root/radiance/ray/src/common/savestr.c
Revision: 2.7
Committed: Sat Jun 7 12:50:20 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.6: +6 -5 lines
2 static const char RCSid[] = "$Id: savestr.c,v 2.6 2003/02/25 02:47:22 greg Exp $";
5 * savestr.c - routines for efficient string storage.
6 *
7 * Savestr(s) stores a shared read-only string.
8 * Freestr(s) indicates a client is finished with a string.
9 * All strings must be null-terminated. There is
10 * no imposed length limit.
11 * Strings stored with savestr(s) can be equated
12 * reliably using their pointer values.
13 * Calls to savestr(s) and freestr(s) should be
14 * balanced (obviously). The last call to freestr(s)
15 * frees memory associated with the string; it should
16 * never be referenced again.
17 *
18 * External symbols declared in standard.h
19 */
20
21 #include "copyright.h"
22
23 #include <string.h>
24 #include <stdlib.h>
25
26 #include "standard.h"
27
28 #ifndef NHASH
29 #define NHASH 509 /* hash table size (prime!) */
30 #endif
31
32 typedef struct s_head {
33 struct s_head *next; /* next in hash list */
34 int nl; /* links count */
35 } S_HEAD; /* followed by the string itself */
36
37 static S_HEAD *stab[NHASH];
38
39 #define hash(s) (shash(s)%NHASH)
40
41 #define string(sp) ((char *)((sp)+1))
42
43 #define salloc(str) (S_HEAD *)malloc(sizeof(S_HEAD)+1+strlen(str))
44
45 #define sfree(sp) free((void *)(sp))
46
47
48 char *
49 savestr(str) /* save a string */
50 char *str;
51 {
52 register int hval;
53 register S_HEAD *sp;
54
55 if (str == NULL)
56 return(NULL);
57 hval = hash(str);
58 for (sp = stab[hval]; sp != NULL; sp = sp->next)
59 if (!strcmp(str, string(sp))) {
60 sp->nl++;
61 return(string(sp));
62 }
63 if ((sp = salloc(str)) == NULL) {
64 eputs("Out of memory in savestr\n");
65 quit(1);
66 }
67 strcpy(string(sp), str);
68 sp->nl = 1;
69 sp->next = stab[hval];
70 stab[hval] = sp;
71 return(string(sp));
72 }
73
74
75 void
76 freestr(s) /* free a string */
77 char *s;
78 {
79 int hval;
80 register S_HEAD *spl, *sp;
81
82 if (s == NULL)
83 return;
84 hval = hash(s);
85 for (spl = NULL, sp = stab[hval]; sp != NULL; spl = sp, sp = sp->next)
86 if (s == string(sp)) {
87 if (--sp->nl > 0)
88 return;
89 if (spl != NULL)
90 spl->next = sp->next;
91 else
92 stab[hval] = sp->next;
93 sfree(sp);
94 return;
95 }
96 }
97
98
99 int
100 shash(s)
101 register char *s;
102 {
103 register int h = 0;
104
105 while (*s)
106 h = (h<<1 & 0x7fff) ^ (*s++ & 0xff);
107 return(h);
108 }
