /* starting wavelength (nanometers) */
| 20 |
#define INCWL 10 /* wavelength increment */
| 21 |
#define NINC 40 /* # of values */
| 22 |
| 23 |
static BYTE chroma[3][NINC] = {
| 24 |
{ /* X */
| 25 |
0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
| 26 |
42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
| 27 |
128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
| 28 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255
| 29 |
}, { /* Y */
| 30 |
0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
| 31 |
17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
| 32 |
188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
| 33 |
| 34 |
}, { /* Z */
| 35 |
0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
| 36 |
237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
| 37 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
| 38 |
| 39 |
| 40 |
| 41 |
| 42 |
#ifdef NTSC
| 43 |
static float xyz2rgbmat[3][3] = { /* XYZ to RGB (NTSC */
| 44 |
1.73, -.48, -.26,
| 45 |
-.81, 1.65, -.02,
| 46 |
.08, -.17, 1.28,
| 47 |
| 48 |
#else
| 49 |
static float xyz2rgbmat[3][3] = { /* XYZ to RGB (color monitor) */
| 50 |
2.739, -1.145, -.424,
| 51 |
-1.119, 2.029, .033,
| 52 |
.138, -.333, 1.105,
| 53 |
| 54 |
#endif
| 55 |
| 56 |
| 57 |
| 58 |
spec_rgb(col, s, e) /* compute RGB color from spectral range */
| 59 |
COLOR col;
| 60 |
int s, e;
| 61 |
| 62 |
COLOR ciecolor;
| 63 |
| 64 |
spec_cie(ciecolor, s, e);
| 65 |
cie_rgb(col, ciecolor);
| 66 |
| 67 |
| 68 |
| 69 |
spec_cie(col, s, e) /* compute a color from a spectral range */
| 70 |
COLOR col; /* returned color */
| 71 |
int s, e; /* starting and ending wavelengths */
| 72 |
| 73 |
register int i, d, r;
| 74 |
| 75 |
s -= STARTWL;
| 76 |
if (s < 0)
| 77 |
s = 0;
| 78 |
| 79 |
e -= STARTWL;
| 80 |
if (e <= s) {
| 81 |
col[RED] = col[GRN] = col[BLU] = 0.0;
| 82 |
return;
| 83 |
| 84 |
if (e >= INCWL*(NINC - 1))
| 85 |
e = INCWL*(NINC - 1) - 1;
| 86 |
| 87 |
d = e / INCWL; /* interpolate values */
| 88 |
r = e % INCWL;
| 89 |
for (i = 0; i < 3; i++)
| 90 |
col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
| 91 |
| 92 |
d = s / INCWL;
| 93 |
r = s % INCWL;
| 94 |
| 95 |
col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
| 96 |
| 97 |
col[RED] = (col[RED] + 0.5) / (256*INCWL);
| 98 |
col[GRN] = (col[GRN] + 0.5) / (256*INCWL);
| 99 |
col[BLU] = (col[BLU] + 0.5) / (256*INCWL);
| 100 |
| 101 |
| 102 |
| 103 |
cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB (NTSC) */
| 104 |
register COLOR rgbcolor, ciecolor;
| 105 |
| 106 |
register int i;
| 107 |
| 108 |
for (i = 0; i < 3; i++) {
| 109 |
rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] +
| 110 |
xyz2rgbmat[i][1]*ciecolor[1] +
| 111 |
xyz2rgbmat[i][2]*ciecolor[2] ;
| 112 |
if (rgbcolor[i] < 0.0)
| 113 |
rgbcolor[i] = 0.0;
| 114 |
| 115 |
