root/radiance/ray/src/common/rtprocess.h
Revision: 3.3
Committed: Mon Jul 14 20:02:29 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.2: +5 -10 lines
1 /* RCSid $Id: rtprocess.h,v 3.2 2003/06/27 06:53:21 greg Exp $ */
2 /*
3 * rtprocess.h
4 * Routines to communicate with separate process via dual pipes
5 *
6 * WARNING: On Windows, there's a system header named <process.h>.
7 */
8 #ifndef _RAD_PROCESS_H_
9 #define _RAD_PROCESS_H_
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 #include <errno.h>
15 #ifdef _WIN32
16 #include <windows.h> /* DWORD etc. */
17 typedef DWORD pid_t;
18 #include <process.h> /* getpid() and others */
19 #else
20 #include <sys/param.h>
21 #endif
22
23 #include "paths.h"
24
25
26 /* On Windows, a process ID is a DWORD. That might actually be the
27 same thing as an int, but it's better not to assume anything.
28
29 This means that we shouldn't rely on PIDs and file descriptors
30 being the same type, so we have to describe processes with a struct,
31 instead of the original int[3]. To keep things simple, we typedef
32 the posix pid_t on those systems that don't have it already.
33
34 Some older Windows systems use negative PIDs. Open_process() and
35 close_process() will convert those to positive values during
36 runtime, so that client modules can still use -1 as invalid PID.
37 */
38
39
40 #ifndef PIPE_BUF
41 #ifdef PIPSIZ
42 #define PIPE_BUF PIPSIZ
43 #else
44 #ifdef PIPE_MAX
45 #define PIPE_BUF PIPE_MAX
46 #else
47 #define PIPE_BUF 512 /* hyperconservative */
48 #endif
49 #endif
50 #endif
51
52 typedef struct {
53 int r; /* read handle */
54 int w; /* write handle */
55 int running; /* doing something */
56 pid_t pid; /* process ID */
57 } SUBPROC;
58
59 #define SP_INACTIVE {-1,-1,0,0} /* for static initializations */
60
61 extern int open_process(SUBPROC *pd, char *av[]);
62 extern int close_process(SUBPROC *pd);
63 extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs);
64 extern int readbuf(int fd, char *bpos, int siz);
65 extern int writebuf(int fd, char *bpos, int siz);
66
67
68 #ifdef __cplusplus
69 }
70 #endif
71 #endif /* _RAD_PROCESS_H_ */
72
