| 1 |
/* RCSid $Id: rtprocess.h,v 3.5 2003/10/21 19:19:28 schorsch Exp $ */
| 2 |
| 3 |
* rtprocess.h
| 4 |
* Routines to communicate with separate process via dual pipes
| 5 |
| 6 |
* WARNING: On Windows, there's a system header named <process.h>.
| 7 |
| 8 |
#ifndef _RAD_PROCESS_H_
| 9 |
#define _RAD_PROCESS_H_
| 10 |
| 11 |
#include <errno.h>
| 12 |
#ifdef _WIN32
| 13 |
#include <windows.h> /* DWORD etc. */
| 14 |
#include <stdio.h>
| 15 |
typedef DWORD pid_t;
| 16 |
#include <process.h> /* getpid() and others */
| 17 |
#define nice(inc) win_nice(inc)
| 18 |
| 19 |
#ifdef __cplusplus
| 20 |
extern "C" {
| 21 |
#endif
| 22 |
extern FILE *win_popen(char *command, char *type);
| 23 |
extern int win_pclose(FILE *p);
| 24 |
#ifdef __cplusplus
| 25 |
| 26 |
#endif
| 27 |
| 28 |
#define popen(cmd,mode) win_popen(cmd,mode)
| 29 |
#define pclose(p) win_pclose(p)
| 30 |
#else
| 31 |
#include <sys/param.h>
| 32 |
#endif
| 33 |
| 34 |
#include "paths.h"
| 35 |
| 36 |
#ifdef __cplusplus
| 37 |
extern "C" {
| 38 |
#endif
| 39 |
| 40 |
/* On Windows, a process ID is a DWORD. That might actually be the
| 41 |
same thing as an int, but it's better not to assume anything.
| 42 |
| 43 |
This means that we shouldn't rely on PIDs and file descriptors
| 44 |
being the same type, so we have to describe processes with a struct,
| 45 |
instead of the original int[3]. To keep things simple, we typedef
| 46 |
the posix pid_t on those systems that don't have it already.
| 47 |
| 48 |
| 49 |
| 50 |
#ifndef PIPE_BUF
| 51 |
#ifdef PIPSIZ
| 52 |
#define PIPE_BUF PIPSIZ
| 53 |
#else
| 54 |
#ifdef PIPE_MAX
| 55 |
#define PIPE_BUF PIPE_MAX
| 56 |
#else
| 57 |
#define PIPE_BUF 512 /* hyperconservative */
| 58 |
#endif
| 59 |
#endif
| 60 |
#endif
| 61 |
| 62 |
typedef struct {
| 63 |
int r; /* read handle */
| 64 |
int w; /* write handle */
| 65 |
int running; /* doing something */
| 66 |
pid_t pid; /* process ID */
| 67 |
} SUBPROC;
| 68 |
| 69 |
#define SP_INACTIVE {-1,-1,0,0} /* for static initializations */
| 70 |
| 71 |
extern int open_process(SUBPROC *pd, char *av[]);
| 72 |
extern int close_process(SUBPROC *pd);
| 73 |
extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs);
| 74 |
extern int readbuf(int fd, char *bpos, int siz);
| 75 |
extern int writebuf(int fd, char *bpos, int siz);
| 76 |
| 77 |
#ifdef _WIN32
| 78 |
/* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */
| 79 |
extern int win_nice(int inc);
| 80 |
#endif
| 81 |
| 82 |
| 83 |
#ifdef __cplusplus
| 84 |
| 85 |
#endif
| 86 |
#endif /* _RAD_PROCESS_H_ */
| 87 |
