root/radiance/ray/src/common/savqstr.c
Revision: 2.7
Committed: Thu Jul 17 09:21:29 2003 UTC (20 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id: savqstr.c,v 2.6 2003/05/15 05:13:35 greg Exp $";
5 * Save unshared strings.
6 *
7 * External symbols declared in standard.h
8 */
9
10 #include "copyright.h"
11
12 #include <stdlib.h>
13
14 #include "rterror.h"
15
16
17 #if 1
18
19 char *
20 savqstr(s) /* save a private string */
21 register char *s;
22 {
23 register char *cp;
24 char *newp;
25
26 for (cp = s; *cp++; ) /* compute strlen()+1 */
27 ;
28 newp = (char *)malloc(cp-s);
29 if (newp == NULL) {
30 eputs("out of memory in savqstr");
31 quit(1);
32 }
33 for (cp = newp; *cp++ = *s++; ) /* inline strcpy() */
34 ;
35 return(newp); /* return new location */
36 }
37
38
39 void
40 freeqstr(s) /* free a private string */
41 char *s;
42 {
43 if (s != NULL)
44 free((void *)s);
45 }
46
47 #else
48
49 /*
50 * Save unshared strings, packing them together into
51 * large blocks to optimize paging in VM environments.
52 */
53
54 #ifdef SMLMEM
55 #ifndef MINBLOCK
56 #define MINBLOCK (1<<10) /* minimum allocation block size */
57 #endif
58 #ifndef MAXBLOCK
59 #define MAXBLOCK (1<<14) /* maximum allocation block size */
60 #endif
61 #else
62 #ifndef MINBLOCK
63 #define MINBLOCK (1<<12) /* minimum allocation block size */
64 #endif
65 #ifndef MAXBLOCK
66 #define MAXBLOCK (1<<16) /* maximum allocation block size */
67 #endif
68 #endif
69
70 extern char *bmalloc();
71
72
73 char *
74 savqstr(s) /* save a private string */
75 register char *s;
76 {
77 static char *curp = NULL; /* allocated memory pointer */
78 static unsigned nrem = 0; /* bytes remaining in block */
79 static unsigned nextalloc = MINBLOCK; /* next block size */
80 register char *cp;
81 register unsigned n;
82
83 for (cp = s; *cp++; ) /* compute strlen()+1 */
84 ;
85 if ((n = cp-s) > nrem) { /* do we need more core? */
86 bfree(curp, nrem); /* free remnant */
87 while (n > nextalloc)
88 nextalloc <<= 1;
89 if ((curp = bmalloc(nrem=nextalloc)) == NULL) {
90 eputs("out of memory in savqstr");
91 quit(1);
92 }
93 if ((nextalloc <<= 1) > MAXBLOCK) /* double block size */
94 nextalloc = MAXBLOCK;
95 }
96 for (cp = curp; *cp++ = *s++; ) /* inline strcpy() */
97 ;
98 s = curp; /* update allocation info. */
99 curp = cp;
100 nrem -= n;
101 return(s); /* return new location */
102 }
103
104
105 void
106 freeqstr(s) /* free a private string (not recommended) */
107 char *s;
108 {
109 bfree(s, strlen(s)+1);
110 }
111
112 #endif
