--- ray/src/common/spec_rgb.c 1990/09/22 10:44:56 1.1 +++ ray/src/common/spec_rgb.c 1993/03/05 15:14:04 2.2 @@ -1,3 +1,5 @@ +/* Copyright (c) 1990 Regents of the University of California */ + #ifndef lint static char SCCSid[] = "$SunId$ LBL"; #endif @@ -37,7 +39,22 @@ static BYTE chroma[3][NINC] = { } }; +#ifdef NTSC +static float xyz2rgbmat[3][3] = { /* XYZ to RGB (NTSC) */ + {1.73, -.48, -.26}, + {-.81, 1.65, -.02}, + {.08, -.17, 1.28} +}; +#else +static float xyz2rgbmat[3][3] = { /* XYZ to RGB (color monitor) */ + {2.739, -1.145, -.424}, + {-1.119, 2.029, .033}, + {.138, -.333, 1.105} +}; +#endif + + spec_rgb(col, s, e) /* compute RGB color from spectral range */ COLOR col; int s, e; @@ -60,6 +77,10 @@ int s, e; /* starting and ending wavelengths */ s = 0; e -= STARTWL; + if (e <= s) { + col[RED] = col[GRN] = col[BLU] = 0.0; + return; + } if (e >= INCWL*(NINC - 1)) e = INCWL*(NINC - 1) - 1; @@ -79,20 +100,15 @@ int s, e; /* starting and ending wavelengths */ } -cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB (NTSC) */ +cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB */ register COLOR rgbcolor, ciecolor; { - static float cmat[3][3] = { - 1.73, -.48, -.26, - -.81, 1.65, -.02, - .08, -.17, 1.28, - }; register int i; for (i = 0; i < 3; i++) { - rgbcolor[i] = cmat[i][0]*ciecolor[0] + - cmat[i][1]*ciecolor[1] + - cmat[i][2]*ciecolor[2] ; + rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] + + xyz2rgbmat[i][1]*ciecolor[1] + + xyz2rgbmat[i][2]*ciecolor[2] ; if (rgbcolor[i] < 0.0) rgbcolor[i] = 0.0; }
