root/radiance/ray/src/common/spec_rgb.c
Revision: 2.13
Committed: Mon Jun 30 19:04:29 2003 UTC (21 years, 10 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.13 static const char RCSid[] = "$Id: spec_rgb.c,v 2.12 2003/02/25 02:47:22 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Convert colors and spectral ranges.
6 greg 2.11 * Added von Kries white-balance calculations 10/01 (GW).
7     *
8     * Externals declared in color.h
9     */
10
11 greg 2.12 #include "copyright.h"
12 greg 1.1
13 greg 2.13 #include <stdio.h>
14     #include <string.h>
15 greg 1.1 #include "color.h"
16 greg 2.11
17     #define CEPS 1e-4 /* color epsilon */
18
19     #define CEQ(v1,v2) ((v1) <= (v2)+CEPS && (v2) <= (v1)+CEPS)
20 greg 1.1
21 greg 2.11 #define XYEQ(c1,c2) (CEQ((c1)[CIEX],(c2)[CIEX]) && CEQ((c1)[CIEY],(c2)[CIEY]))
22 greg 2.5
23 gwlarson 2.10
24 greg 2.11 RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */
25 greg 2.5
26 greg 2.8 COLOR cblack = BLKCOLOR; /* global black color */
27     COLOR cwhite = WHTCOLOR; /* global white color */
28
29 greg 2.11 float xyneu[2] = {1./3., 1./3.}; /* neutral xy chromaticities */
30
31 greg 1.1 /*
32     * The following table contains the CIE tristimulus integrals
33     * for X, Y, and Z. The table is cumulative, so that
34     * each color coordinate integrates to 1.
35     */
36
37     #define STARTWL 380 /* starting wavelength (nanometers) */
38     #define INCWL 10 /* wavelength increment */
39     #define NINC 40 /* # of values */
40
41     static BYTE chroma[3][NINC] = {
42     { /* X */
43     0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
44     42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
45     128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
46     255, 255, 255, 255, 255, 255, 255, 255, 255, 255
47     }, { /* Y */
48     0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
49     17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
50     188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
51     255, 255, 255, 255, 255, 255, 255, 255, 255, 255
52     }, { /* Z */
53     0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
54     237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
55     255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
56     255, 255, 255, 255, 255, 255, 255, 255, 255, 255
57     }
58     };
59
60 greg 2.11 COLORMAT xyz2rgbmat = { /* XYZ to RGB (no white balance) */
61 greg 2.3 {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
62     (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
63     (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD},
64     {(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
65     (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
66     (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD},
67     {(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
68     (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
69     (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD}
70 greg 1.2 };
71 greg 1.1
72 greg 2.11 COLORMAT rgb2xyzmat = { /* RGB to XYZ (no white balance) */
73 greg 2.4 {CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D},
74     {CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D},
75     {(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
76     (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
77     (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D}
78     };
79 greg 1.2
80 greg 2.11 COLORMAT vkmat = { /* Sharp primary matrix */
81     { 1.2694, -0.0988, -0.1706},
82     {-0.8364, 1.8006, 0.0357},
83     { 0.0297, -0.0315, 1.0018}
84     };
85
86     COLORMAT ivkmat = { /* inverse Sharp primary matrix */
87     { 0.8156, 0.0472, 0.1372},
