1 |
/* RCSid $Id: rtprocess.h,v 3.19 2020/02/28 16:23:47 greg Exp $ */ |
2 |
3 |
* rtprocess.h |
4 |
* Routines to communicate with separate process via dual pipes |
5 |
6 |
* WARNING: On Windows, there's a system header named <process.h>. |
7 |
8 |
#ifndef _RAD_PROCESS_H_ |
9 |
#define _RAD_PROCESS_H_ |
10 |
11 |
#include <errno.h> |
12 |
#include <stdio.h> |
13 |
#if defined(_WIN32) || defined(_WIN64) |
14 |
#include <windows.h> /* DWORD etc. */ |
15 |
typedef DWORD RT_PID; |
16 |
#include <process.h> /* getpid() and others */ |
17 |
#define getpid _getpid |
18 |
#define execv _execv |
19 |
#define execvp _execvp |
20 |
#else |
21 |
#include <sys/param.h> |
22 |
#include <sys/types.h> |
23 |
typedef pid_t RT_PID; |
24 |
#endif |
25 |
26 |
#include "paths.h" |
27 |
28 |
#ifdef __cplusplus |
29 |
extern "C" { |
30 |
#endif |
31 |
32 |
/* On Windows, a process ID is a DWORD. That might actually be the |
33 |
same thing as an int, but it's better not to assume anything. |
34 |
35 |
This means that we shouldn't rely on PIDs and file descriptors |
36 |
being the same type, so we have to describe processes with a struct, |
37 |
instead of the original int[3]. For that purpose, we typedef a |
38 |
platform independent RT_PID. |
39 |
40 |
41 |
/* On Unix, we can set flags and assign descriptors before opening a |
42 |
process, coupling an existing input or output to the new process rather |
43 |
than opening both pipes. If PF_FILT_INP is passed in the flags member of |
44 |
SUBPROC, then the given r stream will be attached to the standard input |
45 |
of the child process, and subsequent reads from that descriptor in the |
46 |
parent get data from the standard output of the child, instead. The |
47 |
returned w descriptor is set to -1, since there is no longer any way |
48 |
to write to the input of the child. The default r descriptor of 0 will |
49 |
compel the child to act as a filter on the standard input of the parent. |
50 |
Whatever r handle you specify, the child will filter its read operations. |
51 |
Note that this should be called before anything has been buffered using r. |
52 |
If PF_FILT_OUT is set in flags, then the given w stream will be |
53 |
attached to the standard output of the child, and subsequent writes |
54 |
to that descriptor in the parent send data to the standard input |
55 |
of the child. The returned r descriptor is set to -1, since |
56 |
there is no output to read from any longer in the child. The |
57 |
default w descriptor of 1 will cause the child to act as a filter |
58 |
on the output of the parent. Make sure to call fflush(stdout) first |
59 |
if any data was buffered. It is illegal to set both PF_FILT_INP and |
60 |
PF_FILT_OUT, as a circular process is guaranteed to hang. |
61 |
62 |
If you want behavior similar to popen(cmd, "w") (again Unix-only), |
63 |
keeping stdout open in parent, use a duplicate descriptor like so: |
64 |
65 |
SUBPROC rtp = sp_inactive; |
66 |
FILE *fout; |
67 |
fflush(stdout); |
68 |
rtp.w = dup(fileno(stdout)); |
69 |
rtp.flags |= PF_FILT_OUT; |
70 |
if (open_process(&rtp, cmd_argv) <= 0) { |
71 |
perror(cmd_argv[0]); exit(1); |
72 |
73 |
fout = fdopen(rtp.w, "w"); |
74 |
...write data to filter using fout until finished... |
75 |
fclose(fout); |
76 |
if (close_process(&rtp)) { |
77 |
78 |
79 |
...can continue sending data directly to stdout... |
80 |
81 |
We could also have called open_process() after fdopen() above, or after |
82 |
using fopen() on a file if we wanted to insert our filter before it. |
83 |
A similar sequence may be used to filter from stdin without closing |
84 |
it, though process termination becomes more difficult with two readers. |
85 |
Filtering input from a file works better, since the file is then read by |
86 |
the child only, as in: |
87 |
88 |
89 |
FILE *fin = fopen(fname, "r"); |
90 |
if (fin == NULL) { |
91 |
open_error(fname); exit(1); |
92 |
93 |
rtp.r = fileno(fin); |
94 |
rtp.flags |= PF_FILT_INP; |
95 |
96 |
perror(cmd_argv[0]); fclose(fin); exit(1); |
97 |
98 |
...read filtered file data from fin until EOF... |
99 |
fclose(fin); |
100 |
101 |
102 |
103 |
104 |
105 |
106 |
107 |
#ifndef PIPE_BUF |
108 |
#ifdef PIPSIZ |
109 |
#define PIPE_BUF PIPSIZ |
110 |
#else |
111 |
#ifdef PIPE_MAX |
112 |
#define PIPE_BUF PIPE_MAX |
113 |
#else |
114 |
#define PIPE_BUF 512 /* hyperconservative */ |
115 |
#endif |
116 |
#endif |
117 |
#endif |
118 |
/* process flags */ |
119 |
#define PF_RUNNING 1 /* process is running */ |
120 |
#define PF_FILT_INP 2 /* use assigned read descriptor */ |
121 |
#define PF_FILT_OUT 4 /* use assigned write descriptor */ |
122 |
123 |
typedef struct { |
124 |
int flags; /* what is being done */ |
125 |
int r; /* read handle */ |
126 |
int w; /* write handle */ |
127 |
RT_PID pid; /* process ID */ |
128 |
} SUBPROC; |
129 |
130 |
#define SP_INACTIVE {0,0,1,-1} /* for static initializations */ |
131 |
132 |
#define close_process(pd) close_processes(pd,1) |
133 |
134 |
extern int open_process(SUBPROC *pd, char *av[]); |
135 |
extern int close_processes(SUBPROC pd[], int nproc); |
136 |
extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs); |
137 |
extern ssize_t readbuf(int fd, char *bpos, ssize_t siz); |
138 |
extern ssize_t writebuf(int fd, char *bpos, ssize_t siz); |
139 |
140 |
141 |
/* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */ |
142 |
extern int win_kill(RT_PID pid, int sig /* ignored */); |
143 |
extern int win_nice(int inc); |
144 |
#endif |
145 |
146 |
extern SUBPROC sp_inactive; |
147 |
148 |
149 |
150 |
#endif |
151 |
#endif /* _RAD_PROCESS_H_ */ |
152 |
