root/Development/ray/src/common/rtprocess.h
Tue Oct 29 00:35:06 2024 UTC (12 months ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 3.24 , to selected 3.5
refactor: Changed some calls to use const type for better C++ callability
Mon Jun 3 18:55:51 2024 UTC (16 months, 4 weeks ago) by greg
Changes since 3.23: +4 -4 lines
Diff to previous 3.23 , to selected 3.5
refactor: Changed buffer types in process(), readbuf(), writebuf()
Wed Apr 7 01:15:53 2021 UTC (4 years, 6 months ago) by greg
Diff to previous 3.22 , to selected 3.5
docs: fixed comment
Tue Jan 19 18:15:32 2021 UTC (4 years, 9 months ago) by greg
Changes since 3.21: +7 -6 lines
Diff to previous 3.21 , to selected 3.5
fix: changed definiton of ssize_t for Windows
Mon Jan 18 03:55:33 2021 UTC (4 years, 9 months ago) by greg
Diff to previous 3.20 , to selected 3.5
fix: compile error under Windows
Fri Jan 15 19:01:53 2021 UTC (4 years, 9 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19 , to selected 3.5
fix: more 64-bit fixes
Fri Feb 28 16:23:47 2020 UTC (5 years, 8 months ago) by greg
Changes since 3.18: +44 -1 lines
Diff to previous 3.18 , to selected 3.5
Added more comments about how to use new filtering features
Fri Feb 28 05:18:49 2020 UTC (5 years, 8 months ago) by greg
Changes since 3.17: +33 -6 lines
Diff to previous 3.17 , to selected 3.5
Tue Mar 20 17:45:07 2018 UTC (7 years, 7 months ago) by greg
Changes since 3.16: +2 -1 lines
Diff to previous 3.16 , to selected 3.5
Added Windows _execvp()
Sun Mar 6 01:13:17 2016 UTC (9 years, 7 months ago) by schorsch
Changes since 3.15: +5 -3 lines
Diff to previous 3.15 , to selected 3.5
Fri Mar 4 02:48:14 2016 UTC (9 years, 8 months ago) by greg
Changes since 3.14: +4 -2 lines
Diff to previous 3.14 , to selected 3.5
Made quitting rvu, rholo and rcontrib quicker with multiple processes on Unix
Wed Feb 3 22:41:35 2016 UTC (9 years, 9 months ago) by greg
Changes since 3.13: +2 -1 lines
Diff to previous 3.13 , to selected 3.5
Fixed errors introduced in Windows
Tue Feb 2 18:02:32 2016 UTC (9 years, 9 months ago) by greg
Changes since 3.12: +2 -22 lines
Diff to previous 3.12 , to selected 3.5
Tue Mar 4 17:06:13 2014 UTC (11 years, 8 months ago) by greg
Changes since 3.11: +8 -4 lines
Diff to previous 3.11 , to selected 3.5
Changed to using _popen and _pclose under MicroSoft VisualStudio
Sat Oct 23 18:55:52 2004 UTC (21 years ago) by schorsch
CVS Tags: rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1
Changes since 3.10: +3 -1 lines
Diff to previous 3.10 , to selected 3.5
Wed Jan 28 12:42:22 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.9: +7 -5 lines
Diff to previous 3.9 , to selected 3.5
Created our own RT_PID instead of hijacking pid_t on Windows.
Fri Nov 14 17:22:06 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.8: +2 -1 lines
Diff to previous 3.8 , to selected 3.5
Tue Nov 11 16:24:06 2003 UTC (21 years, 11 months ago) by greg
Changes since 3.7: +1 -5 lines
Diff to previous 3.7 , to selected 3.5
Mon Nov 10 16:41:52 2003 UTC (21 years, 11 months ago) by greg
Changes since 3.6: +5 -1 lines
Diff to previous 3.6 , to selected 3.5
Mon Oct 27 10:19:31 2003 UTC (22 years ago) by schorsch
Changes since 3.5: +14 -1 lines
Diff to previous 3.5
Revision 3.5 - (view) (download) (annotate) - [selected]
Tue Oct 21 19:19:28 2003 UTC (22 years ago) by schorsch
Changes since 3.4: +7 -5 lines
Diff to previous 3.4
Mon Jul 14 22:23:59 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.3: +4 -4 lines
Diff to previous 3.3 , to selected 3.5
Mon Jul 14 20:02:29 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.2: +5 -10 lines
Diff to previous 3.2 , to selected 3.5
Fri Jun 27 06:53:21 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.1: +1 -4 lines
Diff to previous 3.1 , to selected 3.5
Thu Jun 26 00:58:09 2003 UTC (22 years, 4 months ago) by schorsch
Diff to selected 3.5