88     { 0.3791, 0.5769, 0.0440},
89     {-0.0123, 0.0167, 0.9955}
90     };
91 greg 1.2
92 greg 2.4
93 greg 2.11 void
94 greg 1.1 spec_rgb(col, s, e) /* compute RGB color from spectral range */
95     COLOR col;
96     int s, e;
97     {
98     COLOR ciecolor;
99
100     spec_cie(ciecolor, s, e);
101     cie_rgb(col, ciecolor);
102     }
103
104
105 greg 2.11 void
106 greg 1.1 spec_cie(col, s, e) /* compute a color from a spectral range */
107     COLOR col; /* returned color */
108     int s, e; /* starting and ending wavelengths */
109     {
110     register int i, d, r;
111
112     s -= STARTWL;
113     if (s < 0)
114     s = 0;
115
116     e -= STARTWL;
117 greg 1.2 if (e <= s) {
118 greg 2.5 col[CIEX] = col[CIEY] = col[CIEZ] = 0.0;
119 greg 1.2 return;
120     }
121 greg 1.1 if (e >= INCWL*(NINC - 1))
122     e = INCWL*(NINC - 1) - 1;
123
124     d = e / INCWL; /* interpolate values */
125     r = e % INCWL;
126     for (i = 0; i < 3; i++)
127     col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
128
129     d = s / INCWL;
130     r = s % INCWL;
131     for (i = 0; i < 3; i++)
132     col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
133
134 greg 2.5 col[CIEX] = (col[CIEX] + 0.5) * (1./(256*INCWL));
135     col[CIEY] = (col[CIEY] + 0.5) * (1./(256*INCWL));
136     col[CIEZ] = (col[CIEZ] + 0.5) * (1./(256*INCWL));
137 greg 1.1 }
138
139
140 greg 2.11 void
141 greg 2.8 cie_rgb(rgb, xyz) /* convert CIE color to standard RGB */
142 greg 2.11 COLOR rgb;
143     COLOR xyz;
144 greg 2.8 {
145     colortrans(rgb, xyz2rgbmat, xyz);
146     clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite);
147     }
148
149
150     int
151     clipgamut(col, brt, gamut, lower, upper) /* clip to gamut cube */
152     COLOR col;
153     double brt;
154     int gamut;
155     COLOR lower, upper;
156     {
157     int rflags = 0;
158     double brtmin, brtmax, v, vv;
159     COLOR cgry;
160     register int i;
161     /* check for no check */
162     if (gamut == 0) return(0);
163     /* check brightness limits */
164     brtmin = 1./3.*(lower[0]+lower[1]+lower[2]);
165     if (gamut & CGAMUT_LOWER && brt < brtmin) {
166     copycolor(col, lower);
167     return(CGAMUT_LOWER);
168     }
169     brtmax = 1./3.*(upper[0]+upper[1]+upper[2]);
170     if (gamut & CGAMUT_UPPER && brt > brtmax) {
171     copycolor(col, upper);
172     return(CGAMUT_UPPER);
173     }
174     /* compute equivalent grey */
175     v = (brt - brtmin)/(brtmax - brtmin);
176     for (i = 0; i < 3; i++)
177     cgry[i] = v*upper[i] + (1.-v)*lower[i];
178     vv = 1.; /* check each limit */
179     for (i = 0; i < 3; i++)
180     if (gamut & CGAMUT_LOWER && col[i] < lower[i]) {
181 gwlarson 2.10 v = (lower[i]+CEPS - cgry[i])/(col[i] - cgry[i]);
182 greg 2.8 if (v < vv) vv = v;
183     rflags |= CGAMUT_LOWER;
184     } else if (gamut & CGAMUT_UPPER && col[i] > upper[i]) {
185 gwlarson 2.10 v = (upper[i]-CEPS - cgry[i])/(col[i] - cgry[i]);
186 greg 2.8 if (v < vv) vv = v;
187     rflags |= CGAMUT_UPPER;
188     }
189     if (rflags) /* desaturate to cube face */
190     for (i = 0; i < 3; i++)
191     col[i] = vv*col[i] + (1.-vv)*cgry[i];
192     return(rflags);
193     }
194
195
196 greg 2.11 void
197 greg 2.8 colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */
198 greg 2.11 register COLOR c2;
199 greg 2.5 register COLORMAT mat;
200 greg 2.11 register COLOR c1;
201 greg 1.1 {
202 greg 2.9 COLOR cout;
203
204     cout[0] = mat[0][0]*c1[0] + mat[0][1]*c1[1] + mat[0][2]*c1[2];
205     cout[1] = mat[1][0]*c1[0] + mat[1][1]*c1[1] + mat[1][2]*c1[2];
206     cout[2] = mat[2][0]*c1[0] + mat[2][1]*c1[1] + mat[2][2]*c1[2];
207
208     copycolor(c2, cout);
