root/radiance/ray/src/common/savqstr.c
Tue Oct 29 00:35:06 2024 UTC (7 months ago) by greg
Diff to previous 2.11 , to selected 2.3
refactor: Changed some calls to use const type for better C++ callability
Tue Feb 1 18:43:26 2022 UTC (3 years, 4 months ago) by greg
Changes since 2.10: +15 -6 lines
Diff to previous 2.10 , to selected 2.3
perf: Added check for NULL and empty string
Fri Jun 1 19:17:17 2012 UTC (13 years ago) by greg
Changes since 2.9: +10 -14 lines
Diff to previous 2.9 , to selected 2.3
Minor optimizations
Wed Jul 30 10:11:06 2003 UTC (21 years, 10 months ago) by schorsch
Sun Jul 27 22:12:01 2003 UTC (21 years, 10 months ago) by schorsch
Thu Jul 17 09:21:29 2003 UTC (21 years, 10 months ago) by schorsch
Thu May 15 05:13:35 2003 UTC (22 years ago) by greg
Mon Mar 10 17:13:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.4: +3 -2 lines
Tue Feb 25 02:47:22 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.3: +1 -56 lines
Changes since 2.2: +102 -5 lines
Wed Jan 27 20:23:49 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.1: +44 -10 lines
blocked calls to bmalloc() to optimize VM usage
Tue Nov 12 16:56:07 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1 , to selected 2.3
Mon Jul 22 14:32:39 1991 UTC (33 years, 10 months ago) by greg
Diff to selected 2.3
