root/radiance/ray/src/common/savqstr.c
Revision: 2.3
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.2: +102 -5 lines
5 * Save unshared strings.
6 *
7 * External symbols declared in standard.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include <stdlib.h>
68
69 extern void eputs();
70 extern void quit();
71
72 #if 1
73
74 char *
75 savqstr(s) /* save a private string */
76 register char *s;
77 {
78 register char *cp;
79 char *newp;
80
81 for (cp = s; *cp++; ) /* compute strlen()+1 */
82 ;
83 newp = (char *)malloc(cp-s);
84 if (newp == NULL) {
85 eputs("out of memory in savqstr");
86 quit(1);
87 }
88 for (cp = newp; *cp++ = *s++; ) /* inline strcpy() */
89 ;
90 return(newp); /* return new location */
91 }
92
93
94 void
95 freeqstr(s) /* free a private string */
96 char *s;
97 {
98 free((void *)s);
99 }
100
101 #else
102
103 /*
104 * Save unshared strings, packing them together into
105 * large blocks to optimize paging in VM environments.
106 */
107
108 #ifdef BIGMEM
109 #ifndef MINBLOCK
110 #define MINBLOCK (1<<12) /* minimum allocation block size */
111 #endif
112 #ifndef MAXBLOCK
113 #define MAXBLOCK (1<<16) /* maximum allocation block size */
114 #endif
115 #else
116 #ifndef MINBLOCK
117 #define MINBLOCK (1<<10) /* minimum allocation block size */
118 #endif
119 #ifndef MAXBLOCK
120 #define MAXBLOCK (1<<14) /* maximum allocation block size */
121 #endif
122 #endif
123
124 extern char *bmalloc();
125
126
127 char *
128 savqstr(s) /* save a private string */
129 register char *s;
130 {
131 static char *curp = NULL; /* allocated memory pointer */
132 static unsigned nrem = 0; /* bytes remaining in block */
133 static unsigned nextalloc = MINBLOCK; /* next block size */
134 register char *cp;
135 register unsigned n;
136
137 for (cp = s; *cp++; ) /* compute strlen()+1 */
138 ;
139 if ((n = cp-s) > nrem) { /* do we need more core? */
140 bfree(curp, nrem); /* free remnant */
141 while (n > nextalloc)
142 nextalloc <<= 1;
143 if ((curp = bmalloc(nrem=nextalloc)) == NULL) {
144 eputs("out of memory in savqstr");
145 quit(1);
146 }
147 if ((nextalloc <<= 1) > MAXBLOCK) /* double block size */
148 nextalloc = MAXBLOCK;
149 }
150 for (cp = curp; *cp++ = *s++; ) /* inline strcpy() */
151 ;
152 s = curp; /* update allocation info. */
153 curp = cp;
154 nrem -= n;
155 return(s); /* return new location */
156 }
157
158
159 void
160 freeqstr(s) /* free a private string (not recommended) */
161 char *s;
162 {
163 bfree(s, strlen(s)+1);
164 }
165
166 #endif
