root/radiance/ray/src/common/savestr.c
Revision: 1.2
Committed: Thu Feb 2 13:53:43 1989 UTC (36 years, 4 months ago) by greg
Fixed SCCSid
1 /* Copyright 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * savestr.c - routines for efficient string storage.
9 *
10 * Savestr(s) stores a shared read-only string.
11 * Freestr(s) indicates a client is finished with a string.
12 * All strings must be null-terminated. There is
13 * no imposed length limit.
14 * Strings stored with savestr(s) can be equated
15 * reliably using their pointer values. A tailored version
16 * of strcmp(s1,s2) is included.
17 * Calls to savestr(s) and freestr(s) should be
18 * balanced (obviously). The last call to freestr(s)
19 * frees memory associated with the string; it should
20 * never be referenced again.
21 *
22 * 5/14/87
23 */
24
25 #ifndef NHASH
26 #define NHASH 509 /* hash table size (prime!) */
27 #endif
28
29 typedef struct s_head {
30 struct s_head *next; /* next in hash list */
31 int nl; /* links count */
32 } S_HEAD; /* followed by the string itself */
33
34 static S_HEAD *stab[NHASH];
35
36 extern char *savestr(), *strcpy(), *malloc();
37
38 #define NULL 0
39
40 #define string(sp) ((char *)((sp)+1))
41
42 #define salloc(str) (S_HEAD *)malloc(sizeof(S_HEAD)+1+strlen(str))
43
44 #define sfree(sp) free((char *)(sp))
45
46
47 char *
48 savestr(str) /* save a string */
49 char *str;
50 {
51 register int hval;
52 register S_HEAD *sp;
53
54 if (str == NULL)
55 return(NULL);
56 hval = shash(str);
57 for (sp = stab[hval]; sp != NULL; sp = sp->next)
58 if (!strcmp(str, string(sp))) {
59 sp->nl++;
60 return(string(sp));
61 }
62 if ((sp = salloc(str)) == NULL) {
63 eputs("Out of memory in savestr\n");
64 quit(1);
65 }
66 strcpy(string(sp), str);
67 sp->nl = 1;
68 sp->next = stab[hval];
69 stab[hval] = sp;
70 return(string(sp));
71 }
72
73
74 freestr(s) /* free a string */
75 char *s;
76 {
77 int hval;
78 register S_HEAD *spl, *sp;
79
80 if (s == NULL)
81 return;
82 hval = shash(s);
83 for (spl = NULL, sp = stab[hval]; sp != NULL; spl = sp, sp = sp->next)
84 if (s == string(sp)) {
85 if (--sp->nl > 0)
86 return;
87 if (spl != NULL)
88 spl->next = sp->next;
89 else
90 stab[hval] = sp->next;
91 sfree(sp);
92 return;
93 }
94 }
95
96
97 int
98 strcmp(s1, s2) /* check for s1==s2 */
99 register char *s1, *s2;
100 {
101 if (s1 == s2)
102 return(0);
103
104 while (*s1 == *s2++)
105 if (!*s1++)
106 return(0);
107
108 return(*s1 - *--s2);
109 }
110
111
112 static int
113 shash(s) /* hash a string */
114 register char *s;
115 {
116 register int h = 0;
117
118 while (*s)
119 h += *s++;
120
121 return(h % NHASH);
122 }
