--- ray/src/common/savqstr.c 1991/11/12 16:56:07 2.1 +++ ray/src/common/savqstr.c 1993/01/27 20:23:49 2.2 @@ -1,34 +1,68 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1993 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; #endif /* - * Quick and dirty string saver. + * Save unshared strings, packing them together into + * large blocks to optimize paging in VM environments. */ #define NULL 0 -extern char *strcpy(), *strcat(), *bmalloc(); +#ifdef BIGMEM +#ifndef MINBLOCK +#define MINBLOCK (1<<12) /* minimum allocation block size */ +#endif +#ifndef MAXBLOCK +#define MAXBLOCK (1<<16) /* maximum allocation block size */ +#endif +#else +#ifndef MINBLOCK +#define MINBLOCK (1<<10) /* minimum allocation block size */ +#endif +#ifndef MAXBLOCK +#define MAXBLOCK (1<<14) /* maximum allocation block size */ +#endif +#endif +extern char *bmalloc(); + char * savqstr(s) /* save a private string */ -char *s; +register char *s; { + static char *curp = NULL; /* allocated memory pointer */ + static unsigned nrem = 0; /* bytes remaining in block */ + static unsigned nextalloc = MINBLOCK; /* next block size */ register char *cp; + register unsigned n; - if ((cp = bmalloc(strlen(s)+1)) == NULL) { - eputs("out of memory in savqstr"); - quit(1); + for (cp = s; *cp++; ) /* compute strlen()+1 */ + ; + if ((n = cp-s) > nrem) { /* do we need more core? */ + bfree(curp, nrem); /* free remnant */ + while (n > nextalloc) + nextalloc <<= 1; + if ((curp = bmalloc(nrem=nextalloc)) == NULL) { + eputs("out of memory in savqstr"); + quit(1); + } + if ((nextalloc <<= 1) > MAXBLOCK) /* double block size */ + nextalloc = MAXBLOCK; } - (void)strcpy(cp, s); - return(cp); + for (cp = curp; *cp++ = *s++; ) /* inline strcpy() */ + ; + s = curp; /* update allocation info. */ + curp = cp; + nrem -= n; + return(s); /* return new location */ } -freeqstr(s) /* free a private string */ +freeqstr(s) /* free a private string (not recommended) */ char *s; { bfree(s, strlen(s)+1);
