root/radiance/ray/src/common/savestr.c
Revision: 2.11
Committed: Sun Apr 9 21:33:24 2017 UTC (8 years, 1 month ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.10: +9 -7 lines
Fixed issue with reading and saving empty strings
2 static const char RCSid[] = "$Id: savestr.c,v 2.10 2004/03/04 16:34:34 greg Exp $";
5 * savestr.c - routines for efficient string storage.
6 *
7 * Savestr(s) stores a shared read-only string.
8 * Freestr(s) indicates a client is finished with a string.
9 * All strings must be null-terminated. There is
10 * no imposed length limit.
11 * Strings stored with savestr(s) can be equated
12 * reliably using their pointer values.
13 * Calls to savestr(s) and freestr(s) should be
14 * balanced (obviously). The last call to freestr(s)
15 * frees memory associated with the string; it should
16 * never be referenced again.
17 *
18 * External symbols declared in standard.h
19 */
20
21 #include "copyright.h"
22
23 #include <string.h>
24 #include <stdlib.h>
25
26 #include "rtmisc.h"
27 #include "rterror.h"
28 #include "rtio.h"
29
30 #ifndef NHASH
31 #define NHASH 2039 /* hash table size (prime!) */
32 #endif
33
34 typedef struct s_head {
35 struct s_head *next; /* next in hash list */
36 int nl; /* links count */
37 } S_HEAD; /* followed by the string itself */
38
39 static S_HEAD *stab[NHASH];
40
41 #define hash(s) (shash(s)%NHASH)
42
43 #define string(sp) ((char *)((sp)+1))
44
45 #define salloc(str) (S_HEAD *)malloc(sizeof(S_HEAD)+1+strlen(str))
46
47 #define sfree(sp) free((void *)(sp))
48
49
50 char *
51 savestr(char *str) /* save a string */
52 {
53 int hval;
54 S_HEAD *sp;
55
56 if (str == NULL)
57 return(NULL);
58 if (!*str)
59 return "";
60 hval = hash(str);
61 for (sp = stab[hval]; sp != NULL; sp = sp->next)
62 if (!strcmp(str, string(sp))) {
63 sp->nl++;
64 return(string(sp));
65 }
66 if ((sp = salloc(str)) == NULL) {
67 eputs("Out of memory in savestr\n");
68 quit(1);
69 }
70 strcpy(string(sp), str);
71 sp->nl = 1;
72 sp->next = stab[hval];
73 stab[hval] = sp;
74 return(string(sp));
75 }
76
77
78 void
79 freestr(char *s) /* free a string */
80 {
81 int hval;
82 S_HEAD *spl, *sp;
83
84 if (s == NULL || !*s)
85 return;
86 hval = hash(s);
87 for (spl = NULL, sp = stab[hval]; sp != NULL; spl = sp, sp = sp->next)
88 if (s == string(sp)) {
89 if (--sp->nl > 0)
90 return;
91 if (spl != NULL)
92 spl->next = sp->next;
93 else
94 stab[hval] = sp->next;
95 sfree(sp);
96 return;
97 }
98 }
99
100
101 int
102 shash(char *s)
103 {
104 int h = 0;
105
106 while (*s)
107 h = (h<<1 & 0x7fff) ^ (*s++ & 0xff);
108 return(h);
109 }
