refactor: Added scblack and changed cblack and cwhite to global const arrays
fix(rpict): Fixed light source drawing in non-RGB color spaces
feat: Added convertscolorcol() to generate better RGB result
fix(rmtxop,rmtxcomb): Eliminated truncation of RGB's in spec_rgb()
refactor: Added number of spectral samples and wavelength splits to arguments
feat: Added functional check for XYZ color space to coloprimsOK()
refactor: eliminated deprecated register keywords
Even wider acceptance of whacky color primaries
Stricter check on white point
Allow for even larger primary chromaticity range
Improved chromaticity check
Syntax error
Made color primitive checker even more forgiving
Made color primitives check a little more forgiving
Added return values and colorprimsOK() function to check primary ranges
Fixed problems with NaN and Inf floating point color values
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added conservative measures to make sure clipgamut() kept in bounds
fixed bug in colortrans() introduced in last change
added clipgamut() routine for performing gamut mapping and clipping
changed colortrans() to optionally allow negative results
made testing for stdprims more sensible
made changes for new 32-bit_rle_xyze picture type
added rgb_cie() routine
changed RGB primaries and went to true (i.e. equal-energy) white
portability improvements
added correct color transformations
changed cie_rgb to use mapping for color monitor by default
