--- ray/src/common/rtprocess.h 2016/02/03 22:41:35 3.14 +++ ray/src/common/rtprocess.h 2024/10/29 00:35:06 3.25 @@ -1,4 +1,4 @@ -/* RCSid $Id: rtprocess.h,v 3.14 2016/02/03 22:41:35 greg Exp $ */ +/* RCSid $Id: rtprocess.h,v 3.25 2024/10/29 00:35:06 greg Exp $ */ /* * rtprocess.h * Routines to communicate with separate process via dual pipes @@ -8,19 +8,23 @@ #ifndef _RAD_PROCESS_H_ #define _RAD_PROCESS_H_ -#include -#include -#ifdef _WIN32 +#include +#include "paths.h" +#if defined(_WIN32) || defined(_WIN64) #include /* DWORD etc. */ typedef DWORD RT_PID; #include /* getpid() and others */ + #define getpid _getpid + #define execv _execv + #define execvp _execvp + #ifdef _MSC_VER + #include + typedef SSIZE_T ssize_t; + #endif #else - #include - #include typedef pid_t RT_PID; #endif -#include "paths.h" #ifdef __cplusplus extern "C" { @@ -35,7 +39,72 @@ extern "C" { platform independent RT_PID. */ +/* On Unix, we can set flags and assign descriptors before opening a + process, coupling an existing input or output to the new process rather + than opening both pipes. If PF_FILT_INP is passed in the flags member of + SUBPROC, then the given r stream will be attached to the standard input + of the child process, and subsequent reads from that descriptor in the + parent get data from the standard output of the child, instead. The + returned w descriptor is set to -1, since there is no longer any way + to write to the input of the child. The default r descriptor of 0 will + compel the child to act as a filter on the standard input of the parent. + Whatever r handle you specify, the child will filter its read operations. + Note that this should be called before anything has been buffered using r. + If PF_FILT_OUT is set in flags, then the given w stream will be + attached to the standard output of the child, and subsequent writes + to that descriptor in the parent send data to the standard input + of the child. The returned r descriptor is set to -1, since + there is no longer any output to read from the child. The + default w descriptor of 1 will cause the child to act as a filter + on the output of the parent. Make sure to call fflush(stdout) first + if any data was buffered. It is illegal to set both PF_FILT_INP and + PF_FILT_OUT, as a circular process is guaranteed to hang. + + If you want behavior similar to popen(cmd, "w") (again Unix-only), + keeping stdout open in parent, use a duplicate descriptor like so: + { + SUBPROC rtp = sp_inactive; + FILE *fout; + fflush(stdout); + rtp.w = dup(fileno(stdout)); + rtp.flags |= PF_FILT_OUT; + if (open_process(&rtp, cmd_argv) <= 0) { + perror(cmd_argv[0]); exit(1); + } + fout = fdopen(rtp.w, "w"); + ...write data to filter using fout until finished... + fclose(fout); + if (close_process(&rtp)) { + perror(cmd_argv[0]); exit(1); + } + ...can continue sending data directly to stdout... + } + We could also have called open_process() after fdopen() above, or after + using fopen() on a file if we wanted to insert our filter before it. + A similar sequence may be used to filter from stdin without closing + it, though process termination becomes more difficult with two readers. + Filtering input from a file works better, since the file is then read by + the child only, as in: + { + SUBPROC rtp = sp_inactive; + FILE *fin = fopen(fname, "r"); + if (fin == NULL) { + open_error(fname); exit(1); + } + rtp.r = fileno(fin); + rtp.flags |= PF_FILT_INP; + if (open_process(&rtp, cmd_argv) <= 0) { + perror(cmd_argv[0]); fclose(fin); exit(1); + } + ...read filtered file data from fin until EOF... + fclose(fin); + if (close_process(&rtp)) { + perror(cmd_argv[0]); exit(1); + } + } +*/ + #ifndef PIPE_BUF #ifdef PIPSIZ #define PIPE_BUF PIPSIZ @@ -47,28 +116,35 @@ extern "C" { #endif #endif #endif + /* process flags */ +#define PF_RUNNING 1 /* process is running */ +#define PF_FILT_INP 2 /* use assigned read descriptor */ +#define PF_FILT_OUT 4 /* use assigned write descriptor */ typedef struct { - int r; /* read handle */ - int w; /* write handle */ - int running; /* doing something */ - RT_PID pid; /* process ID */ + int flags; /* what is being done */ + int r; /* read handle */ + int w; /* write handle */ + RT_PID pid; /* process ID */ } SUBPROC; -#define SP_INACTIVE {-1,-1,0,0} /* for static initializations */ +#define SP_INACTIVE {0,0,1,-1} /* for static initializations */ +#define close_process(pd) close_processes(pd,1) + extern int open_process(SUBPROC *pd, char *av[]); -extern int close_process(SUBPROC *pd); -extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs); -extern int readbuf(int fd, char *bpos, int siz); -extern int writebuf(int fd, char *bpos, int siz); +extern int close_processes(SUBPROC pd[], int nproc); +extern int process(SUBPROC *pd, void *recvbuf, void *sendbuf, int nbr, int nbs); +extern ssize_t readbuf(int fd, void *bpos, ssize_t siz); +extern ssize_t writebuf(int fd, const void *bpos, ssize_t siz); -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) /* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */ extern int win_kill(RT_PID pid, int sig /* ignored */); extern int win_nice(int inc); #endif +extern SUBPROC sp_inactive; #ifdef __cplusplus }