209 greg 2.4 }
210
211
212 greg 2.11 void
213 greg 2.5 multcolormat(m3, m2, m1) /* multiply m1 by m2 and put into m3 */
214 greg 2.11 COLORMAT m3; /* m3 can be either m1 or m2 w/o harm */
215     COLORMAT m2, m1;
216 greg 2.4 {
217 greg 2.5 COLORMAT mt;
218     register int i, j;
219 greg 2.4
220     for (i = 0; i < 3; i++)
221 greg 2.5 for (j = 0; j < 3; j++)
222     mt[i][j] = m1[i][0]*m2[0][j] +
223     m1[i][1]*m2[1][j] +
224     m1[i][2]*m2[2][j] ;
225     cpcolormat(m3, mt);
226     }
227
228
229 greg 2.11 void
230 greg 2.5 compxyz2rgbmat(mat, pr) /* compute conversion from CIE to RGB space */
231     COLORMAT mat;
232     register RGBPRIMS pr;
233     {
234     double C_rD, C_gD, C_bD;
235
236 greg 2.6 if (pr == stdprims) { /* can use xyz2rgbmat */
237     cpcolormat(mat, xyz2rgbmat);
238     return;
239     }
240 greg 2.5 C_rD = (1./pr[WHT][CIEY]) *
241     ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
242     pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
243     pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
244     C_gD = (1./pr[WHT][CIEY]) *
245     ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
246     pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
247     pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
248     C_bD = (1./pr[WHT][CIEY]) *
249     ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
250     pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
251     pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
252
253     mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] -
254     pr[BLU][CIEX]*pr[GRN][CIEY] +
255     pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ;
256     mat[0][1] = (pr[BLU][CIEX] - pr[GRN][CIEX] -
257     pr[BLU][CIEX]*pr[GRN][CIEY] +
258     pr[GRN][CIEX]*pr[BLU][CIEY])/C_rD ;
259     mat[0][2] = (pr[GRN][CIEX]*pr[BLU][CIEY] -
260     pr[BLU][CIEX]*pr[GRN][CIEY])/C_rD ;
261     mat[1][0] = (pr[BLU][CIEY] - pr[RED][CIEY] -
262     pr[BLU][CIEY]*pr[RED][CIEX] +
263     pr[RED][CIEY]*pr[BLU][CIEX])/C_gD ;
264     mat[1][1] = (pr[RED][CIEX] - pr[BLU][CIEX] -
265     pr[RED][CIEX]*pr[BLU][CIEY] +
266     pr[BLU][CIEX]*pr[RED][CIEY])/C_gD ;
267     mat[1][2] = (pr[BLU][CIEX]*pr[RED][CIEY] -
268     pr[RED][CIEX]*pr[BLU][CIEY])/C_gD ;
269     mat[2][0] = (pr[RED][CIEY] - pr[GRN][CIEY] -
270     pr[RED][CIEY]*pr[GRN][CIEX] +
271     pr[GRN][CIEY]*pr[RED][CIEX])/C_bD ;
272     mat[2][1] = (pr[GRN][CIEX] - pr[RED][CIEX] -
273     pr[GRN][CIEX]*pr[RED][CIEY] +
274     pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ;
275     mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] -
276     pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ;
277     }
278
279
280 greg 2.11 void
281 greg 2.5 comprgb2xyzmat(mat, pr) /* compute conversion from RGB to CIE space */
282     COLORMAT mat;
283     register RGBPRIMS pr;
284     {
285     double C_rD, C_gD, C_bD, D;
286
287 greg 2.6 if (pr == stdprims) { /* can use rgb2xyzmat */
288     cpcolormat(mat, rgb2xyzmat);
289     return;
290     }
291 greg 2.5 C_rD = (1./pr[WHT][CIEY]) *
292     ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
293     pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
294     pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
295     C_gD = (1./pr[WHT][CIEY]) *
296     ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
297     pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
298     pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
299     C_bD = (1./pr[WHT][CIEY]) *
300     ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
301     pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
302     pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
