| 1 |
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
* savestr.c - routines for efficient string storage.
| 7 |
| 8 |
* Savestr(s) stores a shared read-only string.
| 9 |
* Freestr(s) indicates a client is finished with a string.
| 10 |
* All strings must be null-terminated. There is
| 11 |
* no imposed length limit.
| 12 |
* Strings stored with savestr(s) can be equated
| 13 |
* reliably using their pointer values. A tailored version
| 14 |
* of strcmp(s1,s2) is included.
| 15 |
* Calls to savestr(s) and freestr(s) should be
| 16 |
* balanced (obviously). The last call to freestr(s)
| 17 |
* frees memory associated with the string; it should
| 18 |
* never be referenced again.
| 19 |
| 20 |
* 5/14/87
| 21 |
| 22 |
| 23 |
#ifndef NHASH
| 24 |
#define NHASH 509 /* hash table size (prime!) */
| 25 |
#endif
| 26 |
| 27 |
typedef struct s_head {
| 28 |
struct s_head *next; /* next in hash list */
| 29 |
int nl; /* links count */
| 30 |
} S_HEAD; /* followed by the string itself */
| 31 |
| 32 |
static S_HEAD *stab[NHASH];
| 33 |
| 34 |
extern char *savestr(), *strcpy(), *malloc();
| 35 |
| 36 |
#define NULL 0
| 37 |
| 38 |
#define string(sp) ((char *)((sp)+1))
| 39 |
| 40 |
#define salloc(str) (S_HEAD *)malloc(sizeof(S_HEAD)+1+strlen(str))
| 41 |
| 42 |
#define sfree(sp) free((char *)(sp))
| 43 |
| 44 |
| 45 |
char *
| 46 |
savestr(str) /* save a string */
| 47 |
char *str;
| 48 |
| 49 |
register int hval;
| 50 |
register S_HEAD *sp;
| 51 |
| 52 |
if (str == NULL)
| 53 |
return(NULL);
| 54 |
hval = shash(str);
| 55 |
for (sp = stab[hval]; sp != NULL; sp = sp->next)
| 56 |
if (!strcmp(str, string(sp))) {
| 57 |
sp->nl++;
| 58 |
return(string(sp));
| 59 |
| 60 |
if ((sp = salloc(str)) == NULL) {
| 61 |
eputs("Out of memory in savestr\n");
| 62 |
quit(1);
| 63 |
| 64 |
strcpy(string(sp), str);
| 65 |
sp->nl = 1;
| 66 |
sp->next = stab[hval];
| 67 |
stab[hval] = sp;
| 68 |
return(string(sp));
| 69 |
| 70 |
| 71 |
| 72 |
freestr(s) /* free a string */
| 73 |
char *s;
| 74 |
| 75 |
int hval;
| 76 |
register S_HEAD *spl, *sp;
| 77 |
| 78 |
if (s == NULL)
| 79 |
return;
| 80 |
hval = shash(s);
| 81 |
for (spl = NULL, sp = stab[hval]; sp != NULL; spl = sp, sp = sp->next)
| 82 |
if (s == string(sp)) {
| 83 |
if (--sp->nl > 0)
| 84 |
return;
| 85 |
if (spl != NULL)
| 86 |
spl->next = sp->next;
| 87 |
else
| 88 |
stab[hval] = sp->next;
| 89 |
sfree(sp);
| 90 |
return;
| 91 |
| 92 |
| 93 |
| 94 |
| 95 |
int
| 96 |
strcmp(s1, s2) /* check for s1==s2 */
| 97 |
register char *s1, *s2;
| 98 |
| 99 |
if (s1 == s2)
| 100 |
return(0);
| 101 |
| 102 |
while (*s1 == *s2++)
| 103 |
if (!*s1++)
| 104 |
return(0);
| 105 |
| 106 |
return(*s1 - *--s2);
| 107 |
| 108 |
| 109 |
| 110 |
static int
| 111 |
shash(s) /* hash a string */
| 112 |
register char *s;
| 113 |
| 114 |
register int h = 0;
| 115 |
| 116 |
while (*s)
| 117 |
h += *s++;
| 118 |
| 119 |
return(h % NHASH);
| 120 |
