--- ray/src/common/savqstr.c 1991/07/22 14:32:39 1.1 +++ ray/src/common/savqstr.c 2003/07/27 22:12:01 2.8 @@ -1,35 +1,112 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: savqstr.c,v 2.8 2003/07/27 22:12:01 schorsch Exp $"; #endif - /* - * Quick and dirty string saver. + * Save unshared strings. + * + * External symbols declared in standard.h */ -#define NULL 0 +#include "copyright.h" -extern char *strcpy(), *strcat(), *bmalloc(); +#include +#include "rterror.h" + +#if 1 + char * savqstr(s) /* save a private string */ -char *s; +register char *s; { register char *cp; + char *newp; - if ((cp = bmalloc(strlen(s)+1)) == NULL) { + for (cp = s; *cp++; ) /* compute strlen()+1 */ + ; + newp = (char *)malloc(cp-s); + if (newp == NULL) { eputs("out of memory in savqstr"); quit(1); } - (void)strcpy(cp, s); - return(cp); + for (cp = newp; (*cp++ = *s++); ) /* inline strcpy() */ + ; + return(newp); /* return new location */ } +void freeqstr(s) /* free a private string */ char *s; { + if (s != NULL) + free((void *)s); +} + +#else + +/* + * Save unshared strings, packing them together into + * large blocks to optimize paging in VM environments. + */ + +#ifdef SMLMEM +#ifndef MINBLOCK +#define MINBLOCK (1<<10) /* minimum allocation block size */ +#endif +#ifndef MAXBLOCK +#define MAXBLOCK (1<<14) /* maximum allocation block size */ +#endif +#else +#ifndef MINBLOCK +#define MINBLOCK (1<<12) /* minimum allocation block size */ +#endif +#ifndef MAXBLOCK +#define MAXBLOCK (1<<16) /* maximum allocation block size */ +#endif +#endif + +extern char *bmalloc(); + + +char * +savqstr(s) /* save a private string */ +register char *s; +{ + static char *curp = NULL; /* allocated memory pointer */ + static unsigned nrem = 0; /* bytes remaining in block */ + static unsigned nextalloc = MINBLOCK; /* next block size */ + register char *cp; + register unsigned n; + + for (cp = s; *cp++; ) /* compute strlen()+1 */ + ; + if ((n = cp-s) > nrem) { /* do we need more core? */ + bfree(curp, nrem); /* free remnant */ + while (n > nextalloc) + nextalloc <<= 1; + if ((curp = bmalloc(nrem=nextalloc)) == NULL) { + eputs("out of memory in savqstr"); + quit(1); + } + if ((nextalloc <<= 1) > MAXBLOCK) /* double block size */ + nextalloc = MAXBLOCK; + } + for (cp = curp; *cp++ = *s++; ) /* inline strcpy() */ + ; + s = curp; /* update allocation info. */ + curp = cp; + nrem -= n; + return(s); /* return new location */ +} + + +void +freeqstr(s) /* free a private string (not recommended) */ +char *s; +{ bfree(s, strlen(s)+1); } + +#endif