303     D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) +
304     pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) +
305     pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ;
306     mat[0][0] = pr[RED][CIEX]*C_rD/D;
307     mat[0][1] = pr[GRN][CIEX]*C_gD/D;
308     mat[0][2] = pr[BLU][CIEX]*C_bD/D;
309     mat[1][0] = pr[RED][CIEY]*C_rD/D;
310     mat[1][1] = pr[GRN][CIEY]*C_gD/D;
311     mat[1][2] = pr[BLU][CIEY]*C_bD/D;
312     mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D;
313     mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D;
314     mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D;
315     }
316
317
318 greg 2.11 void
319 greg 2.5 comprgb2rgbmat(mat, pr1, pr2) /* compute conversion from RGB1 to RGB2 */
320     COLORMAT mat;
321     RGBPRIMS pr1, pr2;
322     {
323     COLORMAT pr1toxyz, xyztopr2;
324
325 greg 2.6 if (pr1 == pr2) {
326     mat[0][0] = mat[1][1] = mat[2][2] = 1.0;
327     mat[0][1] = mat[0][2] = mat[1][0] =
328     mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
329     return;
330     }
331     comprgb2xyzmat(pr1toxyz, pr1);
332     compxyz2rgbmat(xyztopr2, pr2);
333 greg 2.5 /* combine transforms */
334     multcolormat(mat, pr1toxyz, xyztopr2);
335 greg 2.11 }
336
337
338     void
339     compxyzWBmat(mat, wht1, wht2) /* CIE von Kries transform from wht1 to wht2 */
340     COLORMAT mat;
341     float wht1[2], wht2[2];
342     {
343     COLOR cw1, cw2;
344     if (XYEQ(wht1,wht2)) {
345     mat[0][0] = mat[1][1] = mat[2][2] = 1.0;
346     mat[0][1] = mat[0][2] = mat[1][0] =
347     mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
348     return;
349     }
350     cw1[RED] = wht1[CIEX]/wht1[CIEY];
351     cw1[GRN] = 1.;
352     cw1[BLU] = (1. - wht1[CIEX] - wht1[CIEY])/wht1[CIEY];
353     colortrans(cw1, vkmat, cw1);
354     cw2[RED] = wht2[CIEX]/wht2[CIEY];
355     cw2[GRN] = 1.;
356     cw2[BLU] = (1. - wht2[CIEX] - wht2[CIEY])/wht2[CIEY];
357     colortrans(cw2, vkmat, cw2);
358     mat[0][0] = cw2[RED]/cw1[RED];
359     mat[1][1] = cw2[GRN]/cw1[GRN];
360     mat[2][2] = cw2[BLU]/cw1[BLU];
361     mat[0][1] = mat[0][2] = mat[1][0] =
362     mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
363     multcolormat(mat, vkmat, mat);
364     multcolormat(mat, mat, ivkmat);
365     }
366
367
368     void
369     compxyz2rgbWBmat(mat, pr) /* von Kries conversion from CIE to RGB space */
370     COLORMAT mat;
371     RGBPRIMS pr;
372     {
373     COLORMAT wbmat;
374
375     compxyz2rgbmat(mat, pr);
376     if (XYEQ(pr[WHT],xyneu))
377     return;
378     compxyzWBmat(wbmat, xyneu, pr[WHT]);
379     multcolormat(mat, wbmat, mat);
380     }
381
382     void
383     comprgb2xyzWBmat(mat, pr) /* von Kries conversion from RGB to CIE space */
384     COLORMAT mat;
385     RGBPRIMS pr;
386     {
387     COLORMAT wbmat;
388
389     comprgb2xyzmat(mat, pr);
390     if (XYEQ(pr[WHT],xyneu))
391     return;
392     compxyzWBmat(wbmat, pr[WHT], xyneu);
393     multcolormat(mat, mat, wbmat);
394     }
395
396     void
397     comprgb2rgbWBmat(mat, pr1, pr2) /* von Kries conversion from RGB1 to RGB2 */
398     COLORMAT mat;
399     RGBPRIMS pr1, pr2;
400     {
401     COLORMAT pr1toxyz, xyztopr2, wbmat;
402
403     if (pr1 == pr2) {
404     mat[0][0] = mat[1][1] = mat[2][2] = 1.0;
405     mat[0][1] = mat[0][2] = mat[1][0] =
406     mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
407     return;
408     }
409     comprgb2xyzmat(pr1toxyz, pr1);
410     compxyzWBmat(wbmat, pr1[WHT], pr2[WHT]);
411     compxyz2rgbmat(xyztopr2, pr2);
412     /* combine transforms */
413     multcolormat(mat, pr1toxyz, wbmat);
414     multcolormat(mat, mat, xyztopr2);
415 greg 1.1 }
