root/radiance/ray/src/common/savestr.c
Thu Jun 8 17:48:01 2023 UTC (23 months, 1 week ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.13
fix: passing const char * to savestr() and shash()
Fri May 7 03:09:45 2021 UTC (4 years ago) by greg
Changes since 2.12: +2 -3 lines
Diff to previous 2.12
refactor: removed unneeded #include
Sat Dec 28 18:05:14 2019 UTC (5 years, 4 months ago) by greg
Changes since 2.11: +1 -2 lines
Sun Apr 9 21:33:24 2017 UTC (8 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.10: +9 -7 lines
Fixed issue with reading and saving empty strings
Thu Mar 4 16:34:34 2004 UTC (21 years, 2 months ago) by greg
Increased savestr() hash table size from 509 to 2039
Fri Nov 14 17:22:06 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 2.8: +6 -7 lines
Mon Oct 27 10:19:31 2003 UTC (21 years, 6 months ago) by schorsch
Sat Jun 7 12:50:20 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.6: +6 -5 lines
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.4: +62 -8 lines
Thu Sep 23 12:15:21 1993 UTC (31 years, 8 months ago) by greg
added safety code for signed characters in shash()
Sat Nov 21 21:46:59 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.2: +7 -8 lines
made shash() better and global
Fri Jul 3 10:51:50 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.1: +0 -15 lines
moved strcmp() to separate module
Tue Nov 12 16:54:33 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.3
Mon Oct 28 09:47:27 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.2
Thu Feb 2 13:53:43 1989 UTC (36 years, 3 months ago) by greg
Diff to previous 1.1
Fixed SCCSid
Thu Feb 2 10:34:40 1989 UTC (36 years, 3 months ago) by greg
