root/radiance/ray/src/common/savestr.c
Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.11: +1 -2 lines
Sun Apr 9 21:33:24 2017 UTC (7 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.10: +9 -7 lines
Fixed issue with reading and saving empty strings
Thu Mar 4 16:34:34 2004 UTC (20 years, 2 months ago) by greg
Increased savestr() hash table size from 509 to 2039
Changes since 2.8: +6 -7 lines
Changes since 2.6: +6 -5 lines
Changes since 2.4: +62 -8 lines
Thu Sep 23 12:15:21 1993 UTC (30 years, 7 months ago) by greg
added safety code for signed characters in shash()
Sat Nov 21 21:46:59 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.2: +7 -8 lines
made shash() better and global
Fri Jul 3 10:51:50 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.1: +0 -15 lines
moved strcmp() to separate module
Tue Nov 12 16:54:33 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 2.6
Mon Oct 28 09:47:27 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 2.6
Thu Feb 2 13:53:43 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.6
Fixed SCCSid
Thu Feb 2 10:34:40 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.6
